Old 04-03-2005, 08:46 PM   #1
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
Default My attempt at altering the Low Det fuel map
So..this is my first attempt at altering the fuel maps. I used many sources of info, books, Nasioc members and also lots and lots of data logs. As you can see from the screenshot, I richend the mixture in the mid load mid rpm range. you can compare the Stage 2 v122 map to mine below. I also leaned out the high load and high RPM areas where boost (according to the Boost map) begins to drop. Just gonna post this up here for opinions. Opinions such as, "Kaboom" and "your an idiot" or "I have a block for sale" are also welcome if that is what you really think.
This one is the modified one
This one is the original v122 Stage 2
darksands is offline   Reply With Quote
Old 04-03-2005, 11:47 PM   #2
HonduHunter
Member#: 28408
2002 vf48ed WRX
just out of curiosity...
why did you add fuel to the mid range?
and what are you using to tune? stock narrowband or a wideband?
HonduHunter is offline   Reply With Quote
Old 04-04-2005, 12:18 AM   #3
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Have you done any logging to see how the programmed targets match what your car is really doing? I don't have a WB, however, on the stock O2, it seems like the car is running a bit richer than the programmed values.
crazymikie is offline   Reply With Quote
Old 04-04-2005, 02:40 AM   #4
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
I raised fuel in midrange cause that is where my EGT's start to climb towards 1200+. I usually stay at .9 load when in normal cruising according to my datalog. I am using stock O2 but according to what many people say, in Cali, whether due to gas or enviornmental reasons, the cars here run leaner than programmed values. I am running a Stage 2 street tuner map, not specified for what octane gas.
Old 04-04-2005, 07:16 AM   #5
happasaiyan
Member#: 37731
where is your EGT tapped? if close to the block, 1200F isnt bad at all.
happasaiyan is online now   Reply With Quote
Old 04-04-2005, 11:07 AM   #6
buzz313th
Member#: 37008
2005 WRX Sedan (STX)
Crystal Grey -TeamBrew-
Subscribing
buzz313th is offline   Reply With Quote
Old 04-04-2005, 03:09 PM   #7
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
It is close to the block. If you can picture this in your mind, the EGT is tapped near the Oil filter is. It is where both 1 and 3 meet. 1200 at a regular everyday driving pace seems high to me. EGT's easily go up to 1400 at half throttle in the 4000-5000 rpm range in 3rd gear. At WOT I reach 1600 in 4th. Unfortunatley, I have not been able to datalog a fourth gear pull at WOT from 3000RPM to redline. Gotta do that on a track ya know
Old 04-04-2005, 03:19 PM   #8
happasaiyan
Member#: 37731
ok, youre where you should be up top...you might need some richening up...or add a little more ign advance...
Old 04-04-2005, 04:05 PM   #9
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
I was going to say... if you're talking midrange cruise conditions, you should be at 14.7:1, period.
If you have an EGT issue, it's timing related. A WRX in the 2700-3500 range (typical highway cruise) is in the 39-42 degree area. Where the STI is about 3-4 more degrees above that.
In the midrange for spoolability, I'd lean out a touch and add timing. But cruise conditions are what I've stated.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 04-04-2005, 04:26 PM   #10
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
I figured alot about timing advance but as of right now, Im not comfortable with altering those maps cause I dont know enough. Again, I am not running this map on my car, I am running the off the shelf street tuner map. This is just an attempt at learning how to tune. I appreciate all the help I have recieved and Hope to learn a little more about top dead center and timing. Im reading about TDC and so far all I seem to know is the optimum for torque is 8-10 degrees after TDC. Anyways, I still need to start with the basics of timing. Anyone have any good reads on it? When I mean basics, I mean BASICS... They should write a book, Tuning for dummies.
Orif someone could explain the degrees beore timing to me that would be great. just learnin here.
My Attempt at a Grounding Kit FalconRS Electrical & Lighting 4 08-30-2005 02:08 PM
My Attempt At A Desktop Background Killian Maynard Member's Car Gallery 1 02-09-2005 09:11 PM
Why must all my attempts at masonry fail? WHTWRX Off-Topic 5 09-15-2003 05:44 PM
my attempt at painting... AndyWRXWG Interior & Exterior Modification 1 08-17-2003 06:08 PM
My attempt at an 03 Subaru Shootout video DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 25 06-29-2003 08:02 PM
