Old 04-06-2005, 11:14 PM   #1
builtscubie
Member#: 82706
02 wrx
sadona red
Default AEM- UEGO problems...
does anyone kno whow to properly tune the UEGO we seem to be having a lil bit of problems..
builtscubie is offline   Reply With Quote
Old 04-06-2005, 11:32 PM   #2
snwman
Member#: 72680
2013 Subaru STi
what do you mean tune the uego?
snwman is offline   Reply With Quote
Old 04-07-2005, 11:10 AM   #3
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Yeah, that was a pretty content-less help request
jblaine is offline   Reply With Quote
Old 04-07-2005, 07:24 PM   #4
mistaboosta
Member#: 68722
did u try the instructions on AEM Forums?
mistaboosta is offline   Reply With Quote
Old 04-08-2005, 08:43 PM   #5
0db
Member#: 33879
2003 WRX Sporkwagon
Its factory calibrated and the 0-5v analog outs are well documented in the manual, I dunno what else you would need.
I just got mine, was wondering where everyone brought that massive connector thru the firewall...?
0db is offline   Reply With Quote
Old 04-08-2005, 09:08 PM   #6
snwman
Member#: 72680
2013 Subaru STi
above the pedals it barely fits thru that plug and i mean barely. did you get teh gauge type or non gauge type.
Old 04-08-2005, 09:20 PM   #7
0db
Member#: 33879
2003 WRX Sporkwagon
Gauge type, I like having it visible!
Old 04-10-2005, 01:40 AM   #8
snwman
Member#: 72680
2013 Subaru STi
same one I got. I used the plug above the pedals to get that massive connector through but you can depin the connector if you wish aemforums have instructions and also have a pinout incase you mix them up!. 0db you have the AEM ems also right? have you gotten that installed yet?
Old 04-10-2005, 03:32 AM   #9
0db
Member#: 33879
2003 WRX Sporkwagon
Yeah, I've been running around on the EMS for a few weeks now. So far, so good. I don't think I'm making a lot more power than stock engine management at the moment, but I've got it reasonably smooth and driveable, and decided I wanted to get all those issues ironed out (this is my daily commute driver) before I tried to push the power up. Once I've got the gauge UEGO in there, I'm considering going to a closed-loop fueling for cruise/vacuum operation. Need to keep that fuel economy up these days!
Old 04-11-2005, 01:52 AM   #10
snwman
Member#: 72680
2013 Subaru STi
the aem base map sucks if you want to run closed loops o2 feedback. You would need to convert to a 3D map from the boost comp map. I am working on this right now so that I can use closed loop to get it tuned to a desired AFR until I can get it dyno tuned.
Old 04-11-2005, 12:36 PM   #11
0db
Member#: 33879
2003 WRX Sporkwagon
Technically there's no reason you can't run boost comp AND fine tune the map in 3d... I actually let autotune do that a bit, it smoothed out some spots that I had trouble isolating with just boost and throttle comp.
Old 04-11-2005, 05:41 PM   #12
snwman
Member#: 72680
2013 Subaru STi
your right there is no reason you cant use boost comp and make the map 3d but it could get a little complicated.
Old 04-12-2005, 12:52 PM   #13
0db
Member#: 33879
2003 WRX Sporkwagon
What I was actually doing is logging the changes the autotune made, and trying to find a way to accomplish the same thing by tweaking the boost comp and throttle mod maps. All does the same thing in the end, I guess. Just interesting to try different approaches.
FS: (Toronto) AEM EMS + AEM UEGO Wideband LuvJuggs Canada Region Private Classifieds 13 04-14-2009 01:42 AM
FS: (Toronto) AEM EMS + AEM UEGO Wideband LuvJuggs Engine/Power/Exhaust 86 04-14-2009 01:41 AM
AEM Uego Problem STI-LOS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 04-04-2008 07:56 PM
AEM uego logging problems mxboy15u Engine Management & Tuning 0 04-28-2007 01:15 PM
FS: Aem tru boost ebc & Aem uego Wideband, both new srt4shizzzle Engine/Power/Exhaust 1 09-26-2006 08:06 PM
