Old 04-16-2005, 05:08 PM   #1
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
Default Wrx Swap Cost ?
Ok so ive been thinkin of buying a wrx motor,ecu,harness how high shoold i go price wise or ok whats a good deal for lets say an 04 with 25k on it thanks guys
99subi is offline   Reply With Quote
Old 04-16-2005, 05:15 PM   #2
2000 RSTi
Member#: 84565
2000 Impreza 2.5 RS
Full USDM STi Swap
A WRX swap should run you about 5-6000 from what you have stated... the only thing you need is a full chasis harness
2000 RSTi is offline   Reply With Quote
Old 04-16-2005, 05:24 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
5-6k with labor you mean
5-6k for a motor is wack
Old 04-16-2005, 11:46 PM   #4
2000 RSTi
Member#: 84565
2000 Impreza 2.5 RS
Full USDM STi Swap
I meant motor + install
Old 04-17-2005, 11:58 AM   #5
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
labor is not ganna be a problem im going to do it myself with my dad (subaru mechanic) so aprox just for the motor ecu and harness. i know i need more than that but im just lookin for the price of this stuff
Old 04-17-2005, 02:19 PM   #6
2000 RSTi
Member#: 84565
2000 Impreza 2.5 RS
Full USDM STi Swap
your looking at about 3 grand or less
Old 04-17-2005, 02:20 PM   #7
2000 RSTi
Member#: 84565
2000 Impreza 2.5 RS
Full USDM STi Swap
but you do need a full chasis harness. If you get the engine harness only you really cant do much with it until you get the chasis harness
Old 04-17-2005, 03:04 PM   #8
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
My entire swap project consisting of an 05’ WRX motor, tranny, r-diff, propeller-shaft, ECU, full harness, and all the odds and ends ended up costing me right at about $5,000 after everything was said and done. This is of course doing all the work yourself….
xcntrk75 is offline   Reply With Quote
Old 04-17-2005, 04:00 PM   #9
simpreza2
Member#: 20381
04 Forester X
93 240sx
Wow thats alot, how many miles on the engine? I just got all the same stuff plus brakes, hubs, struts, springs, x-member and contol arms for 3k. All out of a 04 w/ 18k.
But as for cost all I need now is a hood w/ a hood scoop.
simpreza2 is offline   Reply With Quote
Old 04-17-2005, 06:03 PM   #10
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
...Wow thats alot...
That cost was for the entire install start to finish, not just the drivetrain. You know how they say save an extra 1k for misc expenses? Well I blew that amount before I even had the engine in. For example, went to hook up my airbox - no MAF ($175), went to hook up my p-steering lines – cut at the rack ($199), missing O2 sensors ($200), new up & down-pipe - $350….etc…etc… Plus I was going from an AT to MT so had a large chunk of change wrapped up in pedal-box, clutch master/slave cylinder, hard-lines, shifter trim and knob, etc…etc… Also had my driveshaft and midpipe lengthened... the cost just snowballs
My point here is that there’s more cost associated with the swap then just that of the drivetrain. Especially under my circumstances as I was swapping tranny’s and diff’s as well.
$.02
But well worth it of course
Old 04-17-2005, 07:01 PM   #11
simpreza2
Member#: 20381
04 Forester X
93 240sx
Forgot those...I guess I also need them too.
Old 04-17-2005, 03:23 PM   #12
2000 RSTi
Member#: 84565
2000 Impreza 2.5 RS
Full USDM STi Swap
I wish my STi swap came out to be that much
Old 04-17-2005, 11:43 PM   #13
chrismindless
Member#: 73675
2004 WRX
WR Blue
where are you getting this motor from?? Im shopping now for a motorswap.
chrismindless is offline   Reply With Quote
Old 04-18-2005, 02:30 AM   #14
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
im getting it from this guy i know
Old 04-18-2005, 09:10 AM   #15
chrismindless
Member#: 73675
2004 WRX
WR Blue
ok i see
Old 04-18-2005, 09:16 AM   #16
chrismindless
Member#: 73675
2004 WRX
WR Blue
When you do this swap, how much power do you think you are gonna make outta your wrx setup? Stage 4 type setup?
Old 04-18-2005, 11:57 AM   #17
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
and
are words to live by i find that people that can get swap done for 2k or less (which is possible) tend to have back yards full of parts from their other swaps this keepgin the cost down
Old 05-23-2005, 11:34 PM   #18
AKGC8
Member#: 1305
2000 Impreza
Or they just shop smart(salvaged auctions), my first swap was well under 2 grand, and I hadn't owned a single Subaru before it.
AKGC8 is offline   Reply With Quote
Old 04-18-2005, 12:39 PM   #19
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
i havent decided on hat kind of setup yet i think im goin to get a turbo back exhaust just to start off and then go form there
Old 04-18-2005, 01:59 PM   #20
Randoramma
Member#: 60649
00RS EJ205 swap
I am under 2000 so far for an 02 WRX motor only swap, buy I still need harness and PS assembly. I figure $2500 diy installed and that includes 3"-2.5" exhaust.
Randoramma is offline   Reply With Quote
Old 04-18-2005, 02:39 PM   #21
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
ok for the cost, that really depends on how much you get the motor, wiring, sensors, crossmember and ecu for...then add things like a clutch, lightened flywheel(optional)....and other costs. The range of deals on the motors and what they come with just ranges too much to really give a accurate price.
mine was just over $4k for all the items mentioned above along with all materials needed to do the swap.
Old 04-18-2005, 02:44 PM   #22
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
For that much a WRX swap seems smarter from Aeroism seeing that they swap the full harness and you get a full interior swap as well for 6500 including labor. I'm thinking of going this way simply because finding a full swap and completing will run you almost just as much...
benjaminetanyahoo is offline   Reply With Quote
Old 04-18-2005, 04:02 PM   #23
SubyDuz
Member#: 80432
69 IchhateinAudi
Blutrot
I will be parting out my '03 WRX motor with the following as a set:
UTEC w/map selector, dynoed at 240.7 whp in SLC, UT 4800 ft
PDE up pipe downpipe no cats
PERRIN FMIC, PERRIN intake
Blitz BOV
Tanabe SMR
ECU with Harness
Transmission complete sub frame everything brakes, axles, links
TRUST timing Belt, just installed
Radiator, oil cooler, pretty much everything
motor has 60K and has never pulled a CEL, with over 40K in modified miles, mostly freeway miles.
Let me know if you are interested, I am selling this drop in for who ever wants it all.
SubyDuz is offline   Reply With Quote
Old 05-23-2005, 09:47 PM   #24
greenemac2003
Member#: 38813
1999 RS ej20/stg2 AP
silverthorn
You'll spend around $3-5k if you do all of the work. Make sure you buy a motor from an engine salvage company that gives a warranty. Believe me you won't regret it. Don't ever buy an engine from anyone you don't know even on the forums or you will pay the ultimate price!!!!!!!!!!!!!
greenemac2003 is offline   Reply With Quote
Old 05-26-2005, 11:40 AM   #25
chrismindless
Member#: 73675
2004 WRX
WR Blue
^^^ You mean the salvage was $2000???
Pm me with details, im looking for a salvage now.
2002 Wrx Swap Costs Cky47 Newbies & FAQs 26 05-19-2009 04:13 PM
cost of WRX swap stumblinryan Normally Aspirated with bolt-on Forced Induction Powertrain 6 06-22-2006 12:27 PM
Any idea the cost of a WRX swap totalburnout Subaru Conversions 23 10-30-2004 03:14 PM
Swap Cost? RX7-Killin-Impreza General Community 1 12-31-2002 03:43 AM
Engine Swap Costs andyC Normally Aspirated Powertrain 2 11-29-2000 07:48 PM
