Old 06-08-2005, 12:43 AM   #1
jordylegacy91
Member#: 88180
1991 Legacy Turbo
Red Metal Flake Black
Legacy Turbo Problems
If the Turbo bearings in my turbo were seized from overheating, would this prevent my engine from turning over and firing? and is there anyway to test this to see if this is the problem? I have the EJ22 in my car(1991 Turbo Legacy LS sedan) My engine overheated and blew the water pump, however I know the internals are alright cus I had a compression test done and everything is fine but my car just wont trun over, it backfires and wont start. I think i may have cooked the turbo, is there anyway i can test to see if the turbo still spins and runs??????
jordylegacy91 is offline   Reply With Quote
Old 06-08-2005, 11:26 AM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
The turbo wouldn't prevent you from starting the car. There's something else going on there.
And don't be so sure your engine is fine just because you did a compression test. You could have blown a head gasket, cracked a head, or fried you crank and/or rod bearings.
I had a similar incident last winter when my thermostat froze and the car got hot. It seemed to be fine, but about a month later it started eating oil to the tune of 1wt per week. I knew I had a timebomb on my hands.
I sourced a new block, and did the replacement. When I cracked the case open, I found I had 3 spun crank bearing and all crank and rod bearings were scorched. The through bolts that hold the block together had gotten so hot they turned from golden to black everywhere but on their heads!!!
Old 06-08-2005, 02:23 PM   #3
jordylegacy91
Member#: 88180
1991 Legacy Turbo
Legacy Thanks Matt
Im running out of ideas, I really dont want to replace the whole engine, but its looking like Ill have to do that more and more. If I find the same identical engine of which I have, Will it just bolt in or am I going to need to do some wiring harness changes or anything like that??? Will my stock ECU work also. I have a 91 Legacy Turbo LS Sedan. Thanks for your help but keep the ideas coming. Another question, if the turbo is shot, that means the turbine cant spin, which would cause there to no exhaust escape and no air intake right cus, the engine ran all the way to my house and shut down fine, then the next morning it just wouldnt start. i nursed it home which wasd only like 5 minutes away after I noticed the temp gauge, so I shut the engine down and let it coast in neutral, then started it again when i ran out of momentum, then repeated it that all the way home. I didnt add anything to the engine right away and I didnt touch anything, I shut it down and let it cool by itself. The next morning I put new spark plugs in it and it still wouldnt fire, I had it taklen to a shop where we discovered the water pump was completly shot! The pulley was right snapped off the bearing shaft.this took all the tension off my timing belt. I had a new water pump and timing belt put in, and it still wont start. with everything tightened up it just wont catch, it tries to turn over, but backfires and wont stay running, is there anything in the ECU that would prevent it from running???? Maybe it sensed the overheating and needs to be reset or something, but the more I investigate the more im leaning towards a new engine. Any help would be greatly apprecieated, I want this thing to run sooooooooooo bad. If anybody has a good source on parts too, this would be real nice, I may just need new heads or some other part instead of a whole new engine. Thanks for the help Guys. Keep on driving.
Old 06-23-2005, 07:21 AM   #4
free5ty1e
Member#: 48209
199x Legacy SS EJ22t
'94 White / '91 Silver
Legacy
Definately check legacycentral for this. First of all, 91 Legacy LS's did not come with turbos. Did you add a turbo to your naturally-aspirated EJ22 engine? Or did you mean to say '91 Legacy SS / Sport Sedan...?
Anyway, the legacycentral board has complete info on replacing the timing belt and ensuring you've timed the vehicle correctly. Sounds to me like it could be timing at this point, since you've had to replace the water pump and mess with the belt, which could have jumped many teeth during your drive home.
Backfire during attempt at starting = clue that timing is off. Exhaust valve open at wrong time.
free5ty1e is offline   Reply With Quote
Old 06-23-2005, 12:47 PM   #5
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
are the legacycentral.org boards down? I haven't been able to get to them since tuesday.....
IronMonkeyL255 is offline   Reply With Quote
Old 06-23-2005, 01:07 PM   #6
greg donovan
Member#: 60743
'95 Impreza L
dirty and on jack stands
http://forums.nasioc.com/forums/showthread.php?t=794008
greg donovan is offline   Reply With Quote
Clutch problem or turbo problem? Crow-sti07 Newbies & FAQs 3 07-06-2007 08:17 PM
Help me narrow down my problem please - Air leak or Turbo problem? Justin962 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-08-2006 02:45 PM
Big WRX Turbo problem, Help? amp5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-13-2001 09:14 PM
Help: Please post your Tranny/Turbo problems or lack of problems! Rich L Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-21-2001 04:10 PM
more turbo problems kastle Normally Aspirated Powertrain 13 02-09-2001 09:34 AM
