Welcome to the North American Subaru Impreza Owners Club Wednesday January 28, 2015
Old 07-08-2005, 01:35 PM   #1
bdcz2
Member#: 39790
2004 WRX Sti
Default Calling all engineers, aerodynamicists, gear heads, and know it alls
Ok- you can make this question as complicated or simple as possible, some will decide to immediately flame me for posting a gas related question (I bought a sports car yada yada) and some people will actually offer an answer...
Is there a single speed that, taking into account aerodynamics, engine rpms, and turbo use, will give you the best possible highway mileage...
In other words, if I wanted to go as far as I could on cruise control, where would I set it?
bdcz2 is offline   Reply With Quote
Old 07-08-2005, 01:38 PM   #2
fireball_jones
Member#: 67536
00 AW GM6
And a bunch of parts
Lowest possible speed in your highest possible gear.
fireball_jones is offline   Reply With Quote
Old 07-08-2005, 01:58 PM   #3
Prod
RIP
Member#: 59328
1967 M35A2
duh, winning
Winner.
Throttle makes a huge difference, but this would be a general answer. Basically apply minimum throttle in 5th or 6th, and coast down hills as much as possible.
Prod is offline   Reply With Quote
Old 07-08-2005, 02:27 PM   #4
WRXXXual
Member#: 67784
Now with 100% more
STI short block!
^^^that, or:
You could always just push your car around
WRXXXual is offline   Reply With Quote
Old 07-13-2005, 09:36 AM   #5
REX8
Member#: 24038
Not true...but you'd think it would be...
REX8 is offline   Reply With Quote
Old 07-13-2005, 09:53 AM   #6
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Isn't that the wrong way? In neutral, your engine uses fuel to keep idle speed, but decelerating in gear uses no fuel at all. It's definitely this way on Audis, as it in the '800miles on a tank' episode of Top Gear mentioned earlier.
I don't know what the episode mentioned, but have seen some stuff wrong before.
Let's consider a normally aspirated car for a minute. A lot of times, the increased momentary fuel consumption is associated with Lower (deeper) vacuum. If you look at the vacuum gauge that some normally aspirated cars have, when you suddainly floor it, the vacuum will really go deep. That's how theose "economy" gauges some cars have are hooked up too.
My point is that one of the deepest vaccums is when you use the engine to decelerate.
Even with a turbo car, the same applies. It will not be as bad of a consumption as in wot but right up there.
As far as consumption in idle, that's actually the minimum consumption. With carbureted cars there used to be a separate jet, just for idle. The main emulsion tubes used for normal driving are not even in the same category size wise.
Old 07-13-2005, 01:56 PM   #7
BoneStockTS
Member#: 80670
I know for a fact that BMWs cut the fuel supply when you're coasting, it saves fuel and it helps engine braking.
BoneStockTS is offline   Reply With Quote
Old 07-13-2005, 12:05 PM   #8
sdogg3kgt
Member#: 38397
2002 Lovemachine
I was just going to post that. Too low RPM requires more gas than a little higher RPMs in a lower gear. i.e 25mph in 5th gear instead of 3rd.
sdogg3kgt is offline   Reply With Quote
Old 07-13-2005, 12:13 PM   #9
SCutchins
Member#: 59209
2004 Forester XT
Cayenne Red Pearl
This is absolutely incorrect!! Use the bicycle analogy, pedal in top gear at the slowest speed you can go and you're really cranking on the pedals to keep going. Cranking = energy expenditure which in a car = fuel consumption.
All engines have an RPM range that gives it its maximum efficiency. For a bicycle that might be 90 rpm (the human is the engine) for a lawnmower it might a 3,000, for a jet engine 80,000. For a Subaru engine I seriously doubt it is the "lowest possible speed in your highest possible gear" which would probably be about 1,500 rpm on a flat road. My guess is around 3,000 is more like it.
Now you have to factor in aerodynamics, which means keep it under about 50. Ignore rolling resistance at varying speeds although my old dynamics teacher would disagree.
So my somewhat-educated guess is what someone said before, 40-45 mph in top gear.
SCutchins is offline   Reply With Quote
Old 07-13-2005, 12:47 PM   #10
Airboy
Member#: 72829
2006 WRX
EFR6758
I was expecting some sort of 'proof' after reading that bold statement but all I got was a conclusion based on a 'guess'.
All engines have an RPM range that gives it its maximum efficiency.....My guess is around 3,000 is more like it.
I don't know what the answer is...there are a lot of variables...
Airboy is online now   Reply With Quote
Old 07-13-2005, 02:25 PM   #11
fireball_jones
Member#: 67536
00 AW GM6
Absolutely incorrect? Let me clarify, throw out any RPMs which will cause your car to crank, and it's still your top gear. Anything else would have more rolling resistance. So, for a WRX, it's 2000 RPMs in fifth, or about 52 mph. Almost every street car is geared so that it's lowest normal operating speed in it's highest gear puts it around 55 mph, the most fuel efficient speed. Why do you think a Corvette gets 28 mpg highway?
To use the bicycle analogy, standing on the pedals isn't "going", making full revolutions is. Same as your "lowest speed" in a car... you'll use the least energy if you can turn the crank easily in the highest gear.
Old 07-08-2005, 01:39 PM   #12
Rokkit
Member#: 84181
NASA #530 GTS2
im not an engineer but i can give you my 2 cents...
I think its all relitive as being in the right gear at the right time + Throttle position.... higher the RPM the more fuel the car uses at a set throtle position...
So... low rpm + low throttle = low gas useage... but that = idle lol
I would say speed limit, without cruse control (it over/under compensates ) and go easy on the throttle... DONT BOOST
hah
Rokkit is offline   Reply With Quote
Old 07-08-2005, 01:45 PM   #13
Roy Dietsch
Member#: 88479
91 Mazda Miata
blue yellow
throttle position plays a big role...you can get some crazy lean a/fs while just crusing at low throttle...I would assume something like 40MPH in 5th or 6th
Roy
Roy Dietsch is offline   Reply With Quote
Old 07-08-2005, 01:51 PM   #14
Remnex
Member#: 83790
I actually know the perfect answer to this question, however you may not like the answer.
A good friend of mine told me shortly after I purchased my WRX and started complaining about the gas mileage, that if I couldn't afford to put gas in the gas, I shouldn't have bought it. Period.
You knew this when you bought the car. You stood there with the sticker right in your face. you bought a performance car and you're going to get performance car mileage. Deal with it, or trade it in.
Remnex is offline   Reply With Quote
Old 07-08-2005, 03:13 PM   #15
nate.the.great
Member#: 72031
lol, he never complained about the gas usage. he just asked for what speed he should set the cruise on in order to get maximum mpg. please read before you post.
nate.the.great is offline   Reply With Quote
Old 07-08-2005, 02:02 PM   #16
cstratton04
Member#: 84489
2005 Toyota Corolla
2005 CBR600rr
It should say in your manual the best speed for gas mileage... i think it is 55 mph as it is the best rpm range (low, but not too low) in your highest gear and air resistance isn't too high.
Renmex - you answer wasn't really helpfull. I knew the gas mileage of the car when i bought it, but i still enjoy getting the best mpg i can when not driving hard.
cstratton04 is offline   Reply With Quote
Old 07-08-2005, 02:11 PM   #17
hyperlitenerd
Member#: 86504
1994 Rx-7
Green
there is a episode in top gear (british car show) the guy goes 800 miles in a desiel audi, in short he says take as much stuff that you do not need out of the car, dead bodies, chairs on the roof, etc. If you see a hill comming, gain speed before it, and coast up it, never brake, use no electronics, no ac no heater, nothing. Keep the car in the highest gear possible at the loswet acceptable speed, aka slow lane. you just think really hard about driving slow.
hyperlitenerd is offline   Reply With Quote
Old 07-08-2005, 02:23 PM   #18
cefoskey
Member#: 83961
2014 A5 S-Line 6MT
'06 Triumph D675
1.) Take the box kite wing off the STI.
2.) Stay out of boost
3.) Get up to speed slowly and drive in a gear higher than you usually would at the same speed.
But really, you're not going to change your driving behavior enough to really affect the overall mileage.
cefoskey is offline   Reply With Quote
Old 07-08-2005, 02:43 PM   #19
BlackfeetVI
Member#: 40567
RIP Worcester 6
St Florian protect us all
Just get the JDM mad tyte pedal car conversion
On a side note, I got 29.5mpg crusing at 75 from Minneapolis to Milwaukee, and I think if I'd have taken it down to 70 or so it'd have gone up another mile or so per gallon. I don't think it'll get too much better, I'll take the higher cruise speed and trade off a little economy.
BlackfeetVI is offline   Reply With Quote
Old 07-08-2005, 03:05 PM   #20
kilroy
Member#: 75628
2005 Legacy GT ltd
regal blue
I would have to say the gentlest rate of acceleration while staying out of boost will give you the best mileage. I tried this for a painful and nerve-wracking tank of gas in my legacyGT while watching the instanteneous mpg display. When decelerating, my mpg shot way up and just inching up on the gas while accelerating kept the fluctuation in mpg fairly moderate. I averaged 25.6mpg for the entire tank of gas. I am usually around 20-21mpg. I won't do it again though - I did not buy the car to putter around.
kilroy is offline   Reply With Quote
Old 07-08-2005, 05:20 PM   #21
Prod
RIP
Member#: 59328
1967 M35A2
duh, winning
I did the same exact thing in my LGT, and came to the same conclusion. I'll pay for 20 mpg vs 25 for the fun factor.
Old 07-12-2005, 11:47 PM   #22
hwy61
Member#: 87950
2005 STI
Gone....Somewhere in MS
Since the cruise control won't engage until the vehicle speed reaches 25 mph anything under that is ruled out. The faster you go the more resistance in everything, tires, wind, engine friction, transmission friction, etc. The more resistance, the less mpg. So I suggest 25 mph in the lowest numerical gear ratio the engine will smoothly move the car. Lugging along with the engine struggling to keep up a 25 mph speed probably isn't as good as a gear where the engine can move the car steadily and w/out extreme effort.
Just stick me in the gear head, know it all section, my wife does. hwy61
hwy61 is offline   Reply With Quote
Old 07-08-2005, 03:14 PM   #23
infantsam
Member#: 51280
1987 E30
BEAT-HER
The most efficient driving speed is about 40-45 MPH. This is the point where the exponentially growing aerodynamic drag begins to require much larger power to overcome and thus hurting fuel economy. Tire inflation, alignment settings, and most importantly driving style will affect your ultimate mileage but the maximum efficiency is not too hard to calculate. Since you can't drive 45 everywhere you go then increasing your driving efficiency i sa good way to save gas. 65 vs 75 will make a difference - accelerating smoothly and coasting to a stop instead of running up and slamming the brakes will also help. Tire inflation as mentioned can cost as much as 10 percent. Rid your trunk of any cast iron that is just bouncing around also.
With only a small amount of attention I'd think that most drivers could save at least 10 percent - maybe more if you are a tailgating, on the gas, on the brake, always hitting it at the stop light kind of driver.
infantsam is offline   Reply With Quote
Old 07-08-2005, 03:38 PM   #24
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
I believe the mileage ratings on the sticker are averaged at 62 or 65 mph in the highest gear.
Car vs. Driver is offline   Reply With Quote
Old 07-08-2005, 03:49 PM   #25
8Complex
Member#: 922
04 FXT
Red
Yes, I believe it is torque peak in your highest gear. Try some aerodynamic mods if you want to get it even higher (read: less drag/downforce).
8Complex is offline   Reply With Quote
Ok, I just pulled a muscle in my brain. OT astrophysicists and know-it-alls, hear me! Asinine Off-Topic 91 04-29-2009 09:54 PM
calling all electrical know-it-alls... USB charging question WRXVT Off-Topic 8 04-07-2008 05:41 PM
calling all know-it-alls gf8rallywagon Normally Aspirated Powertrain 8 12-17-2005 07:43 PM
Question for the server-class hardware know-it-alls Bottom Feeder Off-Topic 7 05-16-2005 09:16 AM
Question for the OT credit rating know-it-alls Corn-Picker Off-Topic 3 05-31-2004 11:44 AM
