Old 07-10-2005, 08:13 AM   #1
SPESHAL
Member#: 20401
Default Anyone estimate what offset these are?
Looking to get a similar look to these as far as offset is concerned. Can anyone estimate what offset the below rims would be? They seem to sit perfectly as far as looks go, and similarly dont appear that they would scrape.
http://www.jtuned.com/media/photobox...&box=&shownew=
Thanks!
SPESHAL is offline   Reply With Quote
Old 07-10-2005, 06:49 PM   #2
subieworx
Member#: 47769
Considering those are VR wheels I would say probably 46, could be wrong thgouh. It's difficult to tell without knowing the size.
subieworx is offline   Reply With Quote
Old 07-10-2005, 09:38 PM   #3
sheizen
Member#: 82737
04 STI
could be 44
sheizen is offline   Reply With Quote
Old 07-11-2005, 12:20 AM   #4
SPESHAL
Member#: 20401
Assume they are 18 x 8, the CE28s come in 38 and 44, so 44 would prob be the goer?
Old 07-11-2005, 07:26 PM   #5
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
Look alot like Prodrive P1/Rota Tarmac. Those come in Suby-friendly +48 offset, why not get those instead?
Samirr76 is offline   Reply With Quote
Old 07-12-2005, 01:08 AM   #6
SPESHAL
Member#: 20401
Because I like CE28's.
Old 07-12-2005, 09:43 AM   #7
subieworx
Member#: 47769
I agree. I want the black spoke/polished lip version. I have Tarmac2's right now and they really look quite different than the CE28n's.
Old 07-12-2005, 01:13 AM   #8
dubRexn
Member#: 16100
GD
I believe that car is the top secret car on the boards here, you can search for ti and i am sure he lists his mods
dubRexn is offline   Reply With Quote
Old 07-12-2005, 09:45 AM   #9
SPESHAL
Member#: 20401
What do you mean? ti?
Old 07-12-2005, 10:06 AM   #10
jweiss
Member#: 31636
2005 STi & '82 911
CGM & rosewood
Hi -
this table lists all available sizes and offsets for the CE28N.
I'm going to get LE28N, 8.5x17 +50, 114.3 bolt pattern, 255-40-17, gun metal with polished lip. You can run a lower offset if you don't want/need 255 width.
If you have an STi, the entries in the table with a square after them will clear the Brembos.
Cheers,
Jeff
jweiss is offline   Reply With Quote
Old 07-13-2005, 03:54 PM   #11
dubRexn
Member#: 16100
GD
I can't type, it meant "it"
anyway, his name on the boards is superflysteiny so do a search or pm him and i am sure he'd tell you
Old 07-12-2005, 01:03 PM   #12
ommmjido
Member#: 35746
08 White GRB
Wrong Fitment Crew #001
either 44 or 50
ommmjido is offline   Reply With Quote
Old 07-15-2005, 02:04 AM   #13
SPESHAL
Member#: 20401
Thanks mate, but it isn't the same car - http://forums.nasioc.com/forums/showthread.php?t=797985
Old 07-15-2005, 02:24 AM   #14
ErrolR1919
Member#: 11212
They're 18" Volks so I'm 99% positive the offset is +44. I don't think the +50 clear the brembos.
ErrolR1919 is offline   Reply With Quote
Old 07-15-2005, 05:36 AM   #15
ommmjido
Member#: 35746
08 White GRB
the 18x8.5 +50 TE37 clears Brembos. not sure if that goes for the CE28s as well.
Old 07-15-2005, 09:56 AM   #16
jweiss
Member#: 31636
2005 STi & '82 911
CGM & rosewood
Yes, the CE28N in a +47 and +50 clears the Brembos as well (in a 17, so an 18 should be no problem). You can also do a +44 offset in 18x8.5, but with that I think you will be limited to stock tire width (225). At least that's all I've seen people run. The lower offsets push the wheel out toward the fender, whereas the higher offset pushes it toward the strut. If you want wide tires, you want to optimize the use of space between the two. It appears that in the 8.5x17 and 8.5x18 sizes this is achieved with a +50 offset. With that offset, you should be able to run widths between 225-255 (adjusting the sidewall series appropriately to maintain some semblance of stock tire diameter of 25.0")
http://forums.nasioc.com/forums/showthread.php?t=801351
http://forums.nasioc.com/forums/show...ighlight=ce28n
Old 08-03-2005, 01:34 AM   #17
ErrolR1919
Member#: 11212
I think you guys are forgetting that is a 2004 STi. The +50 offset CE28's won't clear the calipers on the 04. Refer to this thread for more info: Wheels that fir the STi
I'm betting they're a +44...
Anyone know what wheels these are?... JCity Member's Car Gallery 6 07-01-2007 01:10 PM
Anyone know what wheels these are? sublimeplaid Tire & Wheel 6 03-07-2007 01:05 AM
Anyone know what fogs these are? Mikeyrad Electrical & Lighting 4 08-11-2005 11:57 PM
Anyone know what wheels these are? Speedadickt Member's Car Gallery 9 01-20-2005 05:15 PM
anyone know what offset these rotas are? imprezive one Brakes, Steering & Suspension 0 10-23-2002 11:25 AM
