Old 07-15-2005, 07:15 PM   #1
o2sys
Member#: 43842
200? WRX STI
Default Intercooler tilting for lower IC temps!
o2sys is offline   Reply With Quote
Old 07-15-2005, 07:47 PM   #2
toke513
Member#: 16272
2004 WRX Wagon
interesting to say the least. Although I think Im going to pass. I bet an STI scoop with splitter will do the same thing. Although its not free
toke513 is offline   Reply With Quote
Old 07-15-2005, 09:13 PM   #3
WRXRgr
Member#: 54942
2004 WRX
I'd like to see pics...can't imagine how much of a tilt the IC-TB would allow.
WRXRgr is offline   Reply With Quote
Old 07-15-2005, 10:04 PM   #4
King Of Imports
Vendor
Member#: 64590
pics!
King Of Imports is offline   Reply With Quote
Old 07-16-2005, 12:14 PM   #5
djplayboy
Member#: 72933
MY02 WRX Wagon
+555 on the pics
djplayboy is offline   Reply With Quote
Old 07-18-2005, 04:11 PM   #6
makanai
Member#: 65277
2004 WRX Wagon
Platinum Silver
Yup, useless without pics.
makanai is offline   Reply With Quote
Old 07-18-2005, 05:39 PM   #7
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
I'm having a hard time seeing how this would make any difference. How would the amount of airflow change?
"another option you could add is if you want to keep factory seal around IC to scoop you can raise hood by 1/2 inch. All you need is 4 washers or so per bolt on hinge, 4 bolts that are 3/8 inch longer than stock, and you are done"
Um, what? Raise the whole hood so there is a big gap around the edges?
Mike Wevrick is offline   Reply With Quote
Old 07-18-2005, 05:41 PM   #8
WRXRgr
Member#: 54942
2004 WRX
Blarg claims temp data, so who knows...maybe it puts the IC a bit more cross-ways to the air entry angle, and slows it down, letting it pull more heat?
AFA the hood-raising, that sounds unsat...
Old 07-18-2005, 05:47 PM   #9
vapore0n
Member#: 21356
2010 BMW 335i
my guess behind this is that he is making more space below the IC, making air flow faster, thus better cooling. Also the angle of attack is different now, maybe its really more efficient.
Raising the hood is not though. IBHoodFlysOpen
vapore0n is online now   Reply With Quote
Old 07-18-2005, 06:02 PM   #10
WRXedUSA
Member#: 26833
'07 Bugatti Veyron
'03 Chevy Silverado
Dumb.
Why streach you IC hosing? Trimming the shroud?? Dumb, just dumb.
The hoodscoop is only going to take in X volume of air anyways, so what good is it? It's not like you could apply the 'river theory' and say the air that has gone through the fins is flowed better, because there isnt a baffle or ducting removing the 'used air' from the back side of the IC, thus increasing the volume on the air coming in.
What a waste of time.
WRXedUSA is offline   Reply With Quote
Old 07-27-2013, 10:09 AM   #11
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Doing this on my FXT, TMIC is way down.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 07-27-2013, 10:21 AM   #12
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
Awesome cool story. Thanks for bumping an 8 year old thread. This also doesn't sound like it would actually do anything, but more power to you, I guess.
Loyale93 is online now   Reply With Quote
Intercooler Tilted CGuerra54 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-10-2008 02:44 AM
Data points: impact of IC water spray on IC temps scooterforever Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-11-2005 03:43 PM
Which gauge to use for IC temp? jikhead Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 01-06-2004 03:04 PM
Post IC temps ataac_flat04 Engine Management & Tuning 13 08-10-2003 06:57 PM
Anyone measured IC temps? I have! GDB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-23-2002 07:57 PM
