Old 08-01-2005, 11:46 PM   #1
SubieSky
Member#: 86022
Legacy Need Help In Next Mod
HI:
HERE IS WHAT I HAVE SO FAR:
8000K HID (HEADLIGHT AND FOG LIGHT)
CARBON FIBER EYELID
DEBADGED
PAINTED FLAT BLACK RIMS
JL AUDIO SUB
BOSTON ACCOUSTIC AMP
LED DOME LIGHT (BLUE)
LED WHITE DOME LIGHT
FACTORY TINT
PARTS COMING IN THE MAIL:
PERRIN SHORT RAM INTAKE
BOSAL UP-PIPE
JUST A QUESTION FOR EVERYONE, WOULD MY NEXT STEP BE A DOWN PIPE THEN THE EXHAUST? OR FRONT AND REAR SWAY BARS TO MAKE TO THE ON BETTER CORNERING?
EVERYONE SAID THAT I SHOULD GET RIMS AND STUFF, BUT I WANT TO KEEP MY CAR AS STOCK ON THE OUTSIDE LOOKING AS POSSIBLE.
PLEASE HELP!!!
THANKS
SubieSky is offline   Reply With Quote
Old 08-01-2005, 11:47 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Sway Bar
fibuz is offline   Reply With Quote
Old 08-01-2005, 11:53 PM   #3
EastsideLegacy
Member#: 58806
1998 RIP Legacy2.5GT
2.2L legacy wagon
Yea i 2nd the sway because it was my best mod yet..
EastsideLegacy is offline   Reply With Quote
Old 08-02-2005, 12:07 AM   #4
SubieSky
Member#: 86022
question:
what does the sway bar do? and should i get front and rear?
thanks
Old 08-02-2005, 12:19 AM   #5
EastsideLegacy
Member#: 58806
2.2L legacy wagon
Im pretty sure it reduces over/under steer ( not sure whats what ) and less body roll, and this makes it feel more solid round turns .... correct me if im wrong or if I neglected to mention somthing.
Also ive herd that the front swaybar is a overkill. Unless your going into auto x or somthing of that nature.
Old 08-02-2005, 12:26 AM   #6
MitchGT
Member#: 73684
2012 4Runner
A larger rear swaybar will reduce understeer(the front end of your car pushing through turns). From what I've read, increasing the diameter of the front sway bar will offset the improvements of the new rear sb.
MitchGT is offline   Reply With Quote
Old 08-02-2005, 01:05 AM   #7
SubieSky
Member#: 86022
so front sway bar is not necessary, right? Just the rear sway bar?
thanks
Old 08-02-2005, 02:43 AM   #8
Kraziken
Member#: 38629
1999 Legacy GT (STI)
I think both help.
I increased the front swaybar from 20mm to 22mm. As a test, I did the front swaybar first. It helped reduced body roll.
I then installed the rear adjustible swaybar, It's currently set to 20mm. It was a much more dramatic improvement.
Kraziken is offline   Reply With Quote
Old 08-02-2005, 10:09 AM   #9
froggert
Member#: 768
OB, legacy, 911,
ram 1500, 1098s, m620
tires
froggert is offline   Reply With Quote
Old 08-02-2005, 11:49 AM   #10
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
Originally Posted by froggert
tires
x2 (345)
iamrazor is offline   Reply With Quote
Old 08-02-2005, 11:57 AM   #11
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
Frist off turn the caps lock off
Second what car are we talking about here?
bhall is offline   Reply With Quote
Old 08-02-2005, 10:32 AM   #12
ADirtyLegacy
Member#: 77394
05 LGT
which swaybar you choose is dependant on your driving style. front bar will degrade rear lateral force and a rear bar will degrade the front lateral force. if you want to feel the car on corner entry, front bar is the way to go. if you want to REALLY feel the car rotate through the middle and on corner exit, then rear sway bar. too big of a rear sway bar for your driving style can induce unwanted oversteer.
my personal thoughts are if you can't get into the corner, how are you gonna get off the corner?
Kenda
ADirtyLegacy is offline   Reply With Quote
Old 08-02-2005, 11:31 AM   #13
Kraziken
Member#: 38629
My goals were to maintain the car balance and decrease body roll.
If you upgrade both front and rear at the same time I think you can achieve that.
I did feel some understeer with just the larger front swaybar, but not a great amount. And I pushed my car pretty hard into some corners when I first got the front swaybar installed.
I believe if we were talking just FWD or just RWD the oversteer/understeer equation becomes much greater. I just didn't notice that big of a change in either direction. I just noticed a significant reduction in body roll.
I've been meaning to set my rear sway bar to the max 22mm to see if there is a change in feel, but I like the way the car handles now, so I've been too lazy to experiment.
Need help with next exterior mod. AXA Interior & Exterior Modification 5 09-26-2003 01:43 PM
Need Help With Next Phase of Mods jetguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-31-2003 01:53 PM
Need help on next mod choice. jonmacs22 Mid Atlantic Impreza Club -- MAIC 10 04-03-2003 01:43 PM
Need help choosing next mod juztin180 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 11-16-2002 01:02 AM
visiting I-clubber needs HELP in VT. MODS, HELP!!!! Qbushido New England Impreza Club Forum -- NESIC 4 08-05-2002 07:22 PM
