Old 08-28-2005, 05:46 PM   #1
chevelle100
Member#: 94521
Default Turbo kits?
What are the best known turbo kits for the 1.8 impreza? I ran a search on google and found a couple but was curious what's reccomended. Thanks.
chevelle100 is offline   Reply With Quote
Old 08-28-2005, 07:22 PM   #2
Tats
Member#: 5692
WTF? YES! I am
better than you!
Let us know what you found and we'll tell you if they're any good.
Turbokits.com= WAYYYYY BAD.
Tats is offline   Reply With Quote
Old 08-28-2005, 10:54 PM   #3
mybluesubi
Member#: 53526
1997 Impreza
black
well that rules out one place NOT to look
mybluesubi is offline   Reply With Quote
Old 08-28-2005, 11:02 PM   #4
leondal
Member#: 43114
1998 Legacy GT Turbo
Green
You might want to look into putting the WRX turbo setup on
your engine.
I good place to look where this has been done before:
http://www.uniquemotorsports.com
They also sell parts for you to do it to your car!
leondal is offline   Reply With Quote
Old 08-28-2005, 11:37 PM   #5
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
your engine.
If you go this route, my username in AFI. You might be able to find a few things of use. I have that setup and have been running 7-8psi daily for over 20k miles. Compression still perfect on all 4. Still up there with EVOs and STis and even a 2006 Corvette last week. And ditto Chad's site. I got about 90% of the information I needed from there.
-Brett
ExecNav is offline   Reply With Quote
Old 08-28-2005, 11:57 PM   #6
chevelle100
Member#: 94521
What's wrong with turbokits?
Old 08-29-2005, 10:40 PM   #7
Tats
Member#: 5692
WTF? YES! I am
better than you!
Too many things to list.
Do a search in AFI for turbokits.com
Old 08-28-2005, 11:58 PM   #8
chevelle100
Member#: 94521
http://www.streetlevelperformance.co...bo%20Kits.html. Of course I'd probably use a computer to modify the boost to 10-12.
Old 08-29-2005, 12:13 AM   #9
chevelle100
Member#: 94521
Old 08-29-2005, 10:57 PM   #10
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Those are both turbokits.com kits- JUNK. Stick with AVO or FAT.
Drac9 is offline   Reply With Quote
Old 08-29-2005, 11:04 PM   #11
EVOs_Master
Member#: 94470
Cert Subaru Tech.
2004 PSM STI
make your own, i did and got away with it for only $1,000. I was running 8 psi for around 4,000 miles with no problems on a 2.5rs. I fabricated everything, it is quite simple.
EVOs_Master is offline   Reply With Quote
Old 08-29-2005, 11:56 PM   #12
chevelle100
Member#: 94521
What are the websites for avo and fat?
Old 08-30-2005, 12:05 AM   #13
chevelle100
Member#: 94521
Old 08-30-2005, 01:03 PM   #14
Tats
Member#: 5692
WTF? YES! I am
better than you!
Yup..thats one of the really crappy ones.
Best bet:
www.rallitek.com for AVO Kit or www.forcedairtech.com for the FAT kits.
You get what you pay for.
Old 08-30-2005, 06:08 PM   #15
chevelle100
Member#: 94521
Can you crank the boost up to 10-12?
Old 08-30-2005, 09:05 PM   #16
Tats
Member#: 5692
WTF? YES! I am
better than you!
Not if you want it to last long.
Correction: I've heard of it being done but you need a REALLY GOOD tune on yout EM.
Old 08-30-2005, 10:40 PM   #17
chevelle100
Member#: 94521
Maybe run daily at five and crank it up when I see what it can do in the quarter.
Old 08-31-2005, 02:12 AM   #18
Drac9
Member#: 9861
Without several thousand dollars more in mods you wont be "cranking" anything up.
Old 08-30-2005, 06:16 PM   #19
chevelle100
Member#: 94521
http://ludespeedperformance.tripod.c...ts/stage1.html
Also, what about these ludespeed kits?
Old 08-30-2005, 07:29 PM   #20
Drac9
Member#: 9861
Ludespeed no longer makes RS turbo kits.
Old 08-30-2005, 07:37 PM   #21
chevelle100
Member#: 94521
That's too bad. Can I just use the fat stage one kit and not use an intercooler?
Old 08-30-2005, 08:29 PM   #22
Drac9
Member#: 9861
I have an intercooler that should work for that kit for sale for $350. I would recommend against a non-intercooled setup.
Old 08-30-2005, 08:38 PM   #23
chevelle100
Member#: 94521
I was thinking maybe I'd start non intercooled and change over in the future. By the way, this would be for a 2.2.
Old 08-31-2005, 02:36 AM   #24
godfather2112
Papi Chulo
Member#: 53794
2005 BMW M3 - 6spd
2007 Denali Land Yacht
ej20g swap.
godfather2112 is offline   Reply With Quote
Old 08-31-2005, 12:17 PM   #25
chevelle100
Member#: 94521
Why couldnt I bring the boost up? Just a matter of drivetrain strength? I am not going to do the swap. By the time you're done, you may have a better outcome but it will cost you twice as much. I don't have an engine hoist and I do not want to deal with all the wiring.
Ft: So Cal: Gt35r .82 Ar Turbo Kit For Stock Location Turbo Kit EvO KiLLeR 2005 Engine/Power/Exhaust 4 06-02-2008 01:21 PM
AVO Turbo Kit vs TSI Turbo Kit Mechkiller31st Normally Aspirated with bolt-on Forced Induction Powertrain 6 12-01-2004 07:02 PM
Wanted: Turbo Kits or Turbo Kit Parts Acejam2k Private 'Wanted' Classifieds 1 01-05-2004 01:34 PM
Attn:Legacy turbo kit drivers, didnt someone do the kit w/out changing the water pump scootr Normally Aspirated with bolt-on Forced Induction Powertrain 5 01-03-2004 03:56 PM
pic of old turbo kit vs. new custom kit zaidallas Member's Car Gallery 15 06-12-2001 05:56 PM
