Old 08-31-2005, 02:42 PM   #1
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Default SOHC DBW Intake manifold..can you guess?
I have this manifold in my possession. I have no idea what Subaru it is from, other than it is JDM, and drive-by-wire.
Can someone identify this piece or offer details?
Thanks for your time!
S.
The intake in question looks like this one:
http://www.glamisdunes.com/invision/...opic=48338&hl=
n2xlr8n is offline   Reply With Quote
Old 08-31-2005, 02:44 PM   #2
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
It's the 05 SOHC N/A intake. I drooled over fitting that thing to my 00 RS. Nothing swaps easily unfortunately. The fuel injectors, rails, TB, and evel the coil pack are different.
HamFist is offline   Reply With Quote
Old 08-31-2005, 02:57 PM   #3
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
You are my new friend.
Is it USDM, as well? Even better.
I'll be using it on my EJ257 build up, providing it flows like I've heard...I'll be testing it next week.
Thank you very much.
S.
Old 08-31-2005, 11:11 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
If you get some flow bench numbers please come back and share them with the rest of us. Not that I have anything to compare them to really, but it would be good to see. I haven't actively pursued it, but I plan to get a '97-99 DOHC intake manifold flow tested, then get perhaps get it ExtrudeHoned and flow test it again.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 09-01-2005, 12:34 AM   #5
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Pat Olsen
I will surely share the data with you guys.
FWIW, save your money. Extrude honing did nothing for the imbalance inherent in my 02 WRX intake manifold...just made it flow more air.
I agree: If you can find one of these intakes, buy it...as a matter of fact buy me another one, too.
Thanks for the input folks.
S.
Old 08-31-2005, 09:40 PM   #6
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
If you figure out how to get it to swap onto an RS, lemme know. I've heard the same thing about how it flows . Notice how the runners are flipped around on one side? As the motor breathes, it creates a perfect swirl pattern in the intake manifold. That's a very good thing.
Old 08-31-2005, 10:10 PM   #7
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
S.
That manifold was first used on JDM N/A EJ20's and EJ25's. Its now on the 05/06 USDM N/A motors as mentioned.
Old 08-31-2005, 11:02 PM   #8
redwagon
Member#: 2181
2008 SpecB
You guys might want to snap these up while you can. The '06 JDM version looks to have TGVs in it...
Linky
redwagon is offline   Reply With Quote
Old 09-01-2005, 12:38 AM   #9
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Linky
That's my girl.
You guys have amazing resources.
From what I've seen, there are two models of this intake: The one in my posession has no TGV-looking obstructions, and the "other" looks identical, but it has TGV-less housings (three piece intake).
S.
Old 09-01-2005, 05:19 PM   #10
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Update:
I'm not betraying confidences (who & where), because there are few Subaru racers that will share info; Even so, I feel like it's important to give back to the community.
The quote was "The single best flowing manifold out there for a Subaru"
I'm not bothering to flow this manifold. I'm putting it straight on my engine. For those that know me, that should give you an idea.
HTH
S.
Old 09-01-2005, 09:26 PM   #11
redwagon
Member#: 2181
2008 SpecB
Please be sure and report back as to how the install went. It's really hard to see from photos if a normal TB will bolt straight up, if there are enough vacuum ports, if the fuel rails will bolt on, will it interfere with a GC hood, yadda yadda yadda.
Thanks.
<-- also interested in this upgrade.
Old 09-01-2005, 10:59 PM   #12
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Thanks.
I apologize if I've mislead you guys; my project is a 2002 WRX with a EJ257 engine.
-A WRX/STi TB will not bolt right up; an adapter plate must be fabbed, or use smaller bolts and relocate the IAS slot.
-I'm using a vacuum pump. See
http://forums.nasioc.com/forums/show...hlight=Goodbye
-I'm using a custom fuel system with 1000 cc/min injectors, so I'm no help there either.
-It's going to be close on the hood clearance, but I think it will work, because I have a FMIC, and I'm using the CF reverse cowl.
If you guys are still interested, I'll report back the bottom end is finished (waiting on bearings from Folger).
Thanks for the help, folks!
S.
Old 09-01-2005, 06:35 PM   #13
FalconRS
Member#: 92913
2005 2.5RS Wagon
Crystal Grey Metallic
Would this be the intake manifold that came on my 05 RS stock?
FalconRS is offline   Reply With Quote
Old 09-01-2005, 11:00 PM   #14
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Can't say for sure without a pic, but I doubt it.
S.
Old 09-01-2005, 11:44 PM   #15
02Toyowrx
Member#: 56520
Which model has the TGV's, I need a shorter manifold
02Toyowrx is offline   Reply With Quote
Old 09-02-2005, 04:05 AM   #16
redwagon
Member#: 2181
2008 SpecB
Bloody turbo guys grappin' on our tireds.... :fume:
So you're saying that the holy grail, the 'best flowing Subie manifold evAr' is a dohc item? Too bad. I wonder how different the '05 RS one is. It sure looks similar in terms of the runner diameter...
The only n/a intake manifolds I've seen with TGVs are the Japanese versions that haven't made it to the US. That PZEV Legacy had them, so does the current Outback 2.5i mill.
Old 09-02-2005, 05:30 AM   #17
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I can't tell from the pics in the dune buggy... How is the bolt pattern oriented where the manifold bolts to the heads? Is it like one of the ones in my awesome attached drawing?
Pat
Old 09-02-2005, 08:17 AM   #18
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Pat
I didn't notice..it's left the building at present.
Are you saying that late model SOHC bolt pattern is offset?
Oh well, more work.
S.
Old 09-02-2005, 11:41 AM   #19
Crawford Performance
Member#: 42075
The SOHC, WRX and US STI all have the offset center bolts.
If you want to do a comparison, the cheapest way is to buy manifold gaskets for the manifolds in question and lay them on top of each other.
www.crawfordperformance.com
Crawford Performance is offline   Reply With Quote
Old 09-02-2005, 08:14 AM   #20
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
No. It is a SOHC N/A item.
Old 09-02-2005, 06:55 AM   #21
redwagon
Member#: 2181
2008 SpecB
^^^ You can see quite clearly in the second photo that the outside bolts are offset toward the block. That's a SOHC manifold and I'd bet it's the '05 RS item.
But Pat, would a new WRX or USDM STi manifold not fit your dohc heads?
Old 09-02-2005, 01:35 PM   #22
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I did what Quirt is talking about at one point.
The short version is all Ej20G and Ej20k and Ej25 engines throught 1998 had the inline bolt pattern.
From '99 on, the Ej205, Ej207, and EJ25's, both SOHC and DOHC, all share the same offest bolt pattern...
Old 09-03-2005, 12:23 AM   #23
redwagon
Member#: 2181
2008 SpecB
^^^^ Ohhhhh, that explains everything. :notworthy: :thumbsup:
Old 09-03-2005, 02:43 AM   #24
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
I looked pretty hard at swapping this onto my 00 RS. But damn, what a pain! New fuel rails, injectors, TB adapter plate, relocate the coil and wires....ungh! No. I'd love to, but I'll wait for someone else to try that one. I'm lucky the E85 trick worked as good as it did.
Old 09-03-2005, 03:58 AM   #25
zzyzx
Member#: 815
2013 Boss 302 White
2008 S2000 CR ABP
This is the stock manifold off of an '05 RS.
It's for SOHC and it won't bolt to a DOHC head.
The intake runners are large, and it'll be to be match to the heads.
The TB bolt pattern is different from a manual TB.
The fuel rail is different that previous RSs.
It uses WRX style injectors... so you can use WRX injectors.
zzyzx is offline   Reply With Quote
WTB: TGV's (side or top), DBW Throttle Body, DBW Intake Manifold mattminer NESIC Private Classifieds 4 03-13-2010 05:43 PM
F/S Wrinkle red STI DBW intake manifold ronzogonzo Engine/Power/Exhaust 0 09-19-2008 01:00 PM
WTB 2.5STI DBW Intake Manifold sleepersy Private 'Wanted' Classifieds 0 09-09-2008 12:59 PM
PE 800cc STi injectors, STI dbw intake manifold LiquidForce Engine/Power/Exhaust 11 08-26-2008 01:59 PM
SoCal: STi DBW Intake Manifold synernut Engine/Power/Exhaust 29 12-04-2007 09:55 AM
