#1 |
Member#: 45273
Vehicle:2002 Impreza 2.5 RS Aspen White |
what is the detonation sequence, if you are facing the car. 2.5rs my02
#2 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
Vehicle:98 2.5 RS 04 WRX |
Front left, Rear Right
Then Front Right, Rear Left Same on all the 4 Cyl Boxers I think that translates to 1-3, 2-4 |
#3 |
Member#: 77677
Vehicle:1997 OBS '07 KLR 650 |
correct, and FYI, detonation is a bad thing. You mean ignition.
#4 |
Member#: 90156
Vehicle:1986 Syncro Vanaru 07 SV650 |
The front is the part that is towards you and from this perspective layout is :
Passenger side seat------------------------------Driver side seat 3---4 1---2 ------------Front of car---------- ![]() |
#5 |
That animation from Howstuffworks.com is alittle misleading specialev
From Cars101.com http://www.cars101.com/subaru/imprez...tml#mechanical Firing order 1-3-2-4 And also from another site. http://autorepair.about.com/library/...bl-fo-0492.htm I could have sworn that it did not fire two pistons on the same side at the same time though. Seems unbalanced to me somehow. |
#6 |
Member#: 11808
Two pistons do not fire on the same side at the same time. Remember this is a four cycle engine so each piston only fires on each second crankshaft revolution.
#7 |
Member#: 45273
thank you guys
| Thread Tools | |
| Display Modes | |
| SOHC HEAD torque sequence | DJIMPREZA | Normally Aspirated with bolt-on Forced Induction Powertrain | 5 | 09-20-2002 09:54 PM |
| up pipe torque sequence? | Danny | Factory 2.0L Turbo Powertrain | 2 | 09-15-2002 12:08 AM |
| What is the sequence? | nekard | Factory 2.0L Turbo Powertrain | 1 | 09-14-2002 11:48 AM |
| retiring ! my fave RS sequence | patr | Vancouver Impreza Club Forum -- VIC | 6 | 05-14-2001 02:22 PM |
| Correct Brake Bleed Sequence | awu | Brakes, Steering & Suspension | 4 | 10-28-2000 07:39 PM |
