#1 |
Member#: 2353
Vehicle:98' LegOver GT dark whiteish pearly red |
ok, so it was raining hard last night and i thought i'd be kinda cool to try a little drifting(fake), but the only thing is i cant do it
. how the hell do peolpe do this crazy stunts. i've seen em done and read about em but for some reason it looks easier said than done. any addvice would help (yeah i know i suck, gotta learn sometime ) |
#2 |
Member#: 6982
Vehicle:2001 Legover 04 forester xt |
Adjusting your air pressure will help get the tail loose, if thats what you want. Run around 40psi up front and 30 in the rear. That should help get you nice and sloppy.
You just need to learn how your car reacts. Go to a big parking lot and play around(off hours of course!) Don't use the e-brake! |
#3 |
Member#: 2353
oh "not using the e-barkes" might have help
, welp i hope it rains agian![]() |
#4 |
Member#: 249
Vehicle:05 FXT psm 06 E55 |
wait until it snows!
#5 |
Member#: 3931
Vehicle:WRX, Ninja, RX-7 Legacy, Fiat 850 |
The best way to drift without any preperation (brake adjustment, tires, etc) is a quick tug on the e-brake. You can do it on dry pavement going 30mph if your timing gets good enough. The important thing is to use the e-brake to start the slide, then take the brake off (don't even let go of the button, hold it in... pull the brake up, and put it down almost right away) and give it a lot of gas.
#6 |
Member#: 6982
Yanking the e-brake will f-up your center dif. if I'm not mistaken. I did it once and the mighty clunk below did not sound good! But yeah, that will get you around in a hurry!
#7 |
Member#: 3956
Vehicle:2000 Turbo Legacy GT Titanium |
Take a look at the video from the AutoX in my previous post. That was done doing a variation of the "Scandanavian Flick".
1) With the tires I was using (BFG G-Force KD), the pressures were set at 50 psi front, and 40 psi rear. The tire pressures will vary with the type of tires you use. 2) Accelerate in a straight line up to 35 mph 3) Push full throttle and turn your wheel 90 degrees to the left, just enough to compress the RHS suspension 4) Reduce throttle input (0 throttle) (weight transfer) and gradually turn your wheel 90 degrees to the right. 5) The car will enter a drift forcing the tail of the car outwards (left) modulate your throttle lightly to keep the drift going or push hard on the throttle to power out. Practice makes perfect... Enjoy Note: Do this only in a closed / controlled environment supervised by professional instructors, if you are doing this for the first time. Do not do this on the open road, please!!!! |
#8 |
Member#: 2353
dont worry, i tried this in the back parking lot of my work place. thanks for the info guys
LET THE FUN BEGIN ![]() |
#9 |
Member#: 2362
Vehicle:1999 Legacy Outback Blue w/ Paint Chips & Mud |
1. Flick wheel left (for a right hand drift)
2. Hit gas, turn wheel right 3. Have fun drifting 4. Buy new tires. |
#10 |
Guest
Member#:
http://plastik.pnwsec.org/GTScoob/GTscoobnut.wmv
(might have to right-click-save) My process: #1 - Come into corner, start turn #2 - clutch in e-brake until you feel the back end break #3 - clutch-out HARD on gas (keep the wheels straight... AWD drifts do not take place with opposite-lock) #4 - (here is where you guys will hate me) If the car starts to hook up during the drift, pop the e-break quickly while still on the gas. YES, this warms up the center diff a bit, but keeps ya pointed in the right direction! ![]() E-brake will only "hurt" the center diff when the power is down, if you clutch it when you handbrake you take the stress off of the center... A |
| Thread Tools | |
| Display Modes | |
| How to drift a Subaru | awddrifter | Off-Topic | 40 | 12-17-2005 03:18 PM |
| How to drift a GC8... Wired Magazine | Bobalouy | General Community | 0 | 09-12-2003 04:49 PM |
| learn how to drift | drift king | North West Impreza Club Forum -- NWIC | 7 | 12-15-2002 09:25 AM |
| OT: how to drift. | vsigma | Tri-State Area Forum | 12 | 10-17-2002 03:25 PM |
| How to drift? | SubieFL | Technical Forum Archive | 11 | 08-04-2000 10:36 PM |
