Old 11-11-2005, 10:58 PM   #1
JayGold
Member#: 7074
For your viewing pleasure I have comprised a step-by-step installation of the Subaru 4 pot caliper rebuild consisting of seal kit: 26297FA050 (superceded to part number 26297FA051) Thx to ncarn8 for the update
Prior to removing the brake lines from the caliper have either golf tees on hand to plug the brake lines from dripping fluid all over the place or purchase a set Dorman hard rubber brake hose plugs: https://www.google.com/shopping/prod...d=0CNUBEKYrMAQ
Step 1: Removing Calipers: Remove 2 bolts from back of caliper and brake line (optional) from vehicle, drain fluid and obtain a well lit work area with chair...you'll need it as it takes several hours to clean, inspect, and reseal the calipers.
Step 2: Prep: Wipe the calipers down removing any loose dirt, brake dust, and fluid.
Step 3: Piston removal: I did not find it necessary to pump the pistons out of the caliper using compressed air. Simply remove the dust cover clips and the outer dust covers themselves. Use 2 large flat head screwdrivers with the heads wrapped in some protective tape so that you prevent scratching or pitting the pistons and carefully pry them up with equal pressure around.
If you are having difficulty removing the pistons, chances are the inner seals are dry, damaged, seized, or contaminated by something other than brake fluid. If this is the case, try to pour a small amount of brake fluid between the piston and the piston caliper chamber to wet the seals making removal easier.
This is what the caliper should look like right before piston removal, I left one boot on for pic illustration.
Look similar?
Step 4: Carefully remove all inner piston seals with a tartar scraper/puller:
JayGold is offline   Reply With Quote
Old 11-11-2005, 11:10 PM   #2
JayGold
Member#: 7074
Continued:
Step 5: Cleaning/Prep: Use a small amount of brake parts cleaner on a clean cotton rag over the entire piston cylinder area, this may take a while, be meticulous. Do not use anything abrasive. Your pistons should look like this if they are not scarred or damaged. To further clean the pistons, use steel wool #0000 for surface rust or to polish them up. Before re-installation clean the pistons with some compressed air to remove any particulates. The cylinders cleaned are shown below as well:
Step 6: Assembly: Coat the entire piston just below the outer rubber dust cover with red rubber grease (can be found on Ebay) to ease the re-installation of the pistons into the bores. At this time stretch the inner rubber piston seals over the pistons and seat them in the recessed channel.
Step 7: Install the rubber outer dust covers: Carefully stretch the new dust cover into the pistons outer recessed channel (make sure it is seated properly). The piston on the left is the correct way to set them up back into the caliper housing. The right piston in this pic is an illustration just showing that the dust cover is correctly installed and seated. Once all are seated on all 4 pistons, it's recommended you pack the inner portion of the seals with more red rubber grease. This will ensure a water-free/contaminate free environment once you place the pistons back into the calipers and seat the dust covers. (This grease is not shown in the pics)
Old 11-11-2005, 11:18 PM   #3
JayGold
Member#: 7074
Step 8: Piston Assembly: Push the pistons with solid equal force (can't stress this enough) into caliper until the dust boot is close enough to the retaining clip area to seat properly. You will exhibit some resistance when the piston meets the inner seals. (you do NOT need to push the pistons completely into the caliper housing so that it bottoms out),
Step 9: Clips: Install the new dust cover clips by laying one side of the opened end of the clip onto the boot, hold it with your fingers (or have an assistant hold it for you), then work the remainder of the clip around the caliper lip to seat it properly and if you do it at the correct angle you can let go of the end and it should snap and seat itself onto the lip of the caliper, verify that the entire clip is seated properly and not pinching the rubber boot in any spot.
Step 10: Final Inspection: Wipe off any grease/brake fluid/etc. and your calipers should look like so if you successfully followed all the above steps:
Fell free to hit me up with specific questions, this was just an outline, and I do have many more pics if you want to see them.
Good Luck!!!!
Jay
Old 11-11-2005, 11:36 PM   #4
infantsam
Member#: 51280
2015 WRB WRX
KNSBrakes
Most excellent
infantsam is offline   Reply With Quote
Old 11-11-2005, 11:59 PM   #5
JayGold
Member#: 7074
Originally Posted by infantsam
Most excellent
Those 2 words alone made this entire day worth it
Old 11-12-2005, 12:30 AM   #6
infantsam
Member#: 51280
2015 WRB WRX
KNSBrakes
Now to throw back some beers in Chicago and sarge the ladies
werd - HeineKEN's in New Jersey
Old 11-12-2005, 04:23 PM   #7
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Most excellent
I agree. Excellent write-up & pictures.
Samurai Jack is online now   Reply With Quote
Old 11-12-2005, 12:48 AM   #8
Boxologist
Member#: 21118
congrats.
Boxologist is offline   Reply With Quote
Old 11-12-2005, 12:52 AM   #9
burnera
Member#: 56232
89 325I
i don't know
Sticky!
burnera is offline   Reply With Quote
Old 11-16-2005, 02:14 PM   #10
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
Originally Posted by burnera
Sticky!
i'm w/him! great write-up!
Bishop is offline   Reply With Quote
Old 11-12-2005, 06:43 AM   #11
TarmacRally
Member#: 85805
... Shiny & Chrome
Witness Me!
You da man, Nice post. So you decided not to take the calipers apart eh?
sticky or DIY sticky +1
TarmacRally is offline   Reply With Quote
Old 11-12-2005, 02:12 PM   #12
JayGold
Member#: 7074
Hell no I even was told to disassemble the two halves by the local garage owners down the street so that I could have access to remove the pistons (not necessary, obviously), but when they asked why the standard calipers were not enough and gave me a funny look, I thanked them for the advice and ran home to pop the pistons out by hand.
***For the record, these calipers were purchased overseas and were previously on a 1998 WRX Type RA. Note the condition of the pistons and cylinders when contemplating your next rebuild***
No need to use a compressor, needle nose plyers, wrenches, or disassemble the caliper front from back half.
Thanks guy's, this is not something I would like to do every year, but my calipers needed some TLC.
Old 11-12-2005, 04:00 PM   #13
TarmacRally
Member#: 85805
... Shiny & Chrome
Witness Me!
Yeah, you gotta give a little love to your breaks. They're the ones saving your life.
Old 11-12-2005, 07:42 AM   #14
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
submit to scoobymods.
Old 11-12-2005, 01:02 PM   #15
Boxologist
Member#: 21118
very highest of complements!
Old 11-14-2005, 01:51 PM   #16
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Very nice!
You didn't happen to take any measurements of the piston diameter did you? It'd be nice to confirm the piston diameter info I got from the factory manuals.
Legacy777 is offline   Reply With Quote
Old 11-14-2005, 03:13 PM   #17
JayGold
Member#: 7074
Originally Posted by Legacy777
Very nice!
No I did not take any measurements, perhaps someone looking to rebuild soon could do it and add I can add it to this post.
Old 11-14-2005, 02:41 PM   #18
BIGSKYWRX
Member#: 7958
09 GH B+
Thanks so much Quick question I bought a caliper rebuild "kit"- curious if the kit (as listed at subaruwrxparts.com) is enough to do one caliper or two? I'm thinking I'll need another "kit".
Thanks again for taking the time to document this.
BIGSKYWRX is offline   Reply With Quote
Old 11-14-2005, 03:12 PM   #19
infantsam
Member#: 51280
2015 WRB WRX
KNSBrakes
I think Murphy's law says that if you expect enough for both you'll only get one - if you only have one leaking caliper you'll get enough for both and never have to use the others until one day after you can't find them anymore.
Old 11-14-2005, 03:12 PM   #20
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Yeah, one kit per caliper. Just count the seals, 4 = one caliper.
US2JDM is offline   Reply With Quote
Old 11-14-2005, 03:15 PM   #21
JayGold
Member#: 7074
From www.subaruwrxparts.com website:
Seal kit: 26297FA050
Subaru 4 Pot Rebuild Kit
Cracked piston boots? Popped out a piston? Run lots of track days? Then this rebuild kit is for you! Contains parts to rebuild the seals on one set of non-Brembo 4 pot calipers- 8 piston seals, 8 piston rings, 8 piston seal retainers, and a packet of grease.
Price:$25.00
This is the complete kit I used to rebuild both calipers.
Old 11-14-2005, 07:52 PM   #22
BIGSKYWRX
Member#: 7958
09 GH B+
Price:$25.00
Great- that's the one I got
Old 11-14-2005, 03:21 PM   #23
MBPEJ20
Member#: 24360
2002 WRX Sedan
awesome writeup and pix! thanks
MBPEJ20 is offline   Reply With Quote
Old 11-14-2005, 02:59 PM   #24
jamesfacts
Member#: 51282
98 RS
black & blue from parking
What issues did you have that made you want to rebuild your calipers?
jamesfacts is offline   Reply With Quote
Old 11-14-2005, 03:19 PM   #25
JayGold
Member#: 7074
After tracking the car at Gingerman Racetrack in MI, I started to swap my race pads out and noticed the outer dust boots were melted and torn open. I figured it was time to replace them and inspect the calipers which I had never cleaned up since purchase from overseas 3 years ago.
RacingBrake 4-pot Calipers: 50% lighter than Subaru 4-pot & fit under OEM WRX Wheels! AZP Installs Tri-State Area Vendor Classifieds 20 12-11-2012 03:27 PM
Subaru 4-pot Piston Removal/Rebuild JayGold Brakes, Steering & Suspension 12 11-10-2005 09:07 PM
Subaru 4-Pot rebuild tutorial? TROLL Brakes, Steering & Suspension 0 10-12-2005 01:01 PM
Wilwood 4 pot vs Subaru 4 pot Jaz_rs Brakes, Steering & Suspension 25 05-13-2004 12:03 PM
Wilwood 4 pot vs Subaru 4 pot BIGSKYWRX Brakes, Steering & Suspension 124 12-09-2002 11:07 AM
