Old 11-23-2005, 12:10 PM   #1
AndyWRXWG
Member#: 23784
2005 M3
Tiag
Default cel after installing APS TMIC with cobb 2.5
Ok over the weekend I installed an APS TMIC the older version. Now today just driving down the street the cel pops on and I pull over to check the code. I believe it was the PO171 lean A/F code.
Would the IC alone cause me to run a little lean? Or should I be looking for a hose that is leaking? Car seems to run fine haven't heard any knock. I think I'll switch to econo mode for now just in case.
AndyWRXWG is offline   Reply With Quote
Old 11-23-2005, 12:40 PM   #2
TopKatz
Member#: 36793
04 WRX
You probaly have a leak in the induction some place, check all thr conections you fiddled with ataching the TMIC
TopKatz is offline   Reply With Quote
Old 11-23-2005, 12:41 PM   #3
remowgn
Member#: 41149
09 FXT
SSM
I would not recommend using the economy mode as a "safe" alternative. It may run leaner than the regular maps in order to save fuel. Stick with your standard 30/34 map and just stay out of the boost. Running lean off boost is unlikely to cause major damage.
remowgn is offline   Reply With Quote
Old 11-23-2005, 05:51 PM   #4
AndyWRXWG
Member#: 23784
2005 M3
Tiag
yeah I didn't switch it. I reset the ecu and am just waiting to see if it comes back. I did a quick look under the hood when I got home and didn't see anything and I tried pushing on any hoses that I could think of that I might have touched.
Would the TMIC cause it to run lean? I don't recall ever seeing anything that would make me think it would. I know cobb says that if you use one just to watch for boost spikes and egt's, but nothing about A/F
Old 11-23-2005, 06:38 PM   #5
krees23
Member#: 95154
2005 Subaru WRX STi
I checked out the service manual for the code, here's some things to check:
Check for holes, loose bolts or disconnection of hose on air intake system
Check Mass Air Flow and Intake Air Temp sensors
krees23 is offline   Reply With Quote
Old 11-23-2005, 08:28 PM   #6
hondaeater69
Member#: 60324
how much boost are you getting?? What about EGT's?? Check the system for post MAF leaks like previously mentioned.
hondaeater69 is offline   Reply With Quote
Old 11-23-2005, 08:35 PM   #7
AndyWRXWG
Member#: 23784
2005 M3
Tiag
boost seems to be normal. Unfortunatly I don't have an EGT gauge. So a MAF leak is anything associated with the turbo inlet hose? I didn't really touch anything over there, but I guess I could have pulled it from the other end trying to get the IC to fit. I had a pretty hard time with it. I bought it used and it didn't have the proper brackets so I had to fuss with it quite a bit bending my stock brackets. The only thing I can think of is that I had to move the drivers side bracket over and it now kind of rest on a large vac hose that goes into the brake booster. That couldn't cause this kind of problem could it? I've been keeping a close eye on it and it seems to be fine, it's just that the bracket is resting on it and that does have me a bit worried for the long run. I just don't have the time or light to look now and I'm going out of town for the weekend so it will have to wait for a complete check down. I'm just trying to find out which hoses I should be consentrating on so I don't waist my time.
Old 11-23-2005, 08:41 PM   #8
hondaeater69
Member#: 60324
a post maf leak is a leak anywhere after your MAF sensor, and will allow unmetered air into your intake stream. This will cause your engine to injest more air than it thinks it has and cause your afr to run leaner than it's supposed to.
Old 11-23-2005, 09:21 PM   #9
AndyWRXWG
Member#: 23784
2005 M3
Tiag
ok thanks. I'm just going to have to search hose by hose and see if any thing is loose to the touch and after that well I'm not sure what to do. Hopefully it won't come to that. I wonder if the cold crappy weather we were having today could have had anything to do with it?
Old 11-28-2005, 06:38 PM   #10
AndyWRXWG
Member#: 23784
2005 M3
Tiag
ok I'm pretty sure I found it. I had to move the right hand bracket over to make it fit and in doing so it left the bracket pushing on the brake booster vac hose. After the light came back on today I did more looking and I could now hear the leak.
The bracket had cut the hose and air was leaking out like crazy. So I'd be pretty surprised if this isn't it.
Old 11-28-2005, 11:18 PM   #11
JRSCCivic98
Member#: 67080
Do you mean the sun?
Glad you were able to find your problem and resolve it.
JRSCCivic98 is offline   Reply With Quote
Old 11-30-2005, 05:50 PM   #12
AndyWRXWG
Member#: 23784
2005 M3
Tiag
no unfortunatly the sun was down and it was cold as hell. I'm just glad my brakes didn't fail, although i guess the worst that could have happend is no power brakes. I'ts been a few days now and the cell hasn't returned so looks like I fixed it. I had to cut the drivers side bracket so it wouldn't happen again.
Old 11-30-2005, 05:56 PM   #13
AndyWRXWG
Member#: 23784
2005 M3
Tiag
no unfortunatly the sun was down and it was cold as hell. I'm just glad my brakes didn't fail, although i guess the worst that could have happend is no power brakes. I'ts been a few days now and the cell hasn't returned so looks like I fixed it. I had to cut the edge off the bottom of the drivers side bracket so it wouldn't happen again.
gpmoto short ram with cobb 2.5? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 05-25-2005 02:08 AM
ok to run helix top mount ic with cobb 2.5? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-09-2005 07:07 PM
running lean with cobb 2.5? cheese tits Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-01-2005 07:56 PM
Anyone with Cobb 2.5 and borla headers? earlmale Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-14-2004 06:48 AM
For those with Cobb 2.5? STUDAndring Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-06-2004 01:49 AM
