Old 01-09-2006, 04:31 PM   #1
nosajh9
Member#: 85435
02 Impreza RS 2.5L
Default procedure for removing rear wheel bearing
i plan on replacing my rear wheel bearings on my 95 impreza 1.8 L AWD. they are humming, and need replaced. i wanted to know if there are any online procedures for doing this?
nosajh9 is offline   Reply With Quote
Old 01-09-2006, 05:25 PM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
You will need:
19mm
17mm
32mm
14mm
12mm sockets
small punch- 5mm works
decent sizd hammer
breaker bar, impact wrench, or a friend with really big muscles
a 15-50 Ton press with tools for bearing removal
needle nose pliers
possibly a gear puller
something to hang the brake caliper off of while changing the bearing
a torque wrench to put everything back together- 25-200 ft-lb range
2 inner seals
1 outer seal
1 rear bearing
1 new axle nut
1. Take everything apart until you are left with the hub and carrier in your hand.
2. Remove the rear seals from the carrier.
3. Use the needle nose pliers to remove the snap ring. If you can't see it- it's just covered with grease.
4. Press the hub out of the front side if the carrier.
5. Press the bearing out the back side of the hub.
6. Press the new bearing into the carrier.
7. Press the old outer race off the hub.
8. Remove the old outer seal and replace it with the new one.
9. Press the hub (with new seal installed) into the carrier and bearing. Don't press it in too far, 75% of the way is good enough.
10. Replace the snap ring and two inner seals.
11. Put everything back together. Torque as follows:
carrier to strut bolts- 130 ft-lbs
lateral links to carrier bolt (the long one on the bottom)- 100 ft-lbs
trailing link bolt- 85 ft-lbs
Caliper bracket bolts- 40 ft-lbs
Axle nut- 158 ft- lbs
lug nuts- 60-70 ft-lbs
12. Once you have it torqued- use the punch and press in the end of the axle nut where the notch in the axle is to keep it from rotating.
13. I think you are done at this point. If you have any questions feel free to PM me.
question about rear wheel bearing removal.. [email protected] General Community 2 03-23-2009 07:05 PM
Help! >< ,02 rear wheel bearing remover puller tool bon1210 Brakes, Steering & Suspension 2 03-27-2008 05:30 PM
Anyone know a good place to get a rear wheel bearing replaced for a good price evoq007 New England Impreza Club Forum -- NESIC 13 06-30-2006 08:22 AM
WTB: Front and Rear Wheel Bearing for 2004 Sti NotoriousD Private 'Wanted' Classifieds 1 04-26-2006 01:45 PM
last request for advice for rear wheel bearings... i promise psyber_0ptix Mid Atlantic Impreza Club -- MAIC 8 03-20-2005 12:29 PM
