Old 01-22-2006, 03:52 PM   #1
kheff46
Member#: 66739
2002 WRX wagon
Smile RHD swap ??'s
i'm looking at using all RHD components possible and staying LHD in a ver4 sti swap to 95 L sedan. i want the simplest install and will get it.
- hydro pedal box(LHD) can i use RHD and make lines,or is there other clearence issues?
-gc8 elec ac still useable in LHD console? same mounts etc.?
-RHD brake MC setup will bolt into LHD spot with new lines(no ??'s here)
-RHD 2.7 steering rack: is it possible to convert my 3.0 turn rack to the 2.7 turn? this would be ideal!
any ideas would be appreciated greatly! want to make this swap as fast as possible, and RHD seemed easiest until lately. still considering both! -keith
kheff46 is offline   Reply With Quote
Old 01-22-2006, 04:58 PM   #2
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
if you are staying LHD and all of those parts are from the RHD car here are the answers:
-no, dont really understand the question here. you cant use the RHD in a LHD
-no
-no, it will bolt up, but the shaft is too long and the ports on the MC are on the wrong side
-no, not that ive heard
Hurley 2.5 WRS is offline   Reply With Quote
Old 01-23-2006, 09:54 AM   #3
kheff46
Member#: 66739
2002 WRX wagon
why will the rhd pedal box not go in? things are in same spot as lhd just hydro ver.
-use L throttle cable (for length and routing)
-rhd brake MC with new lines to fit lhd routing(simple).
-hydro pedal box is there(rhd) and i need it instead of L's cable crap.)same layout,size
-gc8 elec is nothing i need anyway
-shaft for brake booster: is it removeable? will L be right length? if it is the same brake system entirely from the rhd setup, there's no reason it shouldn't be correct. everything is identical except line holes are mirror image.
Old 01-23-2006, 10:45 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i am gonna go with hurley here
no - go to the junk yard don't fool with hackign together brakes too important
yes but you will have to swap the heater box .. not a commonly done
no
no
Old 01-23-2006, 12:04 PM   #5
kheff46
Member#: 66739
2002 WRX wagon
i'll have all the necessary brake parts with rhd setup and lhd setup at my disposal.
-bigger mc for 4 pots(rhd mc w/lhd lines adapted), stock L lines/stainless ones, rear discs, good fluid
-hardly "hacking". 100% oem parts w/stainless lines(sounds like everyones setup) and good fluid? dosen't every other person in the world use this? i think so!
-if the parts work while on a car and you put the entire assy. into another car without changing anything, they will work as they did in the first car. despite what anyone wants to "think" it has to nothing changed! i guess no one gets it?
Old 01-23-2006, 01:02 PM   #6
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
The RHD setup and LHD setups are different. You can try and use the RHD setup in your LHD car but kiss your strut tower goodbye.
THAWA is offline   Reply With Quote
Old 01-23-2006, 05:01 PM   #7
kheff46
Member#: 66739
2002 WRX wagon
bout to find out!
RHD swap to LHD boiling_water Transmission (AT/MT) & Driveline 2 05-24-2006 09:18 AM
Debating a JDM/STI RHD swap into 05rs Sneeky Pete Subaru Conversions 17 12-04-2005 10:52 AM
Just got a 95 Legacy Wagon RHD, swap? WAUT Legacy Forum 18 09-22-2005 02:04 PM
1993/1996 Sti Rhd Swap B-85 Private Vehicle 'For Sale' Classifieds 5 05-09-2005 04:39 PM
rhd swap scubydrew Subaru Conversions 10 03-21-2005 09:34 PM
