Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 02-03-2006, 06:28 PM   #1
subeesteve25
Guest
Member#:
Default 215 vs 225
Ok so i just ordered some 17 x 7.5 rota subzeros for my wagon with 215/45/17 tires. I know 225 give more grip but with a wagon i know it might rub. Will 215's be good enough. I'm not planning on autocrossing or tacking my car. i really wanted 225's but I went with 215's so i dont rub. I just hope I like them. Anybody running 215's and find them to be pretty good. thanks.
Old 02-03-2006, 06:35 PM   #2
tuskenraider
Member#: 65699
15 WRX
WR Blue
The 215's are gonna be stretched on that rim, so don't expect any rim protection and the ride might be a touch stiffer as well. Otherwise 10mm isn't going to make or break your street performance. Careful not to curb rash them!
tuskenraider is offline   Reply With Quote
Old 02-03-2006, 06:38 PM   #3
BlackSnake
Member#: 42850
WTB 04-07 STI
Roller/Blown Engine
agreed, I would at the Minimum go 225.
BlackSnake is offline   Reply With Quote
Old 02-03-2006, 07:20 PM   #4
subeesteve25
Guest
Member#:
but i will rub when i put my lowering springs on
Old 02-03-2006, 07:46 PM   #5
subeesteve25
Guest
Member#:
bump bump bump
Old 02-03-2006, 08:11 PM   #6
dantastic
Member#: 66815
2005 WRX Wag -SOLD:(
CGM STX #125
i'm running a fairly aggressive setup: 225/40-18 on 18x7.5 +48 offset, lowered on tein s-techs. so far i've only rubbed twice in 10,000 miles (both times with a full load in a hard banked on-ramp.) i just picked up a set of 17x7.5 gram lights and plan to run 225/45-17 hankook rs2 for track and auto-x
dantastic is offline   Reply With Quote
Old 02-03-2006, 08:24 PM   #7
Hunt3r
Member#: 95484
I run 215/45/17 on my 17x7.5 Rota SDR's on my sedan and I love it. I didn't want to go up to 225's because of the bigger overall diameter. I don't know about yours but my 215 tires are rated to be safe on rims from 6.5-8.0 width, most are. That 1/2" width increase is not going to make the 215 tire stretch noticibly, but I think on the wagon that 225's might rub the rear fender unless you fix it. Here's an article on Subydude about it http://www.subydude.com/mods/detailsdoc.php?3055
Hunt3r is offline   Reply With Quote
Old 02-03-2006, 08:31 PM   #8
tora
Member#: 5851
09 Forester XT
+ NA Miata
215's are fine on a 7.5 inch rim. If you are worried about rubbing then get ther 215.
tora is offline   Reply With Quote
Old 02-03-2006, 08:56 PM   #9
nemocity
Member#: 98686
2005 Impreza 2.5RS
The dark blue one
Got Kosei K1 16x7.5 [front] and 16x8.5 [rear] on my old '93 MR2 turbo with 205/45-16 and 225/45-16 Yokohama AVS ES100's...ride is firm but turn in and steering response are insane...so 215's on a 7.5" rim is way cool...had this setup on the Toyota for 5 years with no curb rash...just don't drive alongside curbs and you will be OK!
nemocity is offline   Reply With Quote
Old 02-04-2006, 12:54 AM   #10
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
I'm running 215s on my 17X7.5 SSRs and am very happy.
One advantage was that I saved 3lbs per tire going 215 over 225. Having a little more gear in my WRX doesn't hurt either but the difference is so small I really can't imagine being able to tell.
HerculesPeanut is offline   Reply With Quote
Old 02-04-2006, 04:21 AM   #11
subeesteve25
Guest
Member#:
ok cool. i can always run 225's next time. I'm just running 225's now on a heavy 18 x 7.5 wheel so i wanted to know how different it will feel going to a 17 x 7.5 3lb lighter wheel with 215's.
Old 02-04-2006, 05:35 AM   #12
subeesteve25
Guest
Member#:
so how you guys think royal gunmetal subzeros with a polished lip will look on a psm wagon?
Old 02-04-2006, 10:12 AM   #13
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
i had BFG KDW2 215/45-17's on my SubZero's (sold them today). no streching BS like stated above. also no rubbing when lowered, except for when i went with 0 camber in the rear & had 2 passengers.
here are pics of my wagon lowered on TEIN H-techs:
and a close up:
Quack is offline   Reply With Quote
Old 02-04-2006, 02:20 PM   #14
shane86
Member#: 67387
04 WRX - STX
05 LGT Limited Wagon
Originally Posted by Quack
i had BFG KDW2 215/45-17's on my SubZero's (sold them today). no streching BS like stated above. also no rubbing when lowered, except for when i went with 0 toe in the rear & had 2 passengers.
Toe wouldn't have much effect at all on rubbing... don't you mean camber?
shane86 is offline   Reply With Quote
Old 02-04-2006, 06:07 PM   #15
Quack
Member#: 57264
oops, yep camber.
Old 02-04-2006, 06:29 PM   #16
subeesteve25
Guest
Member#:
Quack- where did you buy your front and rear lights. I want my wagon like that.
Old 02-04-2006, 02:32 PM   #17
ScooterLGT
Member#: 106209
2005 Legacy GT
The 215's are a fine choice - Quacks look pretty much perfect, IMHO. I had a similar conundrum on my Miata: I originally had 205's on my 7" rims, but switched to 195's and I like the look a lot better now and haven't noticed any grip loss. Bigger is not necessarily better for everyone.
ScooterLGT is offline   Reply With Quote
Old 02-04-2006, 04:36 PM   #18
tuskenraider
Member#: 65699
15 WRX
WR Blue
Well I'll stand corrected. Those look about the same as my 215/45 Falkens on the stocker 6.5" rim. Obviously tire brand matters, but Falkens are usaully known to be wide. You have a 1" wider rim and they still look the same. Interesting. Here are 225's on an 8" rim, which both are about 1/2" bigger than a 215 on a 7.5" and you can see it's clearly stretched:
Old 02-04-2006, 05:22 PM   #19
subeesteve25
Guest
Member#:
ill be using 215/45/17 kumho ecsta mx's on the 7.5 wheel. how is this tire for srectching and all that good stuff.
Old 02-04-2006, 06:31 PM   #20
Quack
Member#: 57264
which lights? the bulbs? from AutoZone.
the actual assembly are modded. & painted.
Old 02-04-2006, 07:44 PM   #21
subeesteve25
Guest
Member#:
How do u make them clear, what do i need to get?
Old 02-04-2006, 08:01 PM   #22
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Search 'cleared headlights'
It's a do it youself job and involves removing your headlight assemblies and cooking them in the oven to get them to a nice tasty flavor.
waktasz is offline   Reply With Quote
Old 02-04-2006, 08:03 PM   #23
Quack
Member#: 57264
^^^ what he said. the rears are just stock
215 vs 225 rdltmc3 Tire & Wheel 5 12-28-2008 05:37 AM
215 vs. 225 tires on stock rims... Swine Tire & Wheel 2 09-02-2004 11:47 AM
sizing questions 215 vs 225 and RPM dward Tire & Wheel 3 05-05-2004 06:33 PM
215 vs 225 (Rota 17" wheels) : A wagon owner's perspective. suby_dude Tire & Wheel 2 04-21-2004 05:38 PM
215 vs 225 on 17" 7.5 Wheel Rally Punx Brakes, Steering & Suspension 10 10-15-2002 02:37 AM
