Old 09-20-2001, 01:02 PM   #1
rallysquirrel
Member#: 7006
2007 SpecB
Question Looking for performance struts for the 97 Outback
Anyone have any experience with aftermarket struts. I was looking at KYB AGX struts, but will my stock tire and rim size rub on those? 205/60/15?
Also won't it lower my car?
rallysquirrel is offline   Reply With Quote
Old 09-20-2001, 01:16 PM   #2
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
05 Legacy GT 06 Armada
They shouldn't. AGXs are made and marketed as stock replacement struts.
I have a set of the RS AGXs on my car currently. I haven't had any rubbing or fitment issues.
Brad
MY99 2.5GT is offline   Reply With Quote
Old 09-20-2001, 01:42 PM   #3
98legacygt117
Member#: 8386
1998 Legacy GT 2.5
Red
KYB AGX's should work.. I have them on my car and no rubbing
98legacygt117 is offline   Reply With Quote
Old 09-20-2001, 02:49 PM   #4
sybir
Member#: 4615
05 STi, 97 Leg OB
IGNORE THE GT GUYS
seriously, though, AGX's won't work, they'll rub.
BTW, your stock size is 205/70/15, not 60
it might work with 60's, but I'm not sure. The tires are too tall, and they'll hit the spring perches, unless you run smaller (shorter) tires.
sybir is offline   Reply With Quote
Old 09-20-2001, 02:53 PM   #5
dvancleve
Member#: 5211
1997 Legacy Outback
Spruce Pearl green
Default Re: Looking for performance struts for the 97 Outback
Hey rallysquirrel,
Here is the deal on Outbacks. There are no aftermarket struts that will clear the stock 205/70-15 tires. Any currently available strut (other than stock replacements) will also lower the car about an inch. You can keep your wheels and switch to something like 205/60-15 tires (about the same size as Legacy Gt 16" tires). In theory these will make your speedo read fast, but I am currently running Impreza RS 16" wheels and tires and I have not noticed anything. I suspect that Subaru didn't do anything to correct the speedo on Outbacks.
Doug
dvancleve is offline   Reply With Quote
Old 09-20-2001, 06:12 PM   #6
rallysquirrel
Member#: 7006
2007 SpecB
Question other struts?
What would be the struts that would allow me to keep closest to original height? What about springs?
Anything out there that'll let me put on 225/45/17's and not have rubbing.
Old 09-20-2001, 11:48 PM   #7
dvancleve
Member#: 5211
1997 Legacy Outback
Spruce Pearl green
Default Re: other struts?
No struts (other than stockers) will keep the height. The springs aren't what give the Outback its height, but there are Legacy springs from Australia (Scorpion) that do raise the car. I can't think of why you would want to raise the car and go with bigger wheels and lower profile tires though.
Anything WILL let you run 225/45-17 tires without rubbing (at least with correct Subaru offset wheels). The diameter of these is the same as that of stock Legacy GT wheels/tires and is much smaller than Outback stockers so there is plenty of room.
Doug
Old 09-21-2001, 05:30 PM   #8
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
So the basic gist of this is if you want to mod an outback, you will need new wheels and tires.
My plan:
-rear strut brace
-rear swaybar mounts & endlinks
Then, depending on $$$...
-Gold P1s w/ 225/45-17 tires
-KYB/AGX with some good non-lowering springs
-used rally or mud tires for my five 15" stock alloy rims that will fit with the AGX's. (for offroad excursions and rallyx, don't want to scratch the P1s!)
If no $$$ available by the time my current tires are shot to hell (shortly...) Then:
-Dunlop SP5000 in 215/65/15 (plus zero size, I believe, but should help performance.) on my current 15" rims. Should only be under $500.
There is certainly a WRX in my future, but certainly not the very near future. I'm thinking a 2004 or 2005 model. In the meantime, this luxo-bargewagon is all I've got. Might as well make the most of it, and while gold P1's might look rather silly on the Outback, when I *finally* get my WR Blue WRX, they will fit in perfectly.
remarcable is offline   Reply With Quote
Looking for performance parts for 98 GT wagon jakmobile Legacy Forum 5 03-08-2006 06:46 AM
Looking for performance parts for my Subaru General7 Newbies & FAQs 10 05-24-2005 09:55 PM
The 96 L is gone ( tears ) and now the 97 OUTBACK is coming... RaceComp Engineering Mid Atlantic Impreza Club -- MAIC 0 05-16-2005 08:17 AM
Crossbars for roof rack off a 97 outback Sobelizard109 Private 'For Sale' Classifieds 1 11-11-2003 08:38 PM
? about the 97 outback sport wagen brake ! trustz Brakes, Steering & Suspension 3 09-25-2002 02:51 PM
Message Board Statistics All times are GMT -4. The time now is 05:28 PM.
