Old 09-24-2001, 03:50 PM   #1
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
Default reset cel...
I read in other posts about resetting the check engine light. What's the procedure for resetting it on a 2001?
janikphoto is offline   Reply With Quote
Old 09-24-2001, 09:11 PM   #2
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Easy way: disconnect the negative battery cable for half an hour. However, you lose your radio settings and such.
Second way - this works on a 2nd Gen Legacy (95-99) and I think on a 1st gen as well, so it might work on yours.
Under the hood, there's a second fusebox behind the battery and washer fluid reservoir. Open the box, and remove the second green fuse from the left (labeled SBF #2 - slow-blow fuse - in the diagram on the box lid) for half an hour. No loss of radio settings or anything. Your transmission and engine management systems will have to re-learn, but sometimes that's a good thing.
rrubel is offline   Reply With Quote
Old 09-26-2001, 08:07 PM   #3
MekoNY
Member#: 8000
2005 Accord
Graphite
Default Two birds with one stone.....
OK, I read your post and disconnected the SBF#2 fuse. I did this because my CEL came on a few mintues after my fuel light came on. I'm not sure if that's a coincidence or if something is really wrong. BTW, I own a 2000 Legacy and didn't want to disconnct the battery and lose all my presets.
I also just installed my K&N filter. I hope resetting the ECU will adjust the engine and tranny settings according to my new air filter.
MekoNY is offline   Reply With Quote
Old 09-27-2001, 09:25 PM   #4
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Default Re: Two birds with one stone.....
I seem to recall my CEL going on after installing a K&N, until I reset the ECU. Too much unexpected airflow?
Old 09-28-2001, 07:20 PM   #5
MekoNY
Member#: 8000
2005 Accord
Graphite
Default pulling the fuse did not work........
I did what you said and pulled the SBF#2 fuse for about 45minutes. I then put it back and my CEL was still on. I guess that trick doens't work on the newer Legacy's. I'll have to disconnect the battery and reset my stereo setting now. That better turn the CEL off or I'll have to go back to the dealer.
BTW-The K&N filter is awesome. I didn't expect to much but did notice a difference. Especially throttle response, it doesn't hesitate at all anymore. From any complete stop the car moves instantly with a touch of the pedal. The acceleration is much more linear too. It's no AEM CAI, but it's something.
Can Anyone Read/Reset Cel In Bay Area sirmasterdeck Service & Maintenance 6 12-30-2009 12:17 AM
Reset CEL for free got_WRX? Tri-State Area Forum 24 05-14-2009 07:31 PM
Misfired, CEL, fixed misfire, reset CEL, failed smog... mc2 Normally Aspirated Powertrain 1 03-19-2009 05:59 PM
What software do I need to scan/reset CELs? bump909 Open Source Reflashes 2 01-31-2008 07:44 AM
Wierd Cel after ECU Reset, installed TurboXS TMI, No Cel in Log DiMensionX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-13-2002 08:19 PM
