Old 04-06-2006, 10:31 PM   #1
legacydreamz
Member#: 92423
still locked in freezer
Default engine trouble, help
ok, i have a 95 legacy l. i just did the headgaskets and now the car wont start. before i did the headgaskets, then compression was all 180's except one cylinder.
now, the car will not start- it will turn over but will not start. i checked compression again. cyl 1 & 3 are now 120's and 2&4 are 180s. this is so agrevating!
anyone have any ideas? i know im getting spark and fuel. maybe i did the timing belt wrong? the haynes manual said the indents on the cam gears were to line up with the notch on the top of the rear cam covers. and the crank was to line up the arrow with the notch by the crank angle sensor. is this right?
legacydreamz is offline   Reply With Quote
Old 04-07-2006, 01:10 AM   #2
spdracr00
Member#: 65823
1996 Impreza L
Red
did you count the teeth on the belt? thats what i did.. last night in fact.. i guess i'll find out tomorrow if that works.
spdracr00 is offline   Reply With Quote
Old 04-07-2006, 02:32 AM   #3
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Don't line it up with the arrow on the crank sprocket... Line it up with the little dash on one of the teeth... You can't miss it... it's about the same as teh little mark on each of the cam gears... When the sprocket is in the correct position, I believe the arrow will point towards the drivers side. They keyway should also be pointing straight down.
wrx_driver_2002 is offline   Reply With Quote
Old 04-07-2006, 01:49 PM   #4
legacydreamz
Member#: 92423
huh... thanks alot.
Old 04-07-2006, 02:03 PM   #5
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Do you want pictures explaining what i said?
Old 04-07-2006, 02:13 PM   #6
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
If you get the oem timing belt its marked to line up with the marks on the sprockets.
Beyond that, what wrx_driver said.
ss
subysouth is offline   Reply With Quote
Old 04-08-2006, 11:07 AM   #7
legacydreamz
Member#: 92423
im sure i got it. thanks for the help.
Engine troubles HELP! NWSTi-wa Factory 2.5L Turbo Powertrain 3 06-12-2010 08:25 PM
HELP 2006 engine troubles subywuby45 Service & Maintenance 5 02-21-2008 09:38 PM
Engine Trouble Help brianswagon Factory 2.0L Turbo Powertrain 2 09-12-2006 01:40 PM
need some subie help,engine troubles... Vidiotgamer Factory 2.0L Turbo Powertrain 8 10-29-2003 04:30 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain 3 01-14-2003 09:04 PM
Message Board Statistics All times are GMT -4. The time now is 12:30 AM.
