Old 04-24-2006, 01:26 PM   #1
gdcpony
Member#: 113278
2002 Outback
Blue/tan
Default I was told you could help
I was refered to this site for info on a new type of car (to me). I work on allot of cars, but I am ignorant as far as Subarus go. I just copied the thread openning over to see if you could help me out a bit more.
I just gave into the family thing with my third child being born, and traded a heavily modded 2000 Mustang for a 96 Legacy Brighton. I had the Stang on rails in the handling department, so this soft suspension has to go.
I would like to know what parts can cross from the higher end Subarus to my "grannie car" (my wife's words not mine). I would like a stiffer set of sway bars, adj. coilovers (for more height not less), better braking, and some input on rims to make the most of this AWD. I figure to raise it an inch or 2, and put some bigger tires on it. Also where can I get a CAI, UDP, and exhaust for it? Since this model is not one of the "performance" models I find it hard to find the parts for it. If perf parts from other cars work on it that would help me out a ton. I would like to acheive the stance of an Outback if possible.
Also it has no tach, or cruise, hod scoop, or fog lights. Could you give this newbie a list of what I need to put these in? I have a good source of parts cars with these options (I never thought of a tach as an option before).
I appolojize for the length of this post, and thank you for any help you all can give.
gdcpony is offline   Reply With Quote
Old 04-24-2006, 01:35 PM   #2
ooberdoob
Member#: 70418
Five Subarus later I
drive a lifted TJ.
i'm too busy at the moment to get into it, but i will say..
oooohhhh the possibilities!!!!
think of it this way: brighton is the lightest most basic version of the car. read: best place to start.
ooberdoob is offline   Reply With Quote
Old 04-24-2006, 02:06 PM   #3
spdracr00
Member#: 65823
1996 Impreza L
Red
well you asked a ton of Q's there.. i guess it would be easier if you break down what you want to do first? are you looking to upgrade the suspension? maybe more power? although to be honest you're never going to get much power from that car, it will NEVER feel like your stang. also what kinda cash are you looking to spend?
spdracr00 is offline   Reply With Quote
Old 04-24-2006, 02:14 PM   #4
spdracr00
Member#: 65823
1996 Impreza L
Red
I'll start off with some suspension mods for you..
#1 Rear Sway Bar IPD makes a rear sway for your/our cars and its pretty cheap $180 for the bar and endlinks. that will make a huge diff becuase i dont think your brighton has a rsway at all.
#2 source a set of WRX 16" wheels and get a decent tire. you can find them for $200-$500 all the time on here.
If you really want to raise it, try finding a used outback wagon suspension. that will raise it up a few inches.. you will waste your money with coilovers and prob not be happy with the ride, and your babies prob wont like it either.
Intake = sound and very little HP gain, if any.. but it sounds cooler.
you could go the header/exhaust route.. but again money vs results are low.
If you want a hood scoop they only came on 97-99 LEgacyOutbacks/GT's so check the junkyards and boom, scoop. you can also look for a LEgacy GT front bumper if you want smaller foglights or an outback bumper if you want the 3" fogs. hope thas a place to start. but like i first said.. get some swaybars + wheels/tires and you'll already notice a huge change. then figure out how high you want your wagon.. and check the legacy FAQ's
Old 04-24-2006, 02:57 PM   #5
ooberdoob
Member#: 70418
drive a lifted TJ.
i agree,
sway bars: i don't know if the IPD is adj, if not, get the whiteline like i have, 18mm-20mm-22mm. get endlinks too.
+1 for the wheels too.
springs: depends your resources, if you have quite a bit available, get adjustible KYB AGX and some good springs. if not too much, get some KYB GR2s and some H&Rs or eibachs, etc, search for spring stuff, there's a ton of info on here about it.
engina: you're not gonna make any power there. all i can say is swap it if you want power.
if you're good with wires and have access to an auction, you're set. get a wrecked WRX or STi and start bolting it all in. it would be wisest to get a whole wrecked car, take out the engine and tranny, ecu and wiring harness, transplant them. (it all bolts up, no ****) put the rest of what you want on, and sell the sspare parts for the going rate and you'll have a very cheap 230hp (wrx stock swap) or not too bad of an STi swap. (300hp stock)
body work: scoops: read above. lights: read above.
all in all, sways and wheels and tires. best bang for the buck of them all.
the rest is all in how much you wanna spend.
Old 04-24-2006, 06:55 PM   #6
MYfirst00
Member#: 22928
2011 Outback 3.6R
Gray
Originally Posted by ooberdoob
i agree,
He wants to add height, not remove it. To get the highest, source yourself some Legacy Outback suspension for 97-99.
MYfirst00 is offline   Reply With Quote
Old 04-24-2006, 02:58 PM   #7
ooberdoob
Member#: 70418
drive a lifted TJ.
oh yeah, please fill out your profile, location, car info, regional club, etc. thanks.
Old 04-24-2006, 02:59 PM   #8
gdcpony
Member#: 113278
2002 Outback
Blue/tan
Okay, before I fly to work. I first need to stiffen this thing up some. I can't stand the body roll it has.
The options it's missing come next since I drive long distances a ton.
Infact, I go to 29 Palms (2500 miles) this fall for seven months with two trips back to Ohio while I'm there.
There is allot of desert out there that my Stang couldn't explore. So 'yote hunting from the back of this AWD is a probability.
The power could use some improvement, but this is first and foremost a family car. Nothing to severe in that respect.
Old 04-24-2006, 03:06 PM   #9
ooberdoob
Member#: 70418
drive a lifted TJ.
well a swap isn't severe as long as you stay out of the boost
the sway will tighen it up great. shocks and springs like we said. that's the handling for ya.
there's a thread in here recently about the tach, supposedly it's all in there, but no cluster panel or needle or motor or something, so get a junkyard cluster and rup it apart.
Old 04-24-2006, 06:51 PM   #10
MCarp22
Member#: 102684
2013 Impreza
Deep Cherry
The front bar is about the best thing you can do to tone down the body roll. I really like my whiteline one!
MCarp22 is offline   Reply With Quote
Old 04-24-2006, 07:16 PM   #11
ooberdoob
Member#: 70418
drive a lifted TJ.
dee
dee
dee
Old 04-25-2006, 02:48 PM   #12
gdcpony
Member#: 113278
2002 Outback
Blue/tan
Is the outback a dirct swap? I took a ride in one, and the ride was allot better. Still had some lean, but not nearly as bad. A set of bars and stiffer struts would have put it right where I want to be.
Also can anyone find a link that tach story. As well as any thing on factory fog lights and cruise.
Old 04-25-2006, 03:49 PM   #13
Kraziken
Member#: 38629
1999 Legacy GT (STI)
hey gdcpony,
I feel your pain. Sacrificing a bit for kids, I was in your shoes, but I've had a lot of fun in my car now so I can't complain. In it's stock form, your wife is right. It is a bit of a granny car.
Unless the car has aftermarket rims, usually when I look at the drivers in Legacies, they have white hair.
If you're interested in a GT hood scoop hood, I may be able to sell you mine. I'm either looking to go after a larger 03+ STI hoodscoop or the birdcatching 04 Hoodscoop. It is probably going to be a couple months down the road though.
Kraziken is offline   Reply With Quote
Old 04-25-2006, 05:06 PM   #14
spdracr00
Member#: 65823
1996 Impreza L
Red
yep, thats a direct bolt on, find some outback struts/springs and put them on. it will raise your "L" up about 2"
Old 04-25-2006, 09:27 PM   #15
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Like others have said, go with outback suspension 97 and up is when they came lifted. The reason outbacks feel stiffer is they have a much larger rear sway bar. So, if you're looking to save money, find a wrecked outback and grab its rear swaybar, which if I recall is an 18mm.
Instead of a CAI or exhaust, just take the snorkus box out of the passenger side fender. Search snorkus and snorkusectomy on here and you'll find the info you need. Its just a mod that makes a fun little noise when you get deep into throttle. Definately fun coming out of a wagon.
Also, check out this post about lifting on outback suspension (I think his is a brighton or L):
http://forums.nasioc.com/forums/showthread.php?t=990422
There are foglights available for your car as well, with holes in the bumper beam ready for install. You can source them on ebay for $40-60. I'm working on a way to mount my hella 500's that should be a pretty easy DIY, so check for that here in a few weeks.
Plays_With_toys is offline   Reply With Quote
Old 04-25-2006, 03:45 PM   #16
98_soobie
Member#: 17071
BUY a GT... its more cost/performance effective in the long run...unless your swappin in a 2.0L turbo.
98_soobie is offline   Reply With Quote
Old 04-25-2006, 03:46 PM   #17
98_soobie
Member#: 17071
Old 04-25-2006, 10:04 PM   #18
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
correction: 96 and up Outbacks are lifted.
and yes, they have an 18mm swaybar.
Wiscon_Mark is offline   Reply With Quote
Old 04-26-2006, 12:08 AM   #19
Kraziken
Member#: 38629
You know.
I thought about this.
Did you just buy this car? Someone else just mentioned getting a GT.
The cost of trading in that brighton for a outback, 97-99 wouldn't be all that expensive of a difference I would think. Since you want a taller suspension.
First of all you would get about 30 or 40 more horsepower? I think the brighton had 122 horsepower? You could get the H6 outback (harder to find) but then you would get what, another 80-90 horsepower?
You wouldn't have to spend the few $100 to change out the suspension.
You would get the thicker 18mm rear sway bar.
Depending on the options, you might get the nice leather package, heated seats, etc.
Just a thought.
Old 04-26-2006, 02:57 PM   #20
gdcpony
Member#: 113278
2002 Outback
Blue/tan
I traded the '00 Stang for this Leg and an 83 turbo coupe. Didn't want the payment with a new child. The 83 wil be ripped to pieces and most of the parts sold to pay for, well, more parts. This car is more than a family car to me. Don't tell the wife, but I plan to use it to learn about the Subarus. Having to work on it a bit will be good, and the money I spend is cheaper than a newer or better version. This will remain a work/family car, but why not have some fun with it? I have never driven a stock vehicle for long. I already scored a free hood scoop painted to match. I am well known to the salvage yards and have located 23 cars to use for sources. No Outbacks though. I routinely dropp off parts to them and am told to look and take what I need (within reason). So what parts should I pull for cruise? I have plenty of cars to look from if I know what parts from what years.
Old 04-26-2006, 03:39 PM   #21
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
That's what I'm talking about. Good plan of attack.
IronMonkeyL255 is offline   Reply With Quote
I was told that I need to go to texting rehab. Have you? Subi Chicky Off-Topic 79 09-16-2008 04:12 PM
Need help.. I was told I could find help here... LeroyBKR Built Motor Discussion 3 01-16-2007 09:56 PM
Few random ?'s wondering if you could help tru_to_the_ru New England Impreza Club Forum -- NESIC 15 02-09-2006 02:43 PM
A bit of a n00b when it comes to this, but I'd appreciate it if you could help me out 3DF Brakes, Steering & Suspension 12 03-25-2005 05:38 PM
I told you Billy Brooks was famous!! sweetsuby Mid West Subaru Owners Club Forum -- MWSOC 8 11-14-2003 12:00 PM
