Old 06-22-2005, 08:04 PM   #1
superg
Member#: 3385
Default Comparing dyno results: 50F vs. 90 F day
Twice I have dynoed my car on the same AWD Dynojet. Once when it was 50 degrees F and again recently at 90 degrees. Both at 5280 elev. Does the SAE correction for T, P and humidity (1.22 in the first case and 1.27 in the other) make the hp and tq numbers from the two days comparable? What sort of % error should one expect between different days and dramatically different atmospheric conditions? Even with the correction, would the turbo spool be different (laggier) at 90 degrees than at 50 degrees?
Just trying to figure out if the 6-8 ft lb drop and slightly slower spool is due to atmospherics or the underdrive pulley I replaced with stock recently (tired of p0340 CELs).
Superg
thanks
Superg
superg is offline   Reply With Quote
Old 06-22-2005, 08:13 PM   #2
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
if you're trying to compare both runs, (50 vs 90) and the difference in power between the two, overlay both run files on the same graph and post it up. Making sure that the CF setting is at UNCORRECTED....this would show real WHP on the 50 degree day and the 90 degree day....there should be a difference.
With the CF on SAE, it adjusts both runs to as if there were run @ say 70 degrees....that is why one got multiplied 1.22 and the other 1.27.
Drews_WRX is offline   Reply With Quote
Old 06-22-2005, 10:16 PM   #3
Driver72
Member#: 13720
If you had an underdrive (or lightweight) pulley on for the earlier
runs, and went back to stock for the other, that probably
IS why you lost 6-8 ft lbs.
If you kept getting CEL with the underdrive pulley...just go
with a stock diameter lightweight one.
You'll get 80-85% of the power gains, but without any of the underdrive
pulley drawbacks...and therefore probably no CEL's.
LW Crank pulleys are a cheap ($125) way to get more power to the wheels.
Driver72 is offline   Reply With Quote
Dyno Results: Flat Plate vs Divorced W/G luspeed Proven Power Bragging 56 10-15-2012 11:26 PM
Dyno numbers on a hot day vs a cool day chads09 Newbies & FAQs 23 02-17-2010 07:38 PM
Sreet Tune, Dyno Results: JDM STi EJ207 Blouch Dom3, dyno video too DuCash Proven Power Bragging 46 11-01-2009 11:25 AM
Latest dyno results: 145hp, 144ft-lb on Mustang dyno Patrick Olsen Normally Aspirated Powertrain 39 08-27-2008 03:19 AM
Dyno results: Injen CAI vs. "Torque Box" CAI Patrick Olsen Normally Aspirated Powertrain 45 08-13-2007 12:39 AM
