Old 07-08-2005, 03:13 AM   #1
e-type
Member#: 85338
1995 Legacy
Default Missing/slipping problem
Hello
I have a 94 legacy GT Twin Turbo, I have had a few problems since importing it from Japan for which I have had fixed, but when I floor it and the revs get up to 5000 RPM the engine starts to miss much like a slipping feeling (power surging very badly)
The engine runs great around town and fine on the open road with normal driving speed (speed limit) I get about 350km to a tank
I have replaced the knock sensor and have had the air flow sensor rebuilt. after fault codes indicating.
The spark plugs are brand new.
I did notice the blow off valve blowing air out in idle 750rpm, is this normal?.
If the coils are damaged could I expect this symptom.
If anybody could lead me in the right direction I would be very thankfull.
e-type is offline   Reply With Quote
Old 07-08-2005, 10:06 AM   #2
Performance Driven
Vendor
Member#: 75855
04 Dynapack
stock bov is not suppose to leak at idle.
Performance Driven is offline   Reply With Quote
Old 07-08-2005, 11:24 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
um yes it is suppose to leak
all of the usdm legacy turbos do and my G version does too
any way that shouldn't affect it
the twin turbo is generally out of your realm as it won't clear the LHD parts of the car
that said, ill throw out
try fuel injector cleaner?
bad gas?
how good is your ground strap?
igniter?
most all subarus produce peak power at 5250 or so so this is when the car is working the hardest
Old 07-08-2005, 06:09 PM   #4
e-type
Member#: 85338
1995 Legacy
I was reading through other forums and also found the subject soot in my tail for which I have as well, this subject and another i can not re find talks about the O2 sensor and a similar problem I have when putting the power on.
I will used a injector cleaner and check the ground leads.
would the O2 sensor affect the engine as in my problem
Recurring CEL, yet "no problem codes found". Datalogs included karnick Engine Management & Tuning 4 06-03-2010 09:40 PM
Clutch slip problems on my swap speedymaker Transmission (AT/MT) & Driveline 0 05-20-2010 05:48 PM
Slipping Problem...? cgmwrxFTW Transmission (AT/MT) & Driveline 7 01-16-2009 03:26 PM
Old School legacy missing/stumbling problem footypaul Legacy Forum 5 08-24-2007 07:56 AM
Trunk slipping problems Suby1128 Interior & Exterior Modification 7 06-21-2004 01:28 PM
