Closed Thread
Old 07-12-2005, 06:04 PM   #26
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
Originally Posted by powerlabs
My stock JDM WRX made 280HP. With a full 3 inch catless catback its making over 300HP. Stock. It cost me $2500.SPDUSA has some very good info comparing the "15 year old" G blocks with the new USDM WRX. Some quotes:
"Japanese engine runs different cam profiles and variable cam timing. With the better octane fuel in Japan, the Japanese WRX runs much more timing advance, not so much "more boost". The engine is able to make more boost down low because of timing and cam factors, not the other way around. Drivability is much better as a result. Or, as a friend said of the low speed running of the Japanese WRX, "It feels like a V-8" in comparison to the US car."
"Again by way of comparison, the American car as a throttle than can only be described as 'wooly' to use the old British tuner expression. It does not want to go below 3000 rpm, and the motor just does not feel happy at all below 2000 rpm. The Japanese WRX runs on light throttle at 1500rpm, pulls cleanly and smartly from 2000 rpm and is making good power by 3000 rpm."
"In the EJ205 'world motor', Subaru engineers have made a turbocharged engine that runs more like normally aspirated engine below 3000 rpm with a transition range to 4000rpm where it behaves like a turbo motor. It has only the quality of materials internally needed to stay alive at modest power levels"
I'll take JDM
The G block is the bottom of the barrel. It made 220hp and was used mostly in Legacy's. It had HLA's and is an old Phase I block. Some were closed deck but that is meaningless at the HP levels they can handle with stock internals. There were some better G blocks RS/RA and early WRX engines. Finding one of these is rare. Finding a low mileage USDM is easy. Mike is comparing JDM EJ205 and STi EJ207 engines to the USDM EJ205, NOT THE EJ20G
Scoobie Steve is offline
Old 07-12-2005, 06:47 PM   #27
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Mike runs a EJ20G in his own car. i drove his car last month - hes got the 96 WRX EJ20G bone stock everything. TD05, cast pistons with HLA, Stock cat in downpipe with no muffler (double resonators). probably makes about 280 crank ps.
Comparing his car with my best friends 235 dynopac AWHP Ej205 (stock TD04, no cats, ecutech tune), the tuned EJ205 is faster. more responsive, better top end (6K+) etc. spools quicker etc.
Mikes car passes emmissions in Cali. a JDM EJ20G passes CALI SMOG. enough said about that.
his motor setup is bone stock. You can buy an entire front clip with the awesome 4.11 gear ratio gearbox for less than $2500 bucks. ive bought 2.
a EJ205 dropout with harness and trans intact should cost $2500. we all know that a tune setup shoudl cost $1500-2000. (full exhaust+ dyno time)
play the numbers. which is a better deal for the money?
when refering to G motors let's talk WRX only. im not intersted in a pos legacy 220 ps motor with a VF10. we're talking about a front cut of a 94-96 JDM wrx car, minimum power is 260 stock and they have closed decks.
perhaps im lucky, the first clip i got was a sti version 1 with 8.5:1 forged pistons (in my friends car - gearbox was in mine - for sale now), Currently a Sti-RA version 2 v-limited is sitting in my garage with EJ20G 8.5:1 forged with mechanical valvetrain like the later K motors.
Freak luck i suppose :P
Powerlabs has the later EJ20K motor in his car with the nicer heads. more raars for him.
the argument is $2500 vs $4000-4500. Of course the ej205 for $4000 has its benefits, but its just too much money to put my vote there. is a $4000 EJ205 faster than a $2500 EJ20G?? of course. but you are still suck with the total ****e 3.9 gearbox ratios for the USDM. THAT is undisputed.
obviously for big power you want a EJ207. when i have 8K to trash, ill sign up for the version 8 longblock. they are quite the nice.
EJ20K is a good motor too, ssteve - ill be hard pressed to be even close to yours with my OG RA, but im guessing you paid a pretty penny for your clip - $4K ++ right?
supermoose is offline
Old 07-12-2005, 06:52 PM   #28
supermoose
Member#: 9093
swap starr
at least in my view of things, alot of us are sticking with modding the GC8 cars because they are inexpensive to pick up and swap out. supercar on the cheaps, tahts what this thread is all about.
given the time and proper blingage id join the GDA wagen and pick up a GDA shell to put baller parts on. GDA is a better chassis, everyone knows that. its simply in the descrepancy of weight / cash / power combination that the GC8 car shines.
Total tune on the cheaps. thats what this game is about.
Old 07-12-2005, 07:09 PM   #29
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Originally Posted by stimpy
I know of atleast two people who went with the EJ20G and wish they had gone USDM.
-Jon
I hope that doesn't include Noah. His is a bastard swap without ECU, and shouldn't count. But his bottom end did go bad real quick.
That aside, the Ej20G heads flow significantly better than the Ej205 ones. Personally I favor using a JDM engine with a USDM wiring harness and ECU for tuning. This is what will be done with my RS-RA engine...
Matt Monson is offline
Old 07-12-2005, 08:00 PM   #30
Scoobie Steve
Member#: 2289
Supermoose I agree that the early WRX EJ20g engine are nice units. They make up to 260hp stock. The fact that you found 2 early WRX clips for the price you did is very lucky.
I dont see where you are coming up with $2000 to tune a USDM engine. Up-pipe, pinks, vf22 and a reflash can be had for that price and you are at 260whp. That cant be done with a early WRX engine. Injectors are hard to find, engine management is a huge problem.
Last thing i want to do is start another JDM/USDM fight. Thats not what this thread is about. For the most part I am pro JDM. If i had to choose between a JDM EJ20g or a USDM i would choose the USDM, there are just too many advantages to it. JUST MY OPINION. You can make you own choice.
With that being said, I chose the JDM path. And yes I paid much more then 4k for it, but I got a complete car cut in 2 peices with 3k on it. It wasnt just the common clip. Plus at the time (2001) it was (still is) the best of the best. If I had to do it all over again I wouldnt change a thing.
Old 07-12-2005, 08:27 PM   #31
supermoose
Member#: 9093
swap starr
word.
yours is a drivetrain to die for. perhaps the next time around ill grab one
i suppose my option of tuning a ej205 would be to go catless with good exhaust bits and an ECU tech, at least the way we did it it was about $2K.
ej205 is nice. i really like it when its setup nice. i just cant afford it.
also, i hate the USDM 5 speed gearbox more than anything, perhaps thats my bias against it. its utter poop in my head. i love short gears.
what turbine setup is yours running? how did you tune it?
Old 07-12-2005, 08:28 PM   #32
supermoose
Member#: 9093
swap starr
when i bought my first STi version 1 clip they had a DCCD type RA on the same lot. besides for having a smashed corner, if i had 4K to drop at the time it would be in my car right now. having the rear bits is really nice - can you pm me info on how you went accross importing it?
Old 07-12-2005, 10:24 PM   #33
Scoobie Steve
Member#: 2289
I was running a VF22 on stock JDM ecu, no tune. That got me my 11.87 pass. I have sinced moved on and now I am running a rotated mount 20g and soon to be Hydra tuned.
Old 07-12-2005, 10:25 PM   #34
supermoose
Member#: 9093
swap starr
what is this hydra business i keep hearing about
Old 07-12-2005, 10:35 PM   #35
Scoobie Steve
Member#: 2289
A complete stand alone ECU. They have plug in kits for the Ver 5/6 STi and maybe other JDM engines.
Old 07-12-2005, 11:12 PM   #36
beachbum
Member#: 457
---- Smells like
weed and rampage
Wow... I remember when the hot ticket was an AWD swap, and Mike @ SPD was REALLY cutting edge in attempting to fab up a wiring harness to put a JDM EJ20 into his old Impreza. Now, we're doing all the wiring in < a day. WOW! How far we've come!
Now all I have to do is find an extra $25k lying around for a 2001 RS and a wrecked 05 STi.
beachbum is offline
Old 07-13-2005, 01:53 AM   #37
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I'm sort of feeling the neglect running a GC/GF in the days of the GD/GG. My motor, however, is current tech and I have a huge pool to work with when it comes to engine parts and tuning. That is a great advantage. Being restricted to a stand-alone or piggyback would bother me. Mostly personal preference at that point.
My V7 was WAY out of tune for the conditions my car runs in. I would imagine the older cars are less susceptible to this, but it is a valid concern in my eyes. Can it be driven without much in the way of engine management? When you mod it, how many hoops do you have to jump through to take advantage of the power?
I'm sort of rehashing everything that has been said previously so I'll step back for awhile.
-Jon
stimpy is offline
Old 07-13-2005, 04:47 AM   #38
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Hold on here don't start this BS of saying well both swaps cost about the same but with this this and this the USDM has as much if not more and is quicker than a STOCK EJ20G. I will tell you right now especially you vendors, you should all no better. How about we throw the VF22 and injectors on the G with a tune like the EJ205 then lets compare them shall we? You know good and well the G will spank that 205 like a red headed step child and ask for seconds. There are tons and tons of Gs running around Aomori prefecture with huge turbos an ECU tune and some upgraded injectors drag racing and running crazy on the twisties every weekend with no issues. And I mean turbos like the 3037 and T67 and the cars run fine. So before you start saying add this and that think about how you sound because thats like the SRT guys saying "Well the money I saved on not nuying an STi, I can mod my SRT and make it faster!" and that has to be the gayest crap I have ever heard!!!
DuoMaxwell is offline
Old 07-13-2005, 09:49 AM   #39
kheff46
Member#: 66739
2002 WRX wagon
is there a list of what the engine codes mean? ej20g, ej20t, ej207, etc.
where did they originate, which is considered most reliable with high boost, easiest to find, cheapest etc.
i want to swap an sti(ej257) in but i'm still considering jdm 2.0's. thanks for info!
kheff46 is offline
Old 07-13-2005, 10:48 AM   #40
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Well some of the stickies will help. But things like most reliable at high boost is something that is different with each person you ask. Easiest to find would be the ej205 us wrx blocks and IMO the cheapest. Then the earlier jdm blocks and then the later, newer, blocks.
totoherbs is offline
Old 07-13-2005, 11:21 AM   #41
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Originally Posted by Scoobie Steve
The G block is the bottom of the barrel. It made 220hp and was used mostly in Legacy's. It had HLA's and is an old Phase I block. Some where closed deck but that is meaningless at the HP levels they can handle with stock internals. There were some better G blocks RS/RA and early WRX engines. Finding one of these is rare. Finding a low mileage USDM is easy. Mike is comparing JDM EJ205 and STi EJ207 engines to the USDM EJ205, NOT THE EJ20G
Mine is an EJ207DW1KE:
[email protected], 260ft [email protected],000rpm, redline 8250rpm
... and it was still cheaper than any WRX engine I could find anywhere, fuel pump, wiring harness, STI radiator, etc all included.
Still think you'd go for USDM?
powerlabs is offline
Old 07-13-2005, 12:06 PM   #42
Scoobie Steve
Member#: 2289
Over a EJ20g yes i would go USDM, Over the ej207 NO WAY!
Old 07-13-2005, 11:46 PM   #43
supermoose
Member#: 9093
swap starr
EJ20G DW5PR is mine. supposedly 275ps with solid deck, 8.5:1 forged pistons and mechanical valvetrain (solid lifters). its such a weird inbetween stage motor that i have problems finding proper specs on things. anyone havea lead?
the vin checks out to be 95-96 sti-RA version 2 v-limited??
Old 07-15-2005, 03:53 PM   #44
jrico023
Member#: 43012
01' GC8
got a ej20g waiting to swap into my rs, need harness sugestions on which will be easiest to mod, and any wiring diagrams i may need and where i might be able to find em. i have a couple but one is not that helpful and the other doesnt match completely.
jrico023 is offline
Old 07-17-2005, 05:45 PM   #45
supermoose
Member#: 9093
swap starr
id get a professional to do the work for me. im a wuss when it comes to wiring, did a SR20 last week, but taht was only like 15 wires
Old 05-23-2007, 04:29 PM   #46
98jdmwrx
Member#: 146962
<P>
</P>
<P>&nbsp;</P>
<P>&nbsp;</P>
<P>i have the same engine ej207DW1KE, my car is a jdm 98 wrx, do you have any specs on this engine . I've been searching all over the place.</P>
98jdmwrx is offline
Old 05-23-2007, 06:02 PM   #47
Matt Monson
Member#: 832
99 2.5RS, '85 911
Damnit,
I just hate when the PM button breaks and people are forced to bump ancient threads just to ask one person a simple and direct question...
Old 05-23-2007, 08:48 PM   #48
98jdmwrx
Member#: 146962
my bad, new to this. So i take you have some info for me? Ive been searching for days!
98jdmwrx is offline
Old 03-08-2008, 11:14 AM   #49
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Originally Posted by Matt Monson View Post
Damnit,
I'm glad this thread got bumped (and again by me). It's a great thread full of a ton of valuable info...
SilverSurfer04STi is offline
Old 03-08-2008, 11:54 AM   #50
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
except that it has a ton of incorrect info ...
Jaxx is offline
Closed Thread
Thinking about swapping my WRX 2.0l for a 2.5. What's the easiest way? maxpower_454 Subaru Conversions 3 04-14-2010 10:37 PM
Preferred Packages are the easiest way to outfit your vehicle for winter -- the ideal [email protected] Tire & Wheel 3 11-01-2007 12:32 PM
03 USDM EJ20 -> 97 JDM EJ20 swap marksWRX03 Subaru Conversions 10 06-09-2004 08:13 AM
whats the easiest way to make the radio and lighter work w.o the ignition on swingkid Forester Forum 1 02-16-2004 12:50 PM
Who has the JDM EJ20 Swapped in their L? MY99 2.5GT Mid Atlantic Impreza Club -- MAIC 16 09-09-2002 06:37 AM
