Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 07-14-2005, 11:08 PM   #1
monkeypaw76
Member#: 83497
2002 WRX Wagon
Default surge in ej22t, Suggestions?
I have a 93 lgacy rs and every time the boost comes on the car shakes and surges, sometimes violently. both the engines power delivery and boost seem to jump around however the car is so jumpy many times the boost gauge cannot react fast enough to show much change. I have tried to fix it by:
replacing the bov with a turbosmart recirculating type.
substituting a manual boost controller for the stock electronic one(now stock again).
replaced hoses and checked endlessly for vacuum leaks.
I did find one very large vacuum leak (pre-turbo) but fixing this did virtually nothing. I also unplugged the battery to try to reset the ecu still nothing.
Has anyone heard of anything like this? does anyone have any suggestions?
monkeypaw76 is offline   Reply With Quote
Old 07-15-2005, 08:28 AM   #2
DamienX
Member#: 66331
Check your plugs, you should be able to tell if your running too rich on boost. My car was doing that a week ago but i have a completely diff setup on my legacy and i just needed to lean out the fuel a little bit.
DamienX is offline   Reply With Quote
Old 07-15-2005, 10:36 AM   #3
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
All go and no show...
Do you get a CEL when this happens? If so, pull the codes.
I had a problem kind of like that once and it was because I had a loose vacuum line to the MAP sensor. Under heavy boost it was coming loose at the sensor. Tie strapped it and never had it happen again.
legacy92ej22t is offline   Reply With Quote
Old 07-16-2005, 09:40 PM   #4
hotrod
Member#: 14141
2002 Impreza WRX
what turbo are you running. If your getting true compressor surge on the turbo, than you need to lower your boost settings or change the settings so the boost builds slower. Compressor surge means the turbo is building more boost than it can support at that engine rpm ( usually poorly matched turbo and engine combination ).
If it is not due to compressor surge you could be having fuel or ignition issues.
It would help with a bit more info about your setup (how close to stock are you), and the circumstances where you see the surging. If your getting any CEL you need to get that code pulled and come back to the forum with that info.
Larry
hotrod is offline   Reply With Quote
Old 07-19-2005, 02:43 PM   #5
azn2yunr
Member#: 67229
9295 BC/gm6
winestone/funky blue
sounds like hesitation to me. sruge is more of a noise than it is a violent jerck and it doesnt happen when you get on it. do a tune up, replace your plugs and wires, be sure not to use auto lite. use ngk and what ever your local autozone shucks kragen checker has for wires. borg warner works pretty good.
azn2yunr is offline   Reply With Quote
Old 07-19-2005, 08:21 PM   #6
turbo2ner
Member#: 89385
many most all
WRB/blk/blk/blk/slvr/wht
Too much boost, not enough fuel? Fuel filter, fuel sock?
turbo2ner is offline   Reply With Quote
Old 08-18-2005, 04:03 PM   #7
nismology
Member#: 93913
1996 Maxima
Super Black
Fuel pump??
nismology is offline   Reply With Quote
Japanese Cars Surge In Value Rankings - Baja Ranked #1 flyinpig News & Rumors 4 10-12-2005 01:16 PM
Strange surge in power at 5K RPM bleat Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 09-17-2005 12:17 AM
high G oil surge in heads patr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-23-2005 12:27 PM
Boost surging in 5th O2-GGA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-07-2004 03:04 PM
EMI surging in 1st gear i-rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-03-2003 08:23 PM
