Welcome to the North American Subaru Impreza Owners Club Saturday May 30, 2015
Old 01-15-2006, 07:29 PM   #1
njskatchmo
Member#: 94618
2002 Bugeye
Default Bartender: One Scotty's cocktail please.
Originally Posted by njskatchmo
I have about 70k miles on my 02 WRX. I can't get my car into 1st in a roll and Reverse always resists, not to mention a stiff 2nd gear. Am I ready for the Cocktail of:
1qt Redline lightweight shockproof
1qt Pennzoil Synchromesh
2qt Castrol HypoyC 80w-90
Is my tranny too high mileage for this?
How hard is it to replace this yourself? Anyone have directions?
What about the differential fluid any comments?
OK.....v3 cocktail
ONE
MORE
T I M E
FOR THE SUBARU 5MT TRANSMISSIONS O N L Y!!!!!
I CAN NOT CONDONE AND DO NOT PROMOTE THE USE OF THE MIX OF PRODUCTS IN THIS POST OR IN THIS THREAD OR ANYWHERE ELSE IN ANY OTHER TYPE OF TRANSMISSION!!!!
USE IN ANY OTHER TRANSMISSION AT YOUR OWN RISK
Favorable results reports of using the 'cocktail' in other transmissions are all over the internet, but I can not verify any of these.
The 'cocktail' was not and is not intended to 'fix' or 'band aid' transmissions that are worn or failing.....it WAS AND IS intended to smooth shifting make manipulation of the transmission less problematic than other than other available fluids ONLY.
All sorts of idiot bull**** has been posted and IS NOT TRUE.
DON'T BELIEVE IT.
2qt 80w90 Castrol HypoyC(NOW labeled Axle Limited Slip 80W-90 by Castrol in North America) NO stupid PM's on this either
1qt Redline HEAVYWEIGHT SHOCKPROOF....NOT the LIGHTWEIGHT!!!
1qt Penzoil 'SYNCHROMESH' transmission fluid....the GM synchromesh fluid PN 12345349 is available at any GM dealer and can be used if the Penzoil product is not available....the Penzoil one IS better.
__________________________________________________ _________
1) FOR BEST RESULTS DRAIN THE TRANSMISSION FOR AT LEAST 30 MINUTES...REMOVE the trans dipstick and use a funnel(see below) with a long spout....
Pour the WHOLE BOTTLE of the HEAVYWEIGHT SHOCKPROOF(NOT THE LIGHTWEIGHT) into the trans....
2) Pour EXACTLY 1/2 of ONE of the bottles of CASTROL into the now empty shockproof bottle and shake it gently.....and pour THAT into the trans
3) Pour ALL REMAINING CASTROL PRODUCT into the trans.
4) Pour EXACTLY 1/3 of the 'synchromesh' into the trans and replace the dipstick
5) Drive car in a NORMAL AND RATIONAL AND REASONAL MANNER using ALL the gears INCLUDING REVERSE.....
6) Park car on LEVEL surface....wait at least 20 minutes and check trans fluid level.....top up with the synchromesh product.
THE 5MT TRANSMISSION DOES NOT LIKE TO BE AT ALL UNDER FILLED....A BIT OVER FILLED IS BETTER THAN ANY UNDERFILL AMOUNT.
OVERFILLING THE TRANSMISSION S L I G H T L Y IS NO BIG DEAL.....DO NOT WORRY ABOUT IT. NO stuid pm's or posts on this please
ALWAYS POUR S L O W L Y.....or ya may end up with it all over UNDER the car and NOT in the trans where ya want it
these funnels work great...and no need to take the IC off
http://www.tools2parts.com/Blitz-606..._7c2023_d_0355
POUR SLOWLY....think glacial, here.
njskatchmo is offline   Reply With Quote
Old 01-15-2006, 07:41 PM   #2
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
I think I'd change my driving habits personally, assuming you haven't already. Going into 1st from a roll isn't how the tranny was designed.
THAWA is offline   Reply With Quote
Old 01-15-2006, 07:44 PM   #3
njskatchmo
Member#: 94618
2002 Bugeye
I'm not talking about a 20 mph roll Im talking wont go in unless the speedo is on 0.
Old 01-15-2006, 08:03 PM   #4
...juust do it....and remember.....do NOT dump 4 qt in the tranny!!!!!!!!
That WILL overfill it---bad juju.
Add ~3.3 - 3.4...drive the car---check....repeat a couple times....make SURE it isn't too much before ya add more.
Add the lube SLOWLY into the dipstick tube or you WILL get more UNDER the car than IN the tranny
...and the rear diff can use GL-5 whatever.....I'd use a syn like M1
Old 01-15-2006, 08:31 PM   #5
ivwarrior
Member#: 100610
MBP
Piece of cake.
1. Put car up on jackstands or a lift
2. Remove drain plug and drain old fluid. Reinstall drain plug.
(now would be a good time to do the rear diff, too)
3. Lower car and add new fluid via a funnel in the dipstick tube.
4. Make sure not to overfill, I believe the tranny holds less than 4QT total.
Pretty simple, too. While you still have the car up in the air to do the tranny/front diff (same fluid, flows between the two) do the rear.
1. Remove FILL plug. (You don't want to drain the fluid THEN find out you can't get the fill plug out.)
2. Remove drain plug and let fluid drain. Clean the fill plug while the fluid drains, there's a magnet in it that will have metal filings on it.
3. Reinstall drain plug and carefully add fluid through the fill hole. This part is a bit of a pain because of the location of the fill hole. Holds less than a QT (about .8 I think) Fill until the fluid is just at the bottom of the fill hole.
4. Reinstall fill plug.
ivwarrior is offline   Reply With Quote
Old 01-15-2006, 08:56 PM   #6
njskatchmo
Member#: 94618
2002 Bugeye
Do I have to replace the diff fluid? It was replaced at 60k with royal purple i belive.
Old 01-15-2006, 09:04 PM   #7
brentlz
Member#: 12057
2002 Impreza WRX
WR Blue Pearl
I used a 4" funnel propped into the passenger side mount of my STi titanium strut brace with a short piece of scrap hose from the funnel on down into the filler neck. Draped a couple old rags around the funnel & filler neck to catch any spills.
Might want to warm up the new gear oil 1st, as it flows _real_ slow. I sat the bottles in the kitchen sink full of hot tap water for a half hour or so. Dry off the outside of the bottles before filling up the trans.
When doing the rear diff:
-Take out the filler plug (upper one) 1st before draining the diff!
-Have a long 1/2" drive breaker bar handy as the plugs can be in tight. I put the car on ramps to get extra leverage room and more stability than jack stands.
-Handy to have a pump...I used a cheap one from AutoZone that mounts onto the gear oil bottle. Took many pumps to fill it back up. ;-)
-I have the Primitive rear diff guard, so I used another piece of scrap hose jammed into the drain hole down to a catch can to minimize the oil caught by the diff guard when draining out the old oil.
-I didn't use any sealant on the plugs, just a bit of anti-seize on the threads...no leaks seen.
Brent.
brentlz is offline   Reply With Quote
Old 01-15-2006, 09:20 PM   #8
njskatchmo
Member#: 94618
2002 Bugeye
Where can i find the castrol stuff?
(edit)
I've read that original it was 75-80 castrol hypo C and they discontinuted it. Will it affect performance with 80-90. Should i go with valvoline 75-80?
Old 01-15-2006, 11:47 PM   #9
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I've been running the castrol 80-90 for about 7K miles now. Been happy with it so far.
Old 01-16-2006, 10:57 AM   #10
(edit)
......NO
Old 01-17-2006, 07:57 AM   #11
WRXSleeper
Member#: 43853
2004 WRX Sedan Stg 2
Platinum Silver
does anyone buy the drain bolt sealant from subaru? or should i just use anti-seize or something else.
WRXSleeper is offline   Reply With Quote
Old 01-17-2006, 10:51 AM   #12
there is no sealant for the tranny....there is a re-usable washer.
for the rearend, I have used liquid teflon thread sealer with no known leaks....and many use nothing at all other than the specified torque(36.2ft-lbs) with no leaks
Old 01-17-2006, 11:05 AM   #13
psyber_0ptix
Member#: 60671
1992 Miata
mmMMMMM permatex liquid teflon to the rescue
psyber_0ptix is offline   Reply With Quote
Old 01-17-2006, 03:00 PM   #14
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
That WILL overfill it---bad juju...
w3rd. Letting the transmission drain for 30 minutes or even an hour or 2 won't get all the fluid out. Thick fluid plus lots of gears (for lots of surface area for the fluid to stick to) means you'll have to let it drain at least overnight to get the majority of it out.
Psydotek is offline   Reply With Quote
Old 01-17-2006, 03:22 PM   #15
tmarcel
Member#: 7555
I haven't used the above contents in my tranny but I've got GREAT success with my own blend .
50/50 Mix to start:
Redline Lightweight shockproof
Redline MT-90
I had 3rd-4th shift syncro problems since the car had about 10k miles on it. It progressively got worse and they all got replaced under warranty. Within, 1k miles of the tranny being rebuilt with the new syncros, I began to get the grinding again. I decided it was time try another fluid. I knew that regular GL5 stuff was just too slick. That's when I decided to mix - about 15k miles now and still no more grinding no matter how hard or high you shift to redline.
Although you're not supposed to stick GL4 (the MT-90) in the trans it's the only way to keep from grinding. Either take a chance or go through another set of syncros.
tmarcel is offline   Reply With Quote
Old 01-24-2006, 06:17 AM   #16
Starkiller
Member#: 82741
2007 350Z Silver
Can the GM synchromesh be used instead of the pennzoil stuff?
Starkiller is offline   Reply With Quote
Old 01-24-2006, 09:02 AM   #17
Jfrankon
Member#: 20254
2010 VW GTI
2013 Outback 3.6R
According to the owner's manual, your not suppose to mix makes of fluids. Any one have any warrant issues/headaches when using the cocktail method?
Jfrankon is offline   Reply With Quote
Old 01-24-2006, 09:15 AM   #18
psyber_0ptix
Member#: 60671
1992 Miata
original cocktail calls for GM, however scotty told me the pennzoil is nearly the exact same thing.
i used the pennzoil in mine since it was easier and cheaper to obtain.
Old 01-24-2006, 03:52 PM   #19
Starkiller
Member#: 82741
2007 350Z Silver
Hmm, GM synchromesh probably is a rebadged pennzoil anyways.
Old 02-18-2006, 12:38 AM   #20
fourdegrees
Member#: 49662
2005 FEALing fine
Scotty,
How long have you been running this cocktail?
fourdegrees is offline   Reply With Quote
Old 02-18-2006, 01:36 AM   #21
Originally Posted by fourdegrees
Scotty,
....since '03
Old 02-18-2006, 04:49 AM   #22
garie
Member#: 26607
2002 wrx wagon
when I hit 60k I should really try this cocktail.
right now I am running 1 qt penzoil synchromesh and the rest silkolene synthetic. Works pretty good actually....I actually like it more now 15k into it than in the beginning........weird.
ive tried 100% M1=sucks
50/50 m1/synchromesh=ok but not great
100% synchromesh=worked ok
garie is offline   Reply With Quote
Old 02-18-2006, 08:18 AM   #23
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Is it recommended to put a blend into the 6mt as well?
Mike Robinson
bluescoobywagon is offline   Reply With Quote
Old 02-18-2006, 12:51 PM   #24
fourdegrees
Member#: 49662
2005 FEALing fine
LW Shockproof: 8.99
Castrol 80w90: 4.29 x 2
Penzoil Syncromesh: 6.09
RL 75w90 for the diff: 8.99
Grand total: 35.13 w/ tax
Old 02-18-2006, 01:03 PM   #25
desert pirate
Member#: 70033
use thesearchbutton
orotherswillcry
I would definately trust the UNCLE i've met him and he REALLY know these subys!
HIS NM friend
desert pirate is offline   Reply With Quote
Bartender: One Chim's cocktail please. chimchimm5 Off-Topic 0 06-30-2007 04:34 PM
FS: One (1) Uncle Scotty's Cocktail FunkMasta VIC Private Classifieds 14 05-07-2007 10:09 PM
uncle scotty's cocktail with superlight? RUrunning Service & Maintenance 8 11-12-2005 04:29 PM
Who uses Uncle Scotty's cocktail? Impr3zy0u Transmission (AT/MT) & Driveline 25 09-18-2005 08:33 PM
Update: Uncle Scotty's cocktail with 80w90 hype-R-29 Transmission (AT/MT) & Driveline 17 09-07-2005 08:36 AM
