Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 02-11-2006, 05:51 PM   #1
aspera
Member#: 7879
Default LS1/T56 into GC8 theory for heretics
There's already a 'Corvette engine into WRX' thread, but any older Impreza would be a good donor car. Lighter, better looking, and cheaper.
Why the Impreza? Why not? It is a solid little car with a few specific advantages.
1) wide frame rails
2) long enough engine bay
3) already has transmission tunnel
4) already has IRS
5) everybody (including insurance company) thinks it is a low horsepower/high traction AWD car and will freak out if you do a smoky burnout
6) gigantic aftermarket and technical support for Subie and Chevy stuff
A) So, what will be different than the LS1-into-WRX swap?
B) Is there less room between the hood and engine?
C) Is there less room between the radiator and engine?
D) Is there any difference in the front crossmember (other than the dent for the uppipe) that would cause a problem?
E) How much narrower is the transmission tunnel?
F) R160 and R180 will need to go. What should be done?
Please, please, please if you don't like the idea of a RWD Impreza don't post. We already know you don't like the idea. And you'd never buy a 5.7RS if Subaru offered one right on the showroom floor next to the 2.5RS.
aspera is offline   Reply With Quote
Old 02-11-2006, 05:59 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
well, for hood clearance, a boxer motor is a very short motor...a V8 generally isn't...things would need to be measured and a crossmember/adapter would have to be made...radiator to engine there would be less room, unless expanding the tranny tunnel further back...the LS1 has 4 pistons sitting side by the side, the EJ only 2...
Old 02-11-2006, 06:54 PM   #3
aspera
Member#: 7879
Yeah, it turns out the boxer isn't the only thing in the engine bay. The transaxle sticks in there nearly a foot. The guy that is doing the Corvette/WRX swap showed how the LS1 fits in the WRX engine bay front-to-rear when the car is RWD only. The T56 doesn't intrude into the engine bay. This *might* give the car better F/R weight distribution.
One little thing that the 2.5RS has that should help is the hood vents (one over each cylinder bank) and a hoodscoop. That should help keep the engine cool.
Old 02-11-2006, 07:01 PM   #4
soslow
Member#: 95027
'13 BRZed
pretend racecar
Question
interesting.............
I saw a porsche 944 for sale a while back that had an LT1 swapped in. at any rate its an interesting idea, but for curiosity's sake why not an LS1/6 or newer?
definately different
soslow is offline   Reply With Quote
Old 02-11-2006, 07:25 PM   #5
aspera
Member#: 7879
Ummm...LS1....that's what the thread is about. Do you mean LS2/6 or newer? Any GenIII or GenIV SBC, but I just used the common term LS1. All aluminum would be preferable as well as older OBD2, cable throttle engines. A crate motor might be the way to go, too.
Some of the things to think about would be the wiring harness/throttle cable/clutch/tach/speedometer/power steering.
Might be illegal, too.
Old 02-11-2006, 09:08 PM   #6
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
It cant be done, atleast not within reason. End of story!
Scoobie Steve is offline   Reply With Quote
Old 02-12-2006, 02:36 AM   #7
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
i say get an rx-7 and do it..
I've seen those.. And thats badass.
subbyspeed is offline   Reply With Quote
Old 02-12-2006, 10:54 AM   #8
brighton96
Member#: 85238
2002 WRX Sport Wagon
PSM+CF
IMHO it is not a great idea to put a V8 or inline engine where a boxer belongs. There are plenty of other cars that would be easier and more practical for this swap.
However, I have to respect anyone who can actually pull off a swap like this. But by pull off I mean Daily Driver reliability. A radical swap is just mixed up parts if it won't run or is a garage queen.
brighton96 is offline   Reply With Quote
Old 02-12-2006, 12:42 PM   #9
aspera
Member#: 7879
Care to elaborate? Whenever I see 'end of story', 'period', or 'enough said' I always think the person is trying too hard to declare victory too soon. You even see those terms in Hotrod magazine. The editors use them. Most of the time they are saying that domestic cars are superior to import cars in every way. Period. FWD cars will never break into the tens. End of story.
The 'within reason' part is where I think you have a point, so I'd like to hear it. This thead is basically a feasibility study. We know the engine and transmission fit in a WRX with some work. That's a given. We know that earlier Imprezas are nearly identical platforms, but cheaper. We know that LS1-T56 combos make good power and should be very reliable in a small car like a GC. No broken transmissions.
Old 02-12-2006, 03:47 PM   #10
Scoobie Steve
Member#: 2289
1998 11.87@112mph
I have never seen a Chevy V8 bolted, mounted and running in any subaru. I have seen one dropped in an engine bay with no rad, trans or anything else. I hope you dont consider that fitting. I also have seen one with all kinds of fancy CAD drawings and such, neither one will ever be completed.
I covered this pretty well in the other V8 swap thread. It wont fit its that simple!
V8's do however fit in hondas.
http://videos.streetfire.net/video/D...9BEA2A5D90.htm
Old 02-12-2006, 04:34 PM   #11
soslow
Member#: 95027
'13 BRZed
pretend racecar
Thumbs up
Ooops im stupid I thought I saw LT1, my bad. I say go for it if at all possible. Not my cup of tea (I like the awd to much) but it would be different and kinda cool............Especially If you found a way to turbo the 5.7L Now that would be BAD
Old 02-12-2006, 04:57 PM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
why would you even waste your time? you will then need to convert to a shortered 12both rear end completely wasting the whole idea of a AWD car with independant rear suspension.
and if you think for a a second a r180 will hold that power you are sadly mistaken.
it can be done but why waste the time?
HndaTch627 is offline   Reply With Quote
Old 02-13-2006, 02:02 PM   #13
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Seriously.....If I were to do it (and I have no doubt that I could)...I'd start with finding out if a aftermarket front subframe / suspension could be "re-engineered" into the Subaru. Keep in mind, you may have to remove the tranny tunnel anyway, to get the geometry straightened out....and I'd bet the rear suspension would be a bear, too....not enough room for a 9 inch or 12 bolt with the conventional 4 link or coil-over / ladder bar setup.
I'd get out the DOM tubing / aluminum and get to work. It would probably be cheaper, and less headache.
S.
n2xlr8n is offline   Reply With Quote
Old 02-13-2006, 02:11 PM   #14
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Wrongo. Anything can be done with enough time and money. What is "within reason" for you may not be the same as what is "within reason" for some rich guy.
I don't see why it couldn't be done with plenty of custom work. I'd go 9" rear end, but these guys are right...if you're looking for a small chassis to plop a V8 in there are plenty of easier/cheaper ways. Unless you're simply enamoured of the gorgeous GC8 styling, pick something else.
US2JDM is offline   Reply With Quote
Old 02-13-2006, 07:42 PM   #15
richard donovan
Member#: 62738
2000 RS,5MT,Silver
DeltaCams,Borla,Prodrive
Default this might help
http://www.bmrfabrication.com/F-bodyChassis.htm
http://www.bmrfabrication.com/K-Members/ls1.jpg
this would help greating to speed up the build.
i have also thought of this but found after thinking about it that the shock value would be better in a loyale wagon mid engine.. ... i can agree that the impreza is a great looking car i have a 2000 rs (silver)
i belive a wagon was being build a year ago or so a impreza wagon with a early 70's truck arm rear suspension....wagon and 2 door are really the same thing so it should all fit.
also making the car no matter how cool it might be would kind of be ...wrong especialy if it was a real rs or a real sti...but a loyale who cares!!!
richard donovan is offline   Reply With Quote
Old 03-04-2006, 11:14 PM   #16
aspera
Member#: 7879
Remote mount turbo system, giving you a light pressure turbo system on a large displacement V8. See Squires Turbo Systems.
Old 03-04-2006, 11:35 PM   #17
aspera
Member#: 7879
As I pointed out in my original post, the R180 would have to be dealt with. I'm thinking that an R200 or other Nissan diff would be the way to go. Another option would be to mount the entire rear suspension (subframe and all) from the donor car. A C4 Corvette rear end might also allow wider rear tires. Maybe use a GTO rear diff???
But why waste the time? I don't think that I will...I don't know. All the time I've wasted so far is just investigating the swap. It might turn out to be a good idea. Here's why;
If the 'roadmap' for the swap can be figured out, then it might be fairly cheap to have a small V8 car that looks like a Ver.6 STi, but is really a high mileage Impreza L and a wrecked donor car. Of course it won't be AWD and *might* not be good at exactly what you want it to be good at, but it will surely be good at something.
As far as fitting a SBC in the car...it has been done to nearly every other car made in the last century. It is only a matter of finding out if this swap is on the HARD or EASY end of the spectrum. It sounds like it is just on the expensive side of EASY, or the cheap side of MEDIUM. You should try putting a V8 in an MR2.
Old 05-28-2009, 09:50 AM   #18
Seanco
Member#: 187051
+1!!!!!!!
Seanco is offline   Reply With Quote
Old 05-28-2009, 09:56 AM   #19
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
way to bump a dead three year old thread noob
Old 11-12-2012, 09:06 PM   #20
moto21186
Member#: 276223
2003 impreza wagon
burgandy
There's a guy in Seattle Washington area who brings his bug eye wrx the pacific race ways and he has a ls1 in it he daily drives it and drifts it on the weekends he said it cost him right under 5000 to do the swap and he made almost all of it back by selling his stock parts he gets over 25mpg and he drifts it almost every weekend I've been thinking of doing this ls1 swap in my 96 wagon only problem guy has had is he blew like 3 rear ends I'm pretty sure he said he was running a rx7 one now and it's holding up really good and the best part is he did it all in about a full week and no major modifications were made to engine bay so it has and can be done feasibly just depends on what kind of knowledge you have
moto21186 is offline   Reply With Quote
Old 11-13-2012, 12:37 PM   #21
3mlwhly
Member#: 217648
01 2.5rs
bring this thread back to life!!!
3mlwhly is offline   Reply With Quote
Old 11-14-2012, 02:07 AM   #22
TyConway
Member#: 193189
2002 wrx
sure it can..
TyConway is offline   Reply With Quote
Old 11-14-2012, 08:22 AM   #23
Se7enrex
Member#: 124283
2000 RS/STI/WRX
Go spend some time on zilvia, seriously. Those guys are swapping viper engines now, v8's are a standard affair. I wouldn't worry about the radiator, with that complex of a swap who cares if you have to do some front end modification as well. Tube the front end like every 240 guy and that will allow you to get much more creative. With time and skills it shouldn't cost much. That is if you do the fab work. If you pay a shop you might as well not...
Se7enrex is offline   Reply With Quote
Old 03-13-2014, 01:28 AM   #24
swagwag92
Member#: 260858
0102 01 OBS
02wagon #bigturbo#cam'd
bring this thread back to life so i can finish my OBS!!!!
swagwag92 is offline   Reply With Quote
FS/FT : SC: '90 RX-7 with LS1/T56 swap andrewp724 Private Vehicle 'For Sale' Classifieds 53 06-24-2010 11:02 PM
project LSCUBIE-DOO: LS1 + T56 USA #1 CoiloverKid Member's Car Gallery 65 11-13-2008 08:17 PM
1989 Mazda RX-7 with LS1/T56 swap lots of goodies fully sorted lots of pictures rao Private Vehicle 'For Sale' Classifieds 19 11-18-2006 07:19 AM
