Old 03-09-2006, 01:01 AM   #1
rst4me
Member#: 108286
Default custome fiberglass made easy
I got board so I did a write up on how I made my rear deck enclosure for my gc8.
enjoy
and feel free to email with questions.
Im very sorry, I tried to make this as short and as logical as I could but its late and ive been at it a while. I will look at it again later and revise accordingly.
Round up kiddies, Iím gonna show you how to fiberglass!!
Here is my solution to the inevitable issue of where do I mount my cd changer so it is still accessible to my interior??
First things first a quick materials list.
Beer (located at any supermarket)
Stretchy fleece cloth (Jo Ann fabrics; ya know girly stores where they look at you all funny for shopping there with tattoos on your fore arms)
Fiber glass cloth (murries or any decent auto parts store)
Fiber glass resin (again murries or auto parts store)
Very cheap paint brushes (mijer or any variety store)
Paint mixers
2L bottles
Bondo (murries ect.)
glazing putty
Putty appliers
sand paper all sorts ad varieties (mijer)
tin foil (moms pantry)
masking tape
thick plywood (MDF=medium density fiberboard works best)
electric jigsaw
Wood dowel
Hot glue gun
Spray primer
Scissors
Latex gloves
ok that being said lets begin.
This process is great for making one-off custom boxes and enclosures.. Its especially great if you have some trickey places that you want to locate this stuff in. My project is relocating the rear speakers and adding the cd changer on the rear deck. Keep in mind while going thru this, this example is the first time I attempted this so what you see is what I went thru when I was in your position.
The Lay out.
figure out what you want to put where.
You will need to plan out the size of each component and how you are going to mount it to the finished enclosure.
Little prep work;
while wearing some gloves, cut up one of your fiberglass cloths into strips of all shapes and sizes. fiber glass is very itchy so if you donít wear gloves you will regret it later.
The components forms.
It is best to make a form or a mounting bezel for each component you want to mount out of your MDF. Make sure to account for how you are going to secure the component to the bezel and if you want it flush mounted or not. I cut two rings of mdf for each speaker I wanted to mount, because I wanted them to be recessed under a grill when it was all done.
the first ring was to be the base that the speaker was to be mounted to, the second goes around the speaker to give us the recess. It is easiest to use your jigsaw to cut out 4 half rings rather than trying to cut the full rings (also a better use of material).
I find it very handy to make your mounts first to help with the layout.
Picking your base.
once you have your mounting surface picked out and you have figured out how you want to locate we are going to make our enclosure base.
Take your tinfoil and masking tape and cover the area you wanted to be your base. Make sure you cover the entire area, overlapped the tinfoil on all seems and masking taped every one. Also be sure to cover a little over the area you want.
If you are doing this project overtop of any fabric or any thing you donít want ruined you might want to wrap the area in plastic wrap first.
Once you have every thing wrapped and waterproof mix up some of your resin (as directed on the bottle). Make sure you mix it up in a plastic bottle (2L pop bottle works best) do not use a metal can.. The metal speeds up the curing process.
while wearing gloves take one of your cheep-o brushes and slap some of that resin down on your tinfoil and lay fiber glass strips on top of it. Keep doing this and over lapping until you have about 3 layers of fiberglass down in a crisscross pattern. You donít have to leave much time between layers, just go to town.
Allow it to set over night.
Placing the components.
Peel the tinfoil and what ever else stuck to the back of the base and trim the base to what size and shape you want your finished base to be.
Next with your dowels, and hot glue gun locate your MDF bezels where you want your components to be on the base.
Stretching the skin.
With the bezels in place take your flees fabric and cut it to size. You want to cut it so that way the fleece will cover the entire enclosure with enough to still wrap around the bottom of the base.
The fleece will be the outer most layer of your enclosure so it is important to keep it tight and wrinkle free from this point on.
Use your hot glue gun to tack the cloth down around the bezels.
Donít worry about the openings for the components, you can cut those later.
Once the cloth around the bezels is tacked stretch and glue the cloth around the bottom of the base. Once your cloth is stretched and adjusted the way you want it, mix up more resin and apply it very liberally to the fleece cloth.
Allow to dry over night.
dont forget to test fit when the outside is dry.
Support.
Cut the bottom out of your base.
remove all your dowels.
Mix up more resin and start applying strips of fiberglass on the back side of your enclosure! About 5 layers will support some ones body weight so you donít need to get too carried away. Make sure you lay some strips supporting the bezels to give them strength. allow to dry over night.
cutting out components and finishing.
Using a utility knife cut out where the components are located. If you happen to have a dremmel and a cut off tool that works a lot better.
right now you have a rough surface in the correct shape you want your box to be. If you have wrinkles and such, the more time you spend here fixing them the better you will be.
Mix up some bondo and apply a nice Ďtightí layer of bondo.
allow it to dry completely.
sand it down and start to define your rough features.
repeat this as many times as it takes to get your overall shape smoothed out.
once thatís done apply one nice thin layer of glazing putty and using fine sand paper smooth it all out, after it dries that is.
once that is done and looking good prime it up.
this can be a bit disappointing because it will show any imperfection...
Fix theses imperfections by repeating any of the above finishing steps.
Paint, place and install as you see fit..
Well thatís it. this is how I made my box and I couldnít be happier with it.
How do I make a sealed box?
Easy.
Instead of cutting the bottom out of the base instead cut it where ever you want your Ďseemí to be, lay your support glass, then use a thin strip of fleece or fiber glass to rejoin the two halves. You will have to do a little more work to make this happen but if you do it right no one will be able to tell the difference.
Hope this has helped every one out.
If you have any questions please let me know, and I will help you best I can.
[email protected]
rst4me is offline   Reply With Quote
Old 03-09-2006, 01:40 AM   #2
MoJack
Member#: 90276
'05 Sti:Crystal Met
is my drug of choice.
Damn thats kinda clean. Good solution for an sti seeing as how there are no speakers back there and you dont take up much space. Nice write up mang thanks!
(Getting Ideas)
Edit: those are just components? Thought they were subs
MoJack is offline   Reply With Quote
Old 03-09-2006, 01:47 AM   #3
rst4me
Member#: 108286
My friend was laughing at me about that.
"you are the only guy I know of that will go thru all that work just to put crap componets back in it"
I didnt know how much it would rattel so I didnt want to go over board. That and if I were to put subs up there I would have to find out where to put the componets..
I definetly have ideas for the trunk area. Pritty much this method on a bigger scale
I suggest starting with some small project to get ahold of the method.
Then go wild!
Old 03-09-2006, 09:00 AM   #4
SilentShadow
Member#: 46684
2002 Impreza 1.6
Metalic Silver
That is some nice work!!! good for you man!
SilentShadow is offline   Reply With Quote
Old 03-16-2006, 01:19 PM   #5
rst4me
Member#: 108286
just hope it helps or encourages some one else to take a stab at it.
Old 04-21-2006, 02:31 AM   #6
SilentShadow
Member#: 46684
2002 Impreza 1.6
Metalic Silver
Just wanted to say that I have decided to copy your work just for fun it will be my first time at fiberglassing to hope all will go okay! thanks for all that info man!
Old 04-29-2006, 11:32 AM   #7
rst4me
Member#: 108286
Old 04-29-2006, 05:01 PM   #8
Blind_man
Member#: 113688
Originally Posted by rst4me
Like I said, if you ever have any questions feel free to ask]
That looks great, but i'd be worried about vibration and flex. I wouldn't imagine having a problem without a subwoofer, but if you go the traditional route and put a sub box in the trunk I think your going to run into problems with that big piece vibrating and flexing. That could quickly kill your cd-changer.
Blind_man is offline   Reply With Quote
Old 04-29-2006, 09:25 PM   #9
rst4me
Member#: 108286
cd changers are mounted internally to dampers. Basically take a look the next time you eject your cd cartrige, the whole thing appears to be floating in there. Basicaly if the cd changer ant skipping you should be fine.
That and the medium density fiber board cuts down on alot of it.
My enclosure is darn ridged, I used about 4-5 layers and I can stand on the thing without it flexing. I would be very supprized if it ever cracked or any thing like that with that many layers, but any thing is possible I guess.
I wouldnt recomend strapping a changer to the side of a 10" or something like that. But I think between two 6"es would be fine.
Old 04-30-2006, 12:07 AM   #10
Blind_man
Member#: 113688
It's not the 6" ers im worried about. Do you plan on putting subs in the trunk? I don't know how well the rear seats seal in a Subie but if they seal well and you don't port that back deck you just made the pressure will have nowhere to go. And while Cd changers have improved they're still not great and hardly ever warranteed for vibration issues.
Old 04-30-2006, 01:53 AM   #11
rst4me
Member#: 108286
actully no.
Im going to split the rear seats and put in a devider box between them which will house 2 small subs which should push enough for my taste.
I will let you know if my changer dies but I doubt it will be an issue seeing how as I have had this in the rear deck box sence last summer, and it was mounted to the side of a box with 3 10"s.
Know its not the same thing because that box was mdf but I dont think it will hurt it.
Vehicle Generation Codes made easy? cyberbackpacker Legacy Forum 7 12-09-2005 01:09 AM
Blow Through MAF made easy Bluesmaster Engine Management & Tuning 6 10-07-2005 09:32 AM
Repenting Made Easy! Grap Off-Topic 4 09-07-2005 11:33 AM
engine mount install made easy JohnW Transmission (AT/MT) & Driveline 0 02-09-2004 01:17 AM
DIY CLEAR CORNERS MADE EASY!!!!!!!! BrysImpreza Interior & Exterior Modification 13 02-04-2001 05:05 PM
