Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 10-22-2005, 11:31 AM   #51
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
Even if you cut them to fit and doubled them up?
Trunk_Monkey is offline   Reply With Quote
Old 11-03-2005, 06:49 PM   #52
lawn boy
Member#: 16345
2003 WRX- Sold
E60 BMW 545i
what about the clock LED is this listed
lawn boy is offline   Reply With Quote
Old 11-03-2005, 10:18 PM   #53
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
No real way to do it except replace the clock, some have tried painting the screen with glass stain but its real dark.
Old 11-09-2005, 04:47 PM   #54
Mesatchornug
Member#: 78292
2002 PSM Impreza RS
Red '99 Ducati ST
RE: Clock
Sadly my poor suby's in the shop or I'd have looked at this already: is the green the result only of the glass being grteen, or is the display actually glowing green too? if it's just the glass, why have none of us tried replacing it with a new piece of glass in the color we want?
The basic solution I have in mind consists of going to Home Depot and buying a sheet of plexi ~ as thick as the glass and sandwiching theatrical gel between two pieces, or simply gluing a piece to the back side of one piece about as thick as the glass. cut to fit as necessary and you have an instant pane in the polor you want without dealing with the old stuff being green.
I'm hoping to try this step first this weekend, when I have my baby back.
And thank you Trunk_Monkey for all of these write-ups, I'm hoping to use them soon.
Mesatchornug is offline   Reply With Quote
Old 11-09-2005, 05:02 PM   #55
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
If you really dont plan on replacing that clock with some guages you can buy an evo clock and put it in there. One guy did even did a mod that showed temp and time so its doable.
Old 11-09-2005, 07:03 PM   #56
C43
Member#: 95586
2004 AquaMist Inject
PSM Deadbolt 361WHP SZ49
Very easy in my 04. Took ten minutes
C43 is offline   Reply With Quote
Old 01-29-2006, 11:27 PM   #57
tminus10
Member#: 101574
03 WRX Wagon
WR Blue
I just did this mod on 03 and 04 WRX and just wanted to let everyone know that if you arent comfortable with your soldering skills, its not neccessary to melt the solder and completely remove the metal frame around the display panel on the stereo. One can just straighten out the tabs as described and pull the frame off and bend it down to access the bulbs. Then just push it back up and onto the display panel.
tminus10 is offline   Reply With Quote
Old 02-28-2006, 04:55 PM   #58
kokob
Member#: 62135
2005 STi
AW
trunk monkey is honestly GOD!!!!!
kokob is offline   Reply With Quote
Old 04-05-2006, 12:15 PM   #59
some dude
Member#: 100300
06 WRX
CGM
Well the website that trunkmonkey gives at the beginning has been sold out of red bulb covers for the last 2 months. And they were supposed to be in stock as of 3/31/06. But now they are out of stock until like 4/20 or something. Is there any place that sells .2" red bulb covers because i can't find any?
some dude is offline   Reply With Quote
Old 04-05-2006, 06:13 PM   #60
slowscooby
Member#: 69520
- '05 STi
"White Thunder"
I think I saw another write up that someone used replacement red LEDs. Anyone have a link?
slowscooby is offline   Reply With Quote
Old 04-05-2006, 07:51 PM   #61
MarylandEcstasy
Member#: 103518
2011 Subaru WRX
I was under the impression that the orange bulb condoms would look as good as the red may, plus be a bit bright for my taste, and they're great..I love them. I don't have an STI cluster yet but the bulb color should match it well.. thats just me though against personal preference, red is always a good choice opposed to orange, just a little too dark IMO.
MarylandEcstasy is offline   Reply With Quote
Old 04-09-2006, 07:46 PM   #62
shadow46x2
Member#: 90160
2010 WRX Limited
GMB
anyone have any additional pics of the blue backlighting?...the blue/yellow combo earlier looked sweet, and was curious to see a few more examples of it...
also, anyone who has done blue....how does the double-bag look?...how dim is it as well?
--j
shadow46x2 is offline   Reply With Quote
Old 04-09-2006, 09:37 PM   #63
antidote11
Member#: 31074
'06 WRX TR
CGM
Do the LEDs instead of the bulb rubbers. They look much better
and are much brighter.
antidote11 is offline   Reply With Quote
Old 04-09-2006, 09:48 PM   #64
vf22-wrx
Member#: 100878
I scraped off the film and custom made all my LED fitting and it looks killer!!!...I also am making a fade (because I scraped the green film and factory fade off the cluster) and I am going to slip it behind the number cards and it will look killer...I'll post pics when I get around to it...so far, blue LED's is good!
vf22-wrx is offline   Reply With Quote
Old 05-14-2006, 01:34 AM   #65
intence
Member#: 58477
. Member #1 of
the witty MS Crew
has anyone who has used the red condom method care to post up any pics?
intence is offline   Reply With Quote
Old 05-14-2006, 11:57 AM   #66
Jonnyfilmboy
Member#: 68902
2011 WRX - WRBM
1988 Fiero GT - black
Check out the first post. Those are red condoms.
As for the red LED replacement in the radio, has anyone done that? I figure it will take some soldering but shouldn't be too hard. Just scary.
The writeup for the bulb to LED in the HVAC, keyring and instrument cluster panel is here:
http://www.scoobymods.com/forums/showthread.php?t=2854
Jonnyfilmboy is offline   Reply With Quote
Old 05-14-2006, 12:48 PM   #67
turbo tecnica
Member#: 74470
2013 Accord Sport
72 LS1 Vette
I just did this mod in my STi this last week, looks great. I did the OEM boost gauge, key ring, radio + screen, and HVAC. Had to trim the bulb covers a bit but it wasn't a problem. I double-bagged them except for the boost gauge. They are a little dark at night but I know where everything is so it's not really a problem... looks 100x better than the green too. Thanks Trunk_Monkey for the write-up on all of these.
turbo tecnica is offline   Reply With Quote
Old 05-15-2006, 12:36 AM   #68
intence
Member#: 58477
. Member #1 of
the witty MS Crew
yeah i saw that i just want to see some better pics since some said it looks more orange than red.
Old 05-15-2006, 12:44 AM   #69
InfamousDX
Member#: 25413
I have 3 of the small bulb covers and 8 of hte big ones... I know you guys want em Anyone?
InfamousDX is offline   Reply With Quote
Old 08-11-2006, 03:31 AM   #70
0BlueSTi4
Member#: 98955
2011 WRX Hatch
Originally Posted by Trunk_Monkey
WOW this is really good man! I am doing the key ring and HVAC on my STi would love to change the factory boost too any idea when you will have that guide out? Thanks!
0BlueSTi4 is offline   Reply With Quote
Old 08-11-2006, 03:54 AM   #71
MarylandEcstasy
Member#: 103518
2011 Subaru WRX
Old 08-11-2006, 05:49 PM   #72
0BlueSTi4
Member#: 98955
2011 WRX Hatch
So two questions:
Has anyone had those red bulb "condoms" on for a long time. Say a few years? I noticed someone mentioned they fade to orange with time. Can we get a little vote going on here to see how long you had them for and if they faded?
Also, sounds like double bagging them makes red too dark. Has anyone tried using 2.3watt bulbs (#2723) for key ring and HVAC and not just the factory boost gauge? Also, I'm wondering why you guys are double bagging those in the first place? Is it too bright, too orange with only a single "condom"?
The reason I'm asking all thise is because I want to get this right the first time and have all the lights match the STi gauge cluster as closely as possible. Also, I would like to know how many extra wattage bulbs to get.
Thanks ALL for any input! Really appreciate it!
Old 08-11-2006, 07:07 PM   #73
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
They only fade to orange if they slip off and let white light through, take the bulbs out and check for that.
Old 08-28-2006, 10:53 PM   #74
0BlueSTi4
Member#: 98955
2011 WRX Hatch
How did you do the HVAC one???
I tried doing the HVAC today and discovered that the back of the HVAC looks totally different then what is pictured here. Also, instead of there been 2 bulbs there are actually 4 of them and the worst part is that they are smaller so the .2 bulb covers do not fit. The bulbs were smaller then the ones found on the OEM turbo gauge or the key hole ring. Each individual bulb sits in a plastic holder which in turn screws into the HVAC. When I tried to slip .2 covers over the bulb and on top of the plastic holder the covers stayed on but the bulb would not fit into the mounting hole in the HVAC. So basically I had to put everything back together the way it was and call it a day.
Anyone else have that problem on 04? I guess I might have to get the .12 bulb covers instead and try my luck with those.
Old 08-29-2006, 10:57 AM   #75
OBiWrX_3zero3
Member#: 113481
2005 STI
Crystal Grey Metallic
Where's the thread to the the 05-06 STI's?
OBiWrX_3zero3 is offline   Reply With Quote
Interior Color Change Tutorial: Gauge Cluster Trunk_Monkey Electrical & Lighting 768 05-20-2015 04:45 PM
Interior Color Change Tutorial: Key Ring Trunk_Monkey Electrical & Lighting 71 03-02-2015 05:42 PM
Interior Color Change Tutorial: OEM Boost Gauge Trunk_Monkey Electrical & Lighting 62 05-16-2013 08:02 PM
Instrument Cluster, Radio, and HVAC color change murph32 Electrical & Lighting 7 08-11-2008 04:50 AM
Interior color change tutorial: Clock WejR20X Electrical & Lighting 9 11-07-2006 03:52 AM
