Welcome to the North American Subaru Impreza Owners Club Saturday December 3, 2016
View Poll Results: How often do you clean your MAF sensor?
Once a month or more 23 3.50%
When i change my oil 91 13.85%
When it needs it, I can tell by my EM or my butt dyno 159 24.20%
NevAR 387 58.90%
Multiple Choice Poll. Voters: 657. You may not vote on this poll
Old 06-06-2006, 02:14 AM   #1
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Default How often do you clean your MAF sensor?
I would like to know how often you clean your maf sensor. I usually do mine about once a month or so.
modaddict is offline   Reply With Quote
Old 06-06-2006, 02:16 AM   #2
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
I've never cleaned mine
UndertoW101 is offline   Reply With Quote
Old 06-06-2006, 02:21 AM   #3
Calitri-Boost
Member#: 109090
08 IS-F
WFC Mbr # 004
If you have a dry type air filter you wont need to clean it near as much.
Calitri-Boost is offline   Reply With Quote
Old 06-06-2006, 02:56 AM   #4
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I try to do it somewhat regularly which I would say is about once quarterly.
FYI, CRC's "MAF Sensor Cleaner" product, at $5.99 a can, is 100% identical to their "QD Electronics Cleaner" at $3.99 a can.
nhluhr is offline   Reply With Quote
Old 06-06-2006, 02:57 AM   #5
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Not true. Bone stock STI with 2000miles, still with stock filter - and the MAF sensor was filthy when I pulled it out to swap the intake.
Old 06-06-2006, 04:39 AM   #6
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
once a year
jigga is offline   Reply With Quote
Old 06-06-2006, 08:52 AM   #7
jays05
Member#: 78165
05 STI 35r + e85
I usually do mine about a week after cleaning the filter.
jays05 is offline   Reply With Quote
Old 06-06-2006, 03:17 PM   #8
Illusive
Member#: 90436
2005 STI
Obsidian black pearl
brake clean for 1.69 a can ftw.
you should clean your maf before you get any kind of tune, and before / after doing mods to the car, and generally speaking once per oil change is enough to keep it clean and reading properly. (typically 3-4 mo)
Illusive is offline   Reply With Quote
Old 06-06-2006, 03:22 PM   #9
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
check the ingredients on brakleen. It is definitely NOT the same and not very safe for the plastic and rubber on the maf sensor.
Old 06-06-2006, 07:34 PM   #10
modaddict
Member#: 95840
sold to a good bud
awaiting next car
I just cleaned my MAF w/ brakekleen. I will agree it will eat plastic and swell rubber, thats why i didnt spray any on the o-ring. I think ill invest in some other type of cleaning solution though.
Old 06-06-2006, 07:35 PM   #11
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
just fyi - if you do mess up that little o-ring, replacements are hard to find. i had to resort to using a completely different o-ring and "making it fit"
Old 06-06-2006, 07:53 PM   #12
Evil STI
Member#: 36792
2015 Z/28 (Vader)
Gold chains & meatballs
Every 3000 miles or less. Something so simple shouldn't be overlooked.
Evil STI is offline   Reply With Quote
Old 06-06-2006, 07:55 PM   #13
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
does cleaning it so often damage the MAF?
silver arrow is offline   Reply With Quote
Old 06-06-2006, 08:01 PM   #14
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
not if you do it correctly.
which means:
-carefully remove it from the intake
-spray cleaner onto the IAT probe (the part you can see that looks like a tiny kernel of red corn)
-spray cleaner indirectly up into the hollow of the tube to clean the heater wires. You should avoid blasting the heater wires directly, as it could damage them somehow.
-let air dry
-carefully replace MAF, beign sure to get it pointed the correct direction (plug in front, not in back)
-reset ECU to clear out the AF Learned trims
Old 06-06-2006, 08:13 PM   #15
modaddict
Member#: 95840
sold to a good bud
awaiting next car
which means:
-let air dry
+1^^^^
and im really surprised that 'most' people that have polled do not clean their MAF. I guess as a Ford tech, and seeing how many engines have been DESTROYED by faulty MAF sensors...I am over cautious.
BTW, by DESTROYED, it has ALWAYS been from an engine running lean. 'usually' from dirty air filters (lack of maintenance by the customer) and/or oil bath filters.
Old 06-06-2006, 08:15 PM   #16
Phil Jr.
Member#: 62221
can I just dip it in rubbing alcohol?
Phil Jr. is offline   Reply With Quote
Old 06-06-2006, 08:18 PM   #17
modaddict
Member#: 95840
sold to a good bud
awaiting next car
DoOd...look 2 posts up
LOL, you edited before i posted
not sure about rubbing alky, dont see why not though
Old 06-07-2006, 12:06 AM   #18
bigmike25rs
Member#: 83924
2005 HTA 86 STi
10.66 @ 136 mph
FWIW, with my blow-through setup, any blow by from the turbo can also dirty the MAF. My car was running almost a full point lean under boost (12.1). I noticed a black spot on the MAF and that cleared it up. I was convinced a line had popped off... Wish I had checked the MAF sooner...
bigmike25rs is offline   Reply With Quote
Old 06-07-2006, 12:12 AM   #19
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
i'd say do it every oil chnage or every other. +1 from a tech that's seen his fair share of bad maf sensor problems that could of possibly been avoided by keep ing it clean
vtecTHIS is offline   Reply With Quote
Old 06-07-2006, 12:53 AM   #20
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
I think resetting the ECU is not nessessary and counter productive. The small varience will be quickly corrected by the ECU and you won't lose the learned knock correction.
Old 06-07-2006, 12:54 AM   #21
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
knowing that it takes at least a couple days for the trims to normalize to where they need to be, you should definitely reset the ECU when cleaning, especially if you plan to be getting tuned the next day, driving hard, track day, etc...
but for run of the mill driving around, i agree, no need to reset it.
Old 06-07-2006, 01:53 AM   #22
Calitri-Boost
Member#: 109090
08 IS-F
WFC Mbr # 004
It can be true when people buy K&N or other brand oiled filters and load them up with way too much oil. The MAF will get dirty very fast and the car will run like poop.
Old 06-07-2006, 05:35 PM   #23
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
That isn't nessessarily the opinion of a number of respected tuners in these forums. Most recommend not to reset if the changes you made are small. The car will make small adjustments within seconds of driving.
Old 06-07-2006, 06:31 PM   #24
Phil Jr.
Member#: 62221
ok i popped out my maf and it looked clean as a whistle, as in brand new. ANyone got a pic of a dirty one??
Old 06-07-2006, 06:32 PM   #25
Evil STI
Member#: 36792
2015 Z/28 (Vader)
Why play devil's advocate when a 10 second reset 'wipes the slate clean'?
The ECU doesn't learn within seconds. It takes a minimum of four key cycles for it to maximize effeciency and/or power output.
How often do you change your synth oil in your wrx D-I-Z-Z-L-E Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 58 12-03-2012 09:30 PM
How often do you wash your hair (if you have any)? HoRo1 Off-Topic 33 12-02-2003 04:22 PM
How often do you clean your K&N/reusable air filter??? megatron Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-18-2002 12:05 PM
how often do you wash your car? inpreza kid Canada Region Forum 12 02-24-2001 06:07 PM
How often do you clean your rims? John2.5RS General Forum Archive 12 05-22-2000 09:02 AM
