Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 06-18-2006, 07:49 PM   #1
subeman90
Member#: 65681
13 XV Limited
gray
Default seatbelt beep...make it stop!!!!!
ok so I have this 06 right...you know the chime that goes when the seatbelt isn't hooked....I don't have a problem with it per se but I have a real problem with it beeping and the car not moving and having the ebrake on. The wife wants it killed and to be honest with you...so do I.
Oh great people of the baja....guide me to the death of the seatbelt beep. FWIW, I really don't want to kill its other functions as I feel it is there for a reason but beeping at me in a parking lot with it running is total BS.
subeman90 is offline   Reply With Quote
Old 06-18-2006, 08:50 PM   #2
04turbogurl
Member#: 55662
2004 Baja Turbo 5spd
Mystic Blue w/ stickers:)
hook the seatbelt.. thats what i do when i am the passanger...
-kelz
04turbogurl is offline   Reply With Quote
Old 06-19-2006, 09:32 AM   #3
rexspeedworthy
Member#: 26965
2013 XV crosstrek
goto junkyard, find another seatbelt and just get the portion you shove into it. leave it in the consol until needed to stop the noise??
rexspeedworthy is offline   Reply With Quote
Old 06-20-2006, 11:20 AM   #4
Spacinjason
Member#: 110407
'06 Baja Turbo MT
Cool
If you turn on your ignition (but don't actually start car) and you click and unclick the seatbelt like 20 times in about 30 seconds then start the car and turn it off. Seriously, try it. I read it on USMB or Scoobytrucks and tried it on my '06 Baja T MT. It worked! I still get the initial like 6 beeps when I start the vehicle, but it stops after that. That was a very annoying feature in our vehicles! Good luck and let us know if it works.
Spacinjason
Spacinjason is offline   Reply With Quote
Old 06-20-2006, 01:24 PM   #5
subeman90
Member#: 65681
13 XV Limited
gray
so far so good.....I didn't leave the parking lot yet (i'm at work) but in inital tests it looks like the beep is gone....of course I look like a total jack doing the seatbelt 20x in a row but whatever it takes right...
Thanks dude!
Old 06-20-2006, 01:59 PM   #6
cnw
Member#: 98395
PM r0bman for
parts discounts.
so glad the 05's don't have that annoying crap
cnw is offline   Reply With Quote
Old 06-20-2006, 03:51 PM   #7
mjalex007
Member#: 66022
2005 Baja Turbo
I'm glad you said that, because I didn't know what he was referring to... I also have an 05.
mjalex007 is offline   Reply With Quote
Old 06-20-2006, 05:07 PM   #8
joecerv
Member#: 110459
2006 Impreza 2.5i
Steel gray metallic
Just a small note.
If the battery is disconnected, the seat belt warning comes back.
Just do the same procedure again.
joecerv is offline   Reply With Quote
Old 06-20-2006, 08:26 PM   #9
subeman90
Member#: 65681
13 XV Limited
gray
actually it did it again....i got to see if it is really gone or if the 20 click thing is just a one time deal. I took the belt off as I drove down my alley and it started beeping...hmmm I'll drive it with it off tomorrow and see what happens.
Old 06-21-2006, 07:00 AM   #10
Spacinjason
Member#: 110407
'06 Baja Turbo MT
Smile
Cutoff Function for Seat Belt warning chime
(Works for the 2005 Outbacks and Legacys, too)
Warning: I am in no way responsible for anyone’s safety...just posting this as a convenience.
1. Turn the key to “ON” (not running).
2. Fasten and unfasten the driver’s seat belt 20 times in 30 seconds, starting from when you actually turn on the key. (This will set the passenger seat as well).
3. Turn the ignition on, and you should be set.
4. Setting lasts until the battery is disconnected or the system is otherwise reset.
5. If you want to do this as a temporary thing (just for one driving period), fasten/unfasten the belt 3 times in 6 seconds. The chime will reset the next time the car is started.
I got the above info from Scoobytrucks. If you go there to the Baja forum, you will find info on the seatbelt chime. The first time I did it I had tempory success, but chime returned the next day. Second time I did it was a success as I only get an initial six second chime when I start Baja.
Maybe I told you incorrectly about starting engine after clicking and unclicking the seatbelt twenty times. I could have swore that was the last step I took, but hey there's a reason for the name spacinjason ! Good luck, let us know how it works out for you.
Spacinjason
'06 Baja T MT
Old 06-24-2006, 01:06 PM   #11
subeman90
Member#: 65681
13 XV Limited
gray
justr wanted to revist this: I did it again and it wored this time.... Maybe I only did it 19x before
Thanks Jason and BTW, I am going to copy this over in the USRM on USMB so if anyone over there ever needs this info....
Old 06-24-2006, 02:55 PM   #12
bklynbaja
Member#: 106911
06 BAJA/ 95 SVX
IT'S ALL WE'LL DRIVE!
Default seatbelt chime
I did this for my '06, and it works, but I would like to add that you don't have to clip & unclip the seatbelt. ( it will look funny to someone )
All you have to do is just press the red release botton 20 times. Alan
bklynbaja is offline   Reply With Quote
Old 06-28-2006, 07:13 AM   #13
Spacinjason
Member#: 110407
'06 Baja Turbo MT
Cool
That's a great idea, wish I would of thought of that. I did feel like a dork clipping and unclipping the belt! Thanks for the input!
Spacinjason
Defiant Suspension and Brake sale. Make it handle, make it stop! Defiant Autospeed Suspension/Brakes/Handling 48 03-25-2009 10:16 AM
MEGAN GTSPEC POWERSLOT. Make it handle, make it stop! Defiant Autospeed Suspension/Brakes/Handling 15 11-08-2007 03:52 AM
My window sqeals, how do I make it stop? SOneil0387 General Community 5 12-06-2004 12:39 PM
Make It Stop CandyO Off-Topic 30 02-23-2004 01:42 PM
MAKE IT STOP..... "teh" threads gone crazy... rhdude Off-Topic 22 04-01-2003 10:01 PM
