Old 06-28-2006, 12:19 AM   #26
circaisdashiat
Member#: 96315
1995 STi V5 replica
World rally blue
ok i need to clear this up for me, sorry im a nub.
if the turbo spools up during acceleration and then when you release the gas pedal and close the throttle the turbo should still be spinning, de-accelerating but still spinning. so air is still being forced into the intake, building pressure. what if your blow off was venting the same amount of air (into the atmosphere) as the turbo is pushing into the intake? wouldnt that not alter the PSI rating what so ever in the intake? plus when you let off the gas pedal, it doesnt not matter what the MAF sensor is reading because its not going to be injecting any fuel into the pistons anyways?
circaisdashiat is offline   Reply With Quote
Old 06-28-2006, 12:29 AM   #27
Davenow
Member#: 23676
You are always injecting fuel into the cyls, what do you think makes the car idle? And once the maf has read the air coming in, it is going to inject fuel for that air, regardless of the throttle position.
If you had no bpv or bov, when the throttle plate closed the air pressure would hit it, create a shockwave that would slam pressure back into the compressor blades in the turbo.
SO you lift off the gas, the throttle plate closes, and INSTANTLY there is vacuum in the manifold (because all the boost pressure in it has been eaten up by the motor, and what the turbo is still making is in the pre throttle intake tract) and that vacuum sucks the valve open. The valve is on the pre throttle side of the intake tract, so that boost pressure gets vented out before it slaps back into the compressor blades.
Old 06-28-2006, 03:00 AM   #28
circaisdashiat
Member#: 96315
1995 STi V5 replica
World rally blue
so are you saying that if it vented out (into the atmosphere) jsut enough to stop the shockwave then the engine would never run rich? why would they make an atmospheric BOV if they always make you lose power and waste gas?
Old 06-28-2006, 03:31 AM   #29
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
They sound cool and people continue to buy them. Also, not all engine management tunes for recirc.
They make and sell a metric ton of throttle body spacers for fuel injected vehicles that do not one bit of good at all. Why? Because they can.
CosmoTheCat is offline   Reply With Quote
Old 06-28-2006, 02:36 PM   #30
circaisdashiat
Member#: 96315
1995 STi V5 replica
World rally blue
hahaha ok thanks, its a bit clearer for me now.
Old 06-29-2006, 03:30 AM   #31
circaisdashiat
Member#: 96315
1995 STi V5 replica
World rally blue
What about Hybrid BOV's are those better than the stock BPV or does it not do anything either?
Old 06-29-2006, 03:38 AM   #32
veightkiller
Member#: 78967
2011 335i
what's the difference between the hybrid and the rest of the BOV? I dont see any unless your making alot of boost and yet the air need's to be recirculate not vented
veightkiller is offline   Reply With Quote
Old 06-29-2006, 09:33 AM   #33
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Hybrids are discussed in the main post folks. They suck just like regular BOVs. If you want noise part of the time, get one.
Old 06-30-2006, 10:24 AM   #34
biker921
Member#: 118236
Default Rich Fuel
With the BPV's re-using the air, is the fuel still as rich as using the BOV's?
biker921 is offline   Reply With Quote
Old 07-07-2006, 05:03 PM   #35
modaddict
Member#: 95840
sold to a good bud
awaiting next car
bump...
modaddict is offline   Reply With Quote
Old 07-07-2006, 06:00 PM   #36
WarHawk187
Member#: 58518
04 WRX
bump because there are 6 topics in this particular forum all asking about damn bov's
WarHawk187 is offline   Reply With Quote
Old 07-07-2006, 06:17 PM   #37
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
AKLGT's Living Accessory
bump to make this a permanant sticky
EvolvedAK is offline   Reply With Quote
Old 07-07-2006, 06:28 PM   #38
Petrus
Member#: 71795
2006 Impreza WRX5spd
FREAKIN' BLUE!!!
Bump, put it at the top dagnabbit! This is ridiculous!
Petrus is offline   Reply With Quote
Old 07-07-2006, 06:32 PM   #39
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
yeah its Fu**ing insane!!! like i said its a freaking plague!! WTF!
Old 07-07-2006, 06:50 PM   #40
athakur999
Member#: 88307
2005 Saab 9-2x Aero
Arctic Silver
Nick needs to make the manifesto required reading as a criteria for registration on this board. You'll have to pass a 20 question test before you're allowed to post
athakur999 is offline   Reply With Quote
Old 07-07-2006, 07:19 PM   #41
sleestak6326
Member#: 100040
2016 WRX
Ice Silver Metallic
bump again. keep this at the top
sleestak6326 is offline   Reply With Quote
Old 07-07-2006, 07:23 PM   #42
veightkiller
Member#: 78967
2011 335i
bump for all the people thinking about getting one!
Old 07-07-2006, 08:01 PM   #43
affinity1
Member#: 97266
'15 Forester 2.5i
Touring DGM
never let this thread die
affinity1 is offline   Reply With Quote
Old 07-07-2006, 09:53 PM   #44
enXiks
Member#: 69363
2004 WRX
For the sake of mankind
BUMP
enXiks is offline   Reply With Quote
Old 07-07-2006, 11:15 PM   #45
tjwilke
Member#: 84537
2008 LegacyGTLimited
Originally Posted by enXiks
BUMP FOR 2006wrxWagon
kthx
YES!!! BUMP FOR STICKY WITH BIG RED LETTERS!!!!
tjwilke is offline   Reply With Quote
Old 07-07-2006, 11:17 PM   #46
Bio Retard
Member#: 104057
2005 WRX
Default Omg
Bio Retard is offline   Reply With Quote
Old 07-07-2006, 11:41 PM   #47
DZKSTI
Member#: 116670
02 wrx/sti
black
the mod for holding more boost is only for wrx's and not sti's? can you get the sti to hold more boost?
DZKSTI is offline   Reply With Quote
Old 07-07-2006, 11:51 PM   #48
DeezNutz1833
Member#: 67491
2015 WRX
Crystal White Pearl
There should be a letter that all new members have to read before they get a log in name that states, "THE SEARCH BUTTON IS THERE FOR A REASON"
DeezNutz1833 is offline   Reply With Quote
Old 07-08-2006, 01:24 AM   #49
DZKSTI
Member#: 116670
02 wrx/sti
black
i did a search and no resaults where found..so can i get more boost out of the stock one or not?
Old 07-08-2006, 11:47 AM   #50
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
No. You need to read the post again. BPV/BOV that 100% recirculates = 100% fine. Anything else = rich.
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 296 02-15-2016 03:16 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 07:49 AM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 317 09-03-2015 08:56 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 110 07-02-2015 11:25 PM
