Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 08-22-2006, 09:44 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default 2006 WRX Turbo Combos, Forged internals, Helix Injectors, Helix Cams, & More!!!
HEY GUYS,
HELP US CLEAR UP OUR WAREHOUSE! It's a jungle in our warehouse!! hehehe
2006 WRX TURBO PACKAGE
-IHI VF34 Turbo
-Walbro Fuel Pump
-Cobb Access Port for DBW
-270whp / 275ft/lbs on 91 octane
$1499 Shipped!!
($1449 for non DBW WRX)
Helix 860cc Injectors & Cobb Access Port for STI
-Good up to 600HP on the stock fuel system (w/fuel pump & rails)
-Direct drop in injectors - requires only new clips (included)
-All components included, excellent spray pattern, on-times available
$999 Shipped!!
Perrin Master Cylinder Brace!!
-Billet 6061 Aluminum
-CNC Precision machined
-Designed to improve brake response by reducing firewall flex
$79 Shipped!!
Helix 264 Camshafts are back in stock!
Helix 264 Camshafts
-Excellent for larger than stock turbo applications
-Aggressive duration for big top end power
-Good idle
-High RPM capability with valvetrain
-Designed for WRX head use only (position pickup on cam gear)
$549 Shipped!
Helix 264 Camshafts & Titanium Valvetrain
-Good idle
$999 Shipped!
**Guys it has come to our attention that some less than experienced installers are dropping in camshafts without setting the valvelash and checking the cam journals. YOU CAN'T DO THIS!! MUST CHECK / SET FOR PROPER FITMENT!!
Gruppe-S EJ25 +2mm Long Rod Ratio Forged Component kit
-Helix +2mm Forged Connecting Rods for ARP L19 Rod bolts
-Wiseco custom specced forged Pistons for Long Rod Ratio engines
$1099 Shipped!!
Gruppe-S EJ25 Forged internal kit
-Helix Forged connecting rods with ARP L19 Rod Bolts
-Wiseco custom specced forged pistons 100mm (+0.5mm overbore)
$899 Shipped!!
Sale ends 8/31/06 or until supplies last. Thanks!
Gary
[email protected]
510-783-5300
510-783-4300 fax
Gruppe-S is offline
Old 08-23-2006, 08:22 AM   #2
spoolinsuby
Member Sales Rating: (1)
Member#: 80182
Look ing for a GG
Wagon
Helix 264 Camshafts
-Good idle
$549 Shipped!
Can these cams be used with USDM STi valvetrain with a 7500RPM limit?
I know how to check valvelash but what do you mean by checking the journals?
Thank you,
Frank
spoolinsuby is offline
Old 08-23-2006, 05:07 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Thank you,
Frank
Hi Frank,
Unfortunately these cams are not compatible with the USDM STI heads unless you disable the pickup sensor on the heads & AVCS. You will have to change out the cam gear also. As for the journals, sometimes our customers are failing to check for proper journal clearance, overtightening the journals, no oiling etc. This causes the cams not to rotate properly or scores the cams.
Thanks,
Gary
Gruppe-S
Gruppe-S is offline
Old 08-25-2006, 01:54 AM   #4
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
I'm using the STi motor in a WRX so I have already made the pick-up change. Will the STi valvesprings be good enough?
Old 08-28-2006, 08:15 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
While the STI springs / valvetrain does accomodate for a higher lift camshaft than the WRX, the valvetrain is also designed for a lower revving engine / valvetrain. I would recommend using an aftermarket valvetrain such as the Helix valvetrain for the camshafts. If you are planning to keep your revs low and to stay with the stock valvetrain, please remember to check your valvelash clearances, etc.
Thanks,
Gary
Gruppe-S
Gruppe-S is offline
Old 08-29-2006, 01:08 PM   #6
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
Ok thanks. I will let you know when I will be able to order them.
Old 08-29-2006, 03:23 PM   #7
bruiser63
Member Sales Rating: (6)
Member#: 109366
06 STI
Do you have a turbo package kit like that for the 02 wrx?
bruiser63 is offline
Old 08-29-2006, 07:56 PM   #8
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Yes we do:
IHI VF34 or VF22 + Helix Power 660cc Injectors + Walbro Fuel Pump
-390HP Capable on a WRX (with proper tuning)
-Includes Genuine IHI VF34 or VF22
-STi 565cc Pink Injectors
-Walbro 255l/h Fuel Pump
$1299 shipped for VF34 package!!!
$1249 shipped for VF22 package!!!
IHI VF34 or VF22 + STi 565cc Pink Injectors + Walbro Fuel Pump+Ecutek Reflash
-Send us your ECU and we'll reflash it and we'll overnight it back to you
$1999 shipped for VF34 package!!!
$1949 shipped for VF22 package!!!
IHI VF34 or VF22+ STi 565cc Pink Injectors + Walbro Fuel Pump + Installation + Ecutek Reflash + Custom Dynotune
-Please call to schedule an appointment
$2349 shipped for VF34 package!!!
$2299 shipped for VF22 package!!!
IHI VF34 - $869 Shipped!
IHI VF22 - $799 Shipped!
Thanks,
Geoff
Gruppe-S is offline
Old 08-30-2006, 04:45 PM   #9
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
Thanks,
Gary
Gruppe-S
Could I use valvesprings from another company? I'd rather not spend $450 on valvesprings if I could use Crower or DPR springs instead.
Old 08-30-2006, 09:30 PM   #10
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
That would work fine; you just need to make sure that the valve train you're using is ideal for the Helix cams.
Gruppe-S is offline
Closed Thread
SBR Deals! Rods/Pistons/Cranks/Cams/Turbos/Injectors/Bolt-Ons & More! Built Industries Engine/Power/Exhaust 3 11-17-2009 12:00 PM
02-03 Accessport, 750CC Injectors, Walbro FP & More! trustSTI Engine/Power/Exhaust 13 08-23-2006 06:19 AM
WRX engine, and forged internals questions verc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-24-2005 05:57 PM
Brembo, Helix, Eibach, Axxis, Tein & MORE ! ! Gruppe-S Suspension/Brakes/Handling 5 04-29-2005 04:00 AM
