![]() Mid Atlantic Impreza Club Forum sponsored by Annapolis Subaru |
#1 |
Vendor Sales Rating: (29)
Member#: 54202
Vehicle:ASK ABOUT NEW RCE SWAY BARS FOR STI |
Whiteline 27-29mm Front Swaybars - $195 picked up!!
![]() Cusco Front and Rear OS Strut Tower Braces - $150 each picked up!! ![]() Cusco 21 or 22mm Front Swaybars - $150 picked up!! ![]() Cusco 22mm Rear Swaybars - $150 picked up!! ![]() Cusco Type 2 Lower Arm Bar - $150 picked up!! ![]() Cusco Zero 2R w/ Pillowball Mounts - $2269 picked up!! ![]() Cusco Zero 2E w/ Pillowball Mounts - $1940 picked up!! $2340 w/ E-Con controller!! ![]() ![]() -Dan
#2 |
Member#: 54202
LEFTOVER STOCK ITEMS:
Swift STi Springs - $250 shipped Whiteline STi 24mm Front Sway Bar - $170 shipped (2) WRX 5MT Group-N Tranny Mounts - $55 shipped/each TurboXS CAI w/ K&N filter - $70 shipped Perrin Rear Endlinks - $90 shipped Whiteline Camber Bolts - $50 shipped Whiteline ALK Comfort - $170 shipped Cusco Legacy Type-OS Front Strut Bar - $145 shipped RCE Kool Brake Kits IN STOCK - $299 shipped (Black hose only) ATE Superblue Brake Fluid - $15 shipped Piloti Corsa Shoes, Size 12, Blue/Race Carbon - $150 shipped (Shoes fine, box damaged) Piloti G16 Shoes, Size 9, Black/Smoke - $65 shipped (Shoes fine, box damaged) Last edited by RaceComp Engineering; 10-23-2006 at 03:22 PM. |
#5 | |
Member#: 54202
mw |
#9 |
Member Sales Rating: (35)
Member#: 110932
SCIC
Vehicle:1999 e36 m3 titan silver |
I think the wagon has a different track. I'd call and check with them though. I'm curious as to what the actual answer is because I have a friend with an 04 wagon who would like my stock bar when I go to the 27.
#10 |
Vendor Sales Rating: (10)
Member#: 97303
Vehicle:2009 WRX and Boxster Gray and Black |
We do sell a 22mm wagon specific front whiteline sway bar. The 27mm front will more than likely fit as it has worked for most people but we will not accept any returns due to improper fitment on the wagon.
Mike |
#18 |
Member Sales Rating: (39)
Member#: 45464
Vehicle:91 E30 325i 95 E36 325is |
soooo tempted to upgrade from my 22mm cusco bar to the whiteline 29mm..... and the new shop is just a few minutes from my house making it easy to go pick this up.... dagger!
#21 |
Member Sales Rating: (15)
Member#: 10852
Vehicle:Then : JDM Ver 7 STi Now : E46 M3 / MKVI GTI |
Myles,
After getting a feel of my car at the limit (courtesy of you) my car seems to have a decent amount of understeer I'd like to get rid of. I don't think it's because I'm overcooking the corner, it's just that mid-turn and as I'm powering out all I get is understeer. I'd like it to be more neutral. What should I do? |
#25 |
Member#: 54202
We have a brand new in box set of Cusco Lateral Links and Trailing Arms for 04-07 STi. They sell normally for around $1800. We are selling them for $1300 shipped or picked up. Here is a product description:
Cusco’s pillow ball joint trailing rods prevent movement under acceleration and braking and enable smooth suspension movements. Tire grip is therefore increased and prevents sudden changes in car behavior. Improves traction, braking and cornering characteristics. Cusco's pillow ball joint lateral links are designed to secure traction in drifting and stability during acceleration under high speed cornering. The turnbuckle adjustment enables fine-tuning of the camber angle adjustments. Controls unwanted forces under acceleration and braking. Toe-in and toe-out settings are easy to adjust. ![]() Call us at 1-888-730-7223 to order. Mike Last edited by RaceComp Engineering; 09-11-2006 at 02:31 PM. |
| Thread Tools | |
| Display Modes | |
| whiteline 27-29mm front sway bar | STi-MAN | SCIC Private Classifieds | 4 | 06-22-2009 12:36 PM |
| FS: (OH) Whiteline 27/29 Front Sway Bar | loworbitSI | Suspension/Brakes/Handling | 3 | 05-29-2009 08:23 AM |
| Whiteline 27-29mm Front bar question | xcdhridr | Brakes, Steering & Suspension | 7 | 05-08-2009 07:06 PM |
| Whiteline 27-29mm Front swb and 24-26mm Rear swb plus endlinks | maxim05 | Suspension/Brakes/Handling | 11 | 04-10-2007 06:33 AM |
| FS ID: 04 STi Prodrive springs, front and rear whiteline 27-29mm sways, adj end links | deluxsti | Suspension/Brakes/Handling | 32 | 01-08-2007 07:03 PM |
