#1 |
Member#: 86394
VIC
Vehicle:2000 RS Coupe Blue Ridge Pearl |
I can't seem to find out what bulb my fog lights take (Type B bumper, smaller fogs). I think they're H3 but not sure...
Also, my rear rotors. Are they the same rotors on newer Impreza's all the way to '05? Does this included WRX?
#2 |
Member#: 123191
VIC
Vehicle:2000 2.5 RS Blue |
If i'm correct, there the same as the stock fog lights as the stock subaru bumber fog's. Which should be in your Owners Manual.
#3 |
Member#: 60062
VIC
Vehicle:2000 Impreza 2.5RS 2009 Norco Team DH |
i believe they are H3.. all the subaru fogs use the same ones...
as for the rotors...i know that wrx fronts are bigger, the rear im assuming would be too... cant find the specific ones for your application?? |
#4 |
Member#: 86394
VIC
I have the 4-pots in the front and stock RS in the rear. I'm looking to upgrade the rotors eventually. I'm wondering if I can get a set of 4 intended for an 02 WRX, and the rear rotors will be the same.
#5 |
Member#: 57780
VIC
Vehicle:2000 RS sedan, GC6 Blue Ridge Pearl |
if i remembered correctly the GC RS rear rotor is larger than the GD RS rear rotors. (10.7 vs 10.3 or something like that)
i'm guessing you could use the rotors for the 02WRX, but don't quote me~ ![]() (the only thing you probably need to change, if it doesn't fit, is the brakets) the fog light is H3 |
#6 |
Member#: 86394
VIC
I think I'll just mix-n-match rotors to be on the safe side hehe
I'm thinkin of picking up a pair of yellow H3's for the fogs and see how the look... |
#7 |
Friendly Neighbourhood
Moderator Member#: 269
VIC
Vehicle:2005 ABP LGT LTD BP6 00 Impreza RS GM6 RIP |
If you want to "upgrade" your rear brakes, a recommended way is to do the Legacy GT/H6 rear disc upgrade. It consists of the larger Legacy rotor and a new caliper bracket. Your existing caliper can be used in the new bracket.
Best thing to do is check the good 'ol technical forums for more info on it. There's also the old legacy turbo rear vented rotor "upgrade", but that is a much more involved process which requires new rear calipers due to the wider vented rotors. Again, this info is contained in the "brakes" technical forum. As for the fog lights, I'll confirm, that they are H3 bulbs. I don't recommend getting bulbs larger than the stock 55 watts. Anything more powerful, and you run the risk of possibly melting the housing and/or starting a fire! Of course, if you've rewired your fog lights and aren't running the thin stock wires, then run whatever you want. LaterZ! Darren!! |
| Thread Tools | |
| Display Modes | |
| Mini part out! Lots of JDM GC parts and some GD parts. | Lam | VIC Private Classifieds | 28 | 06-09-2010 12:56 PM |
| FS: 06 wrx body parts, GC parts, etc | aka_tur | Tri-State Area Private Classifieds | 24 | 10-14-2007 05:41 PM |
| FS/trade: 17x7 oz racing superleggeras, STi 4pots, misc gc parts + wrx parts | Keith | Tri-State Area Private Classifieds | 25 | 10-09-2007 09:56 AM |
| wtb: ny many stock wrx parts or gc parts | turbocolin | Tri-State Area Forum | 9 | 12-20-2005 02:40 PM |
| GC-06 and GC-10 question | ihughes | Tire & Wheel | 1 | 07-25-2004 03:48 PM |
