Go Back   NASIOC > NASIOC General > Warranty Issues & SOA Problems
Old 10-21-2004, 04:47 PM   #26
elbenson
Member#: 72993
2004 WRX Wagon
Make: 2004 Impreza WRX Sport Wagon
Mileage:
7,500
Time Out Of Use: 0
Problem And Likely Cause: 2 faded paint spots on hood of car.
Modifications: NONE
Submitted For Warranty Work (Yes/No): YES
Reason Given For Denial: Exposure to environment (bird droppings)
Your Story: About 3-4 months after purchasing car I noticed a faded spot on the hood (looked like damage under the clear coat). One month later a second spot appeared within 2 inches of the original.
Background on car: First 4 months it was kept in a carport with a car cover, and now it resides in a private garage. Car is washed once a week and has never had bird droppings sit on the paint for more than a day or so.
Regional SOA representative denied claim because he said it was environmental damage (most likely bird droppings). Claims Subaru has almost no claims on the paint and couldn't possibly be a problem from the factory. Funny thing is every car I have ever owned has sat outside for years and never had any problems like this with the paint.
elbenson is offline   Reply With Quote
Old 12-07-2004, 12:37 AM   #27
zorgof19
Member#: 64276
2005 05 LGT, 2.5RS
Make: 04 WRX Sedan (San Remo Red)
Milage: 7344
Days out of use: 0
Problem And Likely Cause: lots of chips in the paint; soft paint/poor paint job
Modifications: none
Submitted For Warranty Work (Yes/No): Yes
Reason Given For Denial: Normal Wear and Tear
Your Story: I started to see quite a few white specs in my paint at only 4000mi. This WRX has never seen a dirt road and is always garaged. I have a lot of flecks on the hood and on the rear doors. I feel that the paint job is soft or poor; however not as bad as glass_joe's paint problem. I am thinking about painting it a non subaru color, just to be different.
zorgof19 is offline   Reply With Quote
Old 01-19-2005, 10:48 AM   #28
aznatama
Member#: 60316
2004 STi
Make: 2004 Impreza WRX STi WRB
Mileage: 13,000
Time Out Of Use:
0
Problem And Likely Cause: crack in paint on the corner of driverside rear wheel well. lack of flex additive/unknown
Modifications: front jdm lip
Reason Given For Denial: Lack of documented cases and unknown cause.
Your Story: Went to South Coast Subaru when problem was just a small crack which appeared in the paint, was assured that it can be claimed under warranty and they would let me know when the SOA rep comes. Left number and vehicle info with them.
1 week later, I call back, told they would call me once a rep comes so I can bring car in to get looked at.
another week passes... I call again... same answer, rep hsa no come yet.
after 3-4 weeks of the same BS from SCS, the problem getting MUCH worse due to rust (I was told NOT to touch it at all else I would've put some rust inhibitor or something on it).
I now decided to goto Irvine Subaru in hopes of better service... I was told the same thing at first...SOA rep will be here next week or 2 and that it's a claimable problem. okay... I'll wait... a week later, I get called back and head down to the dealership (yesterday). Talked to the regional SOA rep... what a dick. "not covered under warranty becasue of unknown causes" ... ***??!!??
aznatama is offline   Reply With Quote
Old 01-19-2005, 01:43 PM   #29
Knotsure
Member#: 41730
1415 Legacy/Forester
D.Grey/White
Did the Rep. write that on the RO? "Unknown causes"? I don't think that is a reason to deny under warranty. Or, did the Rep. write due to outside influence like a paint chip?
Knotsure is offline   Reply With Quote
Old 03-18-2005, 12:06 PM   #30
SAND_MAN1
Member#: 31535
2007 F150 Harley Dav
2003 Legacy GT
Make: 2004 WRX Wagon JBP
Mileage: 22k
Time Out Of Use: none
Problem And Likely Cause: Fender liner ripped out while driving
Modifications: Wheels+tires.
Submitted For Warranty Work (Yes/No): No
Reason Given For Denial: Not covered under warranty
Your Story: Fender liner over the driverside front tire came off during a drive, went to dealer and showed it to them because it also broke the clip that holds the bumper in place on the driver side. Was told it wasn't covered under warranty because anything can snag it and pull it off. The replacement part is $37 dollars but shrugged and decided against buying it. Couple of weeks later a lady hit me on the driverside and had to get my two doors replaced as well as the front fender and some suspension work so I got the fenderliner put in as well.
SAND_MAN1 is offline   Reply With Quote
Old 04-01-2005, 08:32 PM   #31
04AspenWhiteWRX
Member#: 84330
04 WRX
Make: 04 WRX (aspen white)
Mileage: 10,000
Time Out Of Use:
Problem And Likely Cause: Poor Paint Job, Chips in paint
Modifications: bov
Submitted For Warranty Work (Yes/No): yes
Reason Given For Denial: Paint was fine and it was normal wear and tear
Your Story: I have tons of small paint chips on my front bumper caused from a salt truck throwing salt but to me i think the salt should break before it puts chips all over the front bumper plus i was going slow at the time and so was he so its not like i hit the salt at 80mph i think i was doing around 20 or less at the time and so was the truck and I also have a major chip on the roof that is allready rusty but im not sure what caused that. I took it to the dealer and they checked the thickness of the paint and said its fine and its normal wear and tear. But why are the chips only on the front bumper from the salt when the truck clearly threw the salt all down the driver side of the car and all over the hood? To me it seems like the plastic bumper is cheaply painted. Also my paint job just looks terrible to begin with it needs a major buffing job and possibly a wet sanding.
04AspenWhiteWRX is offline   Reply With Quote
Old 04-26-2005, 04:50 PM   #32
toadie
Member#: 85913
Default Wrx Sti Paint Problem
I bought my 05 wrx sti about three months ago. recently i started noticing paint flaking off above both rear wheel wells and some on the hood scoop. I brought it in to my dealer today and was told that Subaru was goin to be called to see if they would warranty this condition. Has anyone else run into this problem, and if in any case was their car repaired?
toadie is offline   Reply With Quote
Old 05-02-2005, 12:41 AM   #33
redgt
Member#: 30993
2016 STI
black
Make: 05 WRX (obsidian black)
Mileage: 5000
Time Out Of Use:
Modifications: none
Submitted For Warranty Work (Yes/No): no
Your Story: i was driving and then a bird **** on my car... i went home 5 minutes later to wipe it off, however, the **** had already ate into my paint and now is left with a really noticable and annoying white spot. Can I claim warranty for this?
redgt is offline   Reply With Quote
Old 05-09-2005, 03:14 PM   #34
toadie
Member#: 85913
Default Paint Warranty
Last time i wrote in, I was talkinb about how paint was flaking off of my silver STI (only 3 months old). The dealer contacted subaru and they have agreed to paint all the parts that are flaking. I am so happy, I has only gotten worse. I just hope they do a good paint job.
Old 06-21-2005, 06:10 PM   #35
D.R.
Member#: 72857
Make: 2004 Subaru STi
Mileage: 22,000
Time Out Of Use: 0
Problem And Likely Cause: 2 faded paint spots on hood scoop of car.
Modifications: none
Reason Given For Denial: Dirt on car. They said it needed wax
I said screw them and buffed it out myself. Clear cut case of slight clearcoat blurring. The car was dirty when I brought it to the dealer but that shouldn't matter.
D.R. is offline   Reply With Quote
Old 06-29-2005, 08:59 AM   #36
c4ipp3r
Member#: 89815
04 Impreza TS
San Remo Red
Default Paint warraty
Make: 2004 Subaru TS
Mileage: 37,000 Km
Time Out Of Use: 14 Mo
Problem And Likely Cause: poor paint.
Reason Given For Denial: Chipping not covered
Your Story:Paint chips all over the front hood, on the lower door panels, 1/4 panels, A pilars and rear 1/4 panels. Some sanding on the front hood as well. The car is a San Remo red and is 1 yr old. Check with 2 different dealers and around 7 claims were made on cars with the same trouble. All of them Red San Remo. The subaru rep for eastern Canada don't even want to see the cars. I've also contated Suby Canada to place a formal complaint. Apparently the man with power is the Region manager, and I don't think no escalation is done to him.
c4ipp3r is offline   Reply With Quote
Old 01-08-2006, 01:31 PM   #37
Zottyzot
Member#: 62150
2007 WRX wagon
UGM
Make: 04 WRX wagon
Mileage: 22k
Time Out Of Use: 0
Problem And Likely Cause: Paint chips, particulary one on the ROOF, small maybe 1/8" x 1/4" can see white primer in chip, paint is bubbling around it about the size of a dime!!!
Modifications: Wheels/tires, other minor stuff, nothing affecting the PAINT
Reason Given For Denial: Paint chip is the cause of the bubbling paint
Your Story: Car was bought new from dealer, about nine months after, I was waxing it(not the first time) and I noticed the bubbles and chip on the roof. Dealer said something hit it to chip the paint and thats what caused the bubbles...I think Im gonna install a sunroof In turn cutting out the chip & bubbles.
Zottyzot is offline   Reply With Quote
Old 04-17-2006, 11:12 AM   #38
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
Make: 05 WRX
Mileage: 20k
Time Out Of Use: None
Problem And Likely Cause: Sticky exterior door handle
Modifications: none
Your Story: Waz up guys, I have been having this problem with my drivers side door handle getting kinda sticky on the back side where you pull out. I tried to clean it off when I washed my car but no dice, after closer inspection it seems that the clear coat/paint is wearing off. The car is garage kept and itís only a year old and I donít think that after a year this should happen.
Just checking to see if anyone has had this problem before, and do you think this will be covered under my warranty?
Surfer Steve is offline   Reply With Quote
Old 04-17-2006, 02:34 PM   #39
humara
Member#: 53289
04 wrx waggin'
wrb
Make: 04 WRX wagon
Mileage: 30k
Problem And Likely Cause: plastic trim panels behind rear door windows pop out. /caused by clips not holding to frame properly.
Modifications: cobb stage 2 protuned
Your Story: very minor problem but kind of lame. the black plastic panels that are on the outside of the c-pillar always pop out. done it from almost the first day i had the car. they pop out about 1/2" for some reason. i push them back in and a few days later they pop out again. i guess i need some new clips or whatever. will never take the car in to the dealer for anything like this. so it is what it is.
but that makes me happy that its the only problem i've had with my car for over 2 years.
humara is offline   Reply With Quote
Old 04-17-2006, 09:40 PM   #40
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Why not take it in? It's covered under warranty, so just let them fix it
RexyGirl is offline   Reply With Quote
Old 09-13-2006, 09:15 PM   #41
octaYne
Member#: 106164
2006 WRX
Make: 2006 subaru impreza wrx
Mileage: 10,000
Problem And Likely Cause: condensation on right rear tail light
Modifications: sti wing
Reason Given For Denial: n/a
Your Story: i was out washing my car today after a week of rain, and noticed condensation on my rear right tail light. i was just wondering if my warranty covered this issue.
octaYne is offline   Reply With Quote
Old 09-13-2006, 11:25 PM   #42
RexyGirl
Member#: 63616
with mods :)
Mileage: 10,000
You should have no problem getting it covered under warranty. There is a service bulletin out on this, but be prepared, it doesn't involve replacing the tail light, it involves somehow repairing the seal. (I didn't thoroughly read the bulletin)
Take it to the dealer.
Old 09-14-2006, 07:38 PM   #43
Vahnatai
Member#: 25027
Make: 2002 WRX
Mileage: ~65k
Time Out Of Use: 3 months
Problem And Likely Cause: Spun bearing caused by oil pump failure
Modifications: At the time I had a stage 2 WRX
Reason Given For Denial: Mods
Your Story: Engine started tapping (lifter tap) below a certain RPM on my way home and progressively got worse till the engine died 5 minutes from home. Had the car towed to the dealership and they basically laughed when I asked why it wouldn't be covered. Ended up taking my business elsewhere (non-Subaru shop). There is no way in hell my mod's caused the damage.
Vahnatai is offline   Reply With Quote
Old 09-14-2006, 10:35 PM   #44
RexyGirl
Member#: 63616
with mods :)
Originally Posted by Vahnatai View Post
Make: 2002 WRX
Mileage: ~65k
First of all, wrong thread...this belongs under Engine and Transmission
Second. You are out of warranty. Whether your mods caused the failure or not, you warranty has expired by mileage. Unless you have an extended warranty, which you did not mention
There is no reason why they should cover this seeing that your warranty is expired.
Did the repairing shop tell youw what exactly happened? Did they tell you how much oil was in the engine? Do you run synthetic oil?
Old 09-15-2006, 01:44 AM   #45
Vahnatai
Member#: 25027
Extended warranty.
Engine was rebuilt and they found that the oil pump had stopped working. And yes, I used Royal Purple.
And I just noted it was the wrong section, sorry.
Old 09-23-2006, 02:50 PM   #46
DaveC113
Member#: 126901
2010 WRX 5 Door
Mileage: 10,000
Yup, they replaced my taillight.
DaveC113 is offline   Reply With Quote
Old 09-23-2006, 02:59 PM   #47
DaveC113
Member#: 126901
2010 WRX 5 Door
Default More paint issues, I'm going to test drive a Honda!
Make: 2006 subaru impreza outback wagon se
Mileage: 10,000
Problem And Likely Cause: ding and paint damage... bad paint job and weak sheet metal (easy to stamp) use on body
Modifications: none
Reason Given For Denial: its not SOA's fault, I'm just unlucky.
Your Story: regional svc manager (Boulder, CO) looked at it. I asked why my new car has dings and paint damage, and suggested the quality of the sheet metal and paint were substandard. He said it was the first he's heard of that. BS!!!
I'm on my way to test drive a Honda. My car has also lost coolant and left me STRANDED TWICE!!! I've built 3 cars from the ground up and they never treated me this bad. I'm not into modding my dd, I just want a simple car that is cheap and reliable. I will miss the AWD, but fwd w/ lsd ain't so bad. I'm really disappointed.... its a nice car otherwise.
Old 10-01-2006, 05:57 PM   #48
geebutbut
Member#: 118451
Make: 2004 sti
Mileage: 20000 kms
Problem And Likely Cause: taillight condensation
Modifications: none
Reason Given For Denial: Subaru of Canada says that condensation in the taillight is normal
Your Story: Dealer said he will email SOC again and ask if there is anything that can be done. The likely answer will be "no", so I'm more or less SOL.
geebutbut is offline   Reply With Quote
Old 10-01-2006, 08:33 PM   #49
RexyGirl
Member#: 63616
with mods :)
Originally Posted by geebutbut View Post
Make: 2004 sti
Mileage: 20000 kms
Modifications: none
Tell them to check their service bulletins...I know there is one out in the US for this, and it's covered under your 3/36 warranty.
Old 10-12-2006, 01:00 PM   #50
geebutbut
Member#: 118451
Make: 2004 sti
Mileage: 20000 kms
Modifications: none
After some correspondence with SOC, I'm happy to report that we have reached a satisfactory solution (at least for me). They have decided to replace my taillight (one time only).
see: http://forums.nasioc.com/forums/show....php?t=1103399
Trouble/Warranty Denial Report Thread: Drivetrain (Engine, Tranny, Diff, Etc.) North Ursalia Warranty Issues & SOA Problems 2975 08-25-2016 07:13 PM
Trouble/Warranty Denial Report Thread: Electrical (Lighting, ECU, Sensors, Etc.) North Ursalia Warranty Issues & SOA Problems 110 03-12-2016 01:48 PM
Trouble/Warranty Denial Report Thread: Interior North Ursalia Warranty Issues & SOA Problems 66 03-05-2016 01:04 AM
Trouble/Warranty Denial Report Thread: Braking System North Ursalia Warranty Issues & SOA Problems 83 05-03-2015 08:24 PM
Trouble/Warranty Denial Report Thread: Suspension North Ursalia Warranty Issues & SOA Problems 52 08-13-2014 06:05 PM
