09-25-2006, 02:19 PM | #1 |
Member#: 126116
South East
Vehicle:06 WRX TR Alpine White |
black housing taillight mod for 06 WRX
I've sucessfully completed the headlight mod(when you paint the insides of the headlights black) on the stock 06 tails. I dont know if anyone has ever done this before. I have a few pictures of the process and the final lights.
I had to dremel the lights apart, paint the insides and re-seal them. Thanks to speedworx for helping out. How to: Disclaimer: This is not a mod for those that don't have patience and/or very good hand eye coordination. You can not do this mod quickly or hastily. The longer you take the better it will look. I did it with speedworx, we each dremeled a light painted them together and re-assembled the housings in the span of 4 hours! If you are doing this on your own be prepared to take 6-8 hours. 1. First thing you need to do is get the materials. I went to Autozone and picked up 3 things 1. a can of KRYLON FUSION 2. A can of Duplicolor Trim paint. 3. 3M Window-Weld Ribbon Sealer. Its the same stuff used on the front windsheild of every car. Its very similar, if not the same to the goopy stuff used on the front headlights. 2. Now, to remove your tail lights from the car. You will need to remove the plastic clips from the trim panel, and unbolt 4 10mm nuts per light. Unclip the harness, and each taillight will pop out with no difficulty. 3. Once the lights are out, remove the bulb wiring harness. On the back of each taillight there are 6 philips head screws. Remove them all. 4. Get your Dremel ready. I becan to cut along the back side of the housing about 1/8 inch from the crease line on the back. Be careful, do not cut more that 1/4" depth...you could hit the inner reflectors. I did not even go through 1 cutting wheel, so if you are going through cutting wheels, you are doing something incorrectly. Cut in a smooth consistent line. I made about 3 passes before cutting through as i went around. Stop and clean up the shavings with a razor blade. It will let you see where you are cutting, and will also minimize the chances of getting hit with hot plastic(wear safety goggles!). 5. Once you have cut all the way around, you will find that there are two points holding the housing together. Here is where your dremel will not cut deep enough, and you will need to pry the light apart and SNAP these two points. Do not cut these out once you open the housing. These small tabs hold the chrome housing in place, and will help keep the entire light together after assembly. 6. Make sure that as you cut you stay as close as you can to the crease line. If you get too far from the line, when you are trying to pull the housing apart, you will not be able to because of the shape of the lamp. 7. Once your housing has been seperated from the black housing on the lens side, you will need to slowly work the chrome piece free. ***important*** IF YOU DONT CUT CORRECTLY FROM THE BEGINNING, YOUR CHROME LENS WILL BE STUCK IN THE HOUSING EVEN AFTER SEPERATING THE TWO. Once it is out, spend some time cleaning up the edges of both sides(the lens and the housing) with a razor blade. Clean everything very thoroughly. 8. To prepare the inner chrome lens for paint you will need to remove the red plastic reflector. It is snapped in place. With a small flathead screwdriver push the small clips out from the back of the chrome housing. Be careful. You will also need to remove one of the clear reflectors. This is also relatively straightforward. Remove it from the back with the same flat head screwdriver. Remove the large clip first, and the others will follow. ATTENTION! Before painting, Make sure you test fit the chrome piece into the black housing on the lens side. You will have to trim-shave some plastic from the black housing on the lens side, but never cut or remove any of the supports inside of the housing. These supports are necessary for the chrome piece to be in the correct position after reassembly. 9. Tape off the areas you do not want to paint. I taped the remaining clear lens(it is glued in place) and the chrome area behind the red lens. 10. Prep your painting area, and shoot in the color of your choice, starting with the fusion paint. 11. For the re-assembly. Follow the previous steps in the reverse order. Before placing the housing back on the lens, you will need to use the 3M Window-Weld Ribbon Sealer. run a bead of this across the entire area you cut. I used this because if I ever want to open up the lights again, all I need to do is stick them in the oven for a short time and the two will seperate. You now have a set of custom tail lights. Please post questions, and I will try to edit this post with any answers.
09-25-2006, 02:51 PM | #2 |
Member#: 66402
SWIC
Vehicle:2005 STi Ver8 OBP |
pics?
09-25-2006, 02:54 PM | #3 |
Member#: 126116
South East
a few pics:
09-25-2006, 03:04 PM | #4 |
Member#: 119093
South East
Vehicle:2008 subaru wrx sti silver |
they look nice show the pic of the headlights too
09-25-2006, 03:13 PM | #5 |
Member#: 126116
South East
09-25-2006, 03:32 PM | #6 |
Member#: 29355
you're the 1% i alluded to in my previous post here:
http://forums.nasioc.com/forums/show...1&postcount=18 great job, but i don't like the effect. it makes the circles stand out even more. i would have done it in metallic red. |
09-25-2006, 04:04 PM | #7 | |
Member#: 126116
South East
They do stand out a little. maybe i should have tried to smoke the clear lenses a bit...either way, they are done, and its really not that difficult if you are patient and pay attention to detail. Looks 100x better than stock in my opinion. |
09-25-2006, 04:11 PM | #8 |
Member#: 112992
SCIC
Vehicle:2006 WRX TR Crystal Gray |
Wow that is cool I have been waiting for someone to figure out how to get them out. But dremel...My skills are that great, but I suppose if I took my time I could paint them like the s204 taillights...those are sweet! Nice job do you have any more tips about dremeling it?
09-25-2006, 04:30 PM | #9 |
Member#: 22035
SCIC
Vehicle:2014 Brocoma DCab 71 FJ40, 13 DRZ400SM |
so, how did you do this?
Shane |
09-25-2006, 04:45 PM | #10 |
Member#: 113940
E. Canada
Vehicle:2006 WRX Steel Grey Metallic |
09-25-2006, 04:47 PM | #11 |
Member#: 29355
he said, dremel apart, paint, reseal
09-25-2006, 04:59 PM | #12 |
Member#: 126116
South East
I have some pics that i took while working on them. I will post them when i get a chance, I left my usb cable for my camera at home.
09-25-2006, 05:35 PM | #13 |
Member#: 113940
E. Canada
What did you use to reseal? I think when I try this I'll re-use the permatex black silicone I have left over from clearing my headlights.
09-25-2006, 05:40 PM | #14 |
Member#: 36792
Vehicle: 2018 BMW M2 2016 FRS RS 2.0 #661 |
Nice job.
I thought about doing it before I traded them for the '05 tails, although I would have personally done them in red instead. |
09-25-2006, 08:33 PM | #15 |
Member#: 54935
Subscribe, I will paint them differently though.
09-25-2006, 09:11 PM | #16 |
Member#: 106164
TXIC
Vehicle:2006 WRX WRB |
i like the way that looks, i also did my 06 headlights and wanted to do my tails also. a how to on this mod would be geat
09-25-2006, 09:21 PM | #17 |
Member#: 94615
Vehicle:2017 VW GTI S1+ 2006 STi 341WHP/356TQ |
headlights look good.. tails.. eh..
09-25-2006, 09:23 PM | #18 |
Member#: 61050
SCIC
Vehicle:2004 STi 72 Corona |
Good mod, definitely better than stock.
09-25-2006, 09:38 PM | #19 |
Member#: 120647
South East
Vehicle:2006 WRX Charcoal Grey |
yeah. i'm curious as to where exactly you cut the tail lights with the drumel. Could you not just seperate the tail lights by sticking them in the oven like the headlights? Pics of the cutting would help out a TON. I just finished painting my headlights this weekend and I'm looking to do the tail lights also.
09-25-2006, 10:31 PM | #20 | |
Member#: 36792
09-25-2006, 10:43 PM | #21 |
Member#: 89387
SWIC
Vehicle:2005 RS White |
why not make the headlight housing the same as the car color? The new corvette has that stock, and it looks good.
09-25-2006, 10:55 PM | #22 |
Member#: 125355
finaly someone that had the balls to do it. and i posted a week ago about anyone dremeling their tails open. very well done. few questions i have to ask about the project
1. Did the red lense(brake light) just detach from the housing? Facilitating the smoking of the chrome portion? Or did you have to tape it off? 2. Did you dremel the whole tail light? Or did you use a scoring knife at any point? ++++++1 for doing this mod as I cant stand the tints people put on their taillights. As someone posted above the circles do stand out.. but its pure sex regardless nice choice on ur car color white/black only way to gooooo! edit: shave the ugly emblem off and she'll have a gorgeous booty! |
09-25-2006, 10:58 PM | #23 |
Member#: 125355
09-25-2006, 11:20 PM | #24 |
Member#: 29355
09-25-2006, 11:22 PM | #25 |
Member#: 94615
Similar Threads | ||||
FS : HRSS/ Cobb AP V2, Bellmouth 3 inch Downpipe | lando | MAIC Private Classifieds | 19 | 06-13-2010 06:40 AM |
Check my Thinking (suspension mods for 06 WRX DD) | Chainsaw_Willie | Brakes, Steering & Suspension | 9 | 05-19-2009 10:06 AM |
did the black housing headlight mod with a twist...(56k...stop being poor) | JasonLI25T | Forester Forum | 6 | 01-09-2009 01:55 PM |
Black or CF trunk for 06 wrx | subaruNV | Private 'Wanted' Classifieds | 1 | 11-05-2008 04:13 PM |
newbie wants to know... mods for 06 wrx | raoulduke | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 02-16-2006 03:17 PM |
