Old 10-03-2006, 08:46 AM   #1151
WRX-ERROR
Member#: 83211
2002 WRX - stg4
Originally Posted by Matth3w View Post
I was wondering if the OP can update this trick in the first post since it seems to be a bit of a frequently asked question (and as of page 8 I havent seen a really good answer):
When you are putting your IC pipes on and before you clamp them down, coat the pipe and the inside of the rubber withn aresol hairspray. This is the trick I used when I was putting together both of my turbo kits on my Mazda. The hairspray lubes it up but when it dries creates an excellant seal. When I took my turbo kit apart I had to damn near put the **** in a vice to get it off, and never once had IC piping pop off.
Done..
BTW I'm running this FMIC on a OTS txs map and a vf39 with no problems at all.
WRX-ERROR is offline   Reply With Quote
Old 10-03-2006, 11:03 AM   #1152
tasq
Member#: 62362
2005 wrx
Originally Posted by WRX-ERROR View Post
Done..
Do you have a wideband? If not, how do ya know?
tasq is offline   Reply With Quote
Old 10-03-2006, 11:33 AM   #1153
Freon
Member#: 88322
2009 BMW 135i
It will affect your boost, which can throw off fueling a bit since the UTEC uses boost reference on top of the MAF. It took me about 1 - 1.5psi less to hit the same MAF voltage (keep in mind the MAP sensor is in the intake manifold). It shouldn't throw things that far off, but it will slightly. Nothing like changing your intake which.
Freon is offline   Reply With Quote
Old 10-03-2006, 12:32 PM   #1154
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
Well I will have a PDX tune for the VF39, OTS because I cant go there in person. However, I will have an AEM w/b.
Matth3w is offline   Reply With Quote
Old 10-04-2006, 02:39 PM   #1155
mathetes
Member#: 106238
Is there anyway to fit a grill to protect the ic from debri? Has anyone done this?
mathetes is offline   Reply With Quote
Old 10-04-2006, 03:17 PM   #1156
Bolster
Member#: 22290
2002 WRB WRX Wagon
I made one from gutter guard (Home Depot sells it). It has been rather flimsy, so I bought a grillcraft grill off someone used. They are a lot sturdier.
Bolster is offline   Reply With Quote
Old 10-05-2006, 07:56 PM   #1157
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
Ok, got some things in today...really impressed that I won the auction and BOOM this is at my door already (like 4 days or so). My wife took some pictures (does it look like I have everything?):
In addition, the filter and TurboXS adapter came in.
Old 10-05-2006, 08:17 PM   #1158
Bolster
Member#: 22290
2002 WRB WRX Wagon
Have you also ordered a 2.5"-2.75" adapter for the throttle body? That's the only thing I don't see there.
Old 10-05-2006, 08:23 PM   #1159
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
Yep, hasn't come in yet, according to my wife.
Old 10-08-2006, 12:22 PM   #1160
AmolaitoPR
Member#: 38609
2004 STI
Here's a link to the BOV/BPV adapter. Cheaper than the TXS brand adapter and it looks beefier. WBR is a vendor on NASIOC and IWSTI.
AmolaitoPR is offline   Reply With Quote
Old 10-08-2006, 02:30 PM   #1161
StiPete
Member#: 96164
2005 STi - SOLD :(
'00 Impreza 2.5rs
^^^ nice find
StiPete is offline   Reply With Quote
Old 10-08-2006, 06:29 PM   #1162
benw
Member#: 103320
2005 wingless
aspen white
UPDATE!
I made the six hour drive to Austin, TX from Oklahoma City, OK and got tuned on my new combo, and the burmese soda can FMIC performed very well. The tuner commented that it was his first one to tune and everything went just fine. Here is my setup:
2005 STi stock longblock
td06-20G
740cc
eBay FMIC
catless invidia 3" turboback
walbro gss342
prodrive BCS
APS BOV
Perrin turbo inlet
Ecutek
I was tuned for ____91 octane_____ and laid down 270 on a heartbreaker dyno. translates to 350 on a dynojet across town he said. I am happy! It responds like a stock turbo but MUCH angrier when you poke it with a stick.
benw is offline   Reply With Quote
Old 10-08-2006, 06:36 PM   #1163
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
where did you get tuned? MZM?
Old 10-08-2006, 11:55 PM   #1164
benw
Member#: 103320
2005 wingless
aspen white
yes, at MZM
Old 10-09-2006, 12:15 AM   #1165
AmolaitoPR
Member#: 38609
2004 STI
In case anyone wants a matching 90 deg. hose for the BOV/BPV setup. I got this one a few weeks ago, works just like the radiator hose did, but looks better in the engine bay.
Old 10-09-2006, 12:21 AM   #1166
Wrinkleboi
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
i think my rad hose isnt sealing well... wondering if silicone might seal better and/or hold boost better than a crap radiator hose... or maybe the rad hose i got is just slightly too large.
Wrinkleboi is offline   Reply With Quote
Old 10-09-2006, 12:24 AM   #1167
AmolaitoPR
Member#: 38609
2004 STI
Originally Posted by Wrinkleboi View Post
ha, nice id tag in that link. how much of a kickback do you get per click/purchase?
I have no clue what you mean.... I just copied and pasted the link right from my favorites.
Old 10-09-2006, 12:26 AM   #1168
Wrinkleboi
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
thats just me being a cranky ass tonight... i realized you were innocent there and edited my post to a more productive question instead based on my leak testing today. sorry about that...
Old 10-09-2006, 12:26 AM   #1169
AmolaitoPR
Member#: 38609
2004 STI
Same reason why I replaced it. Rad hose works well in a pinch... but I noticed mine was dry and brittle once removed.
Old 10-11-2006, 02:05 PM   #1170
WRX-ERROR
Member#: 83211
2002 WRX - stg4
Added the hose and BPV adapter to the FAQ.
Old 10-12-2006, 12:10 AM   #1171
WrXwaBBit
Member#: 33296
Originally Posted by R0DENT View Post
To be honest, my car is running great with this tube! Idle and cruise aren't bad at all and with no tune. I've been keeping a close eye on my wide band o2 and I think with a good tune, this will run like it was stock (just with more power). I'm not saying this is ideal for everyone but if you want to run a larger turbo with a 3" inlet, then its a cheap way to do it.
Anyway, I took some exact measurements with a micrometer.
Spectre MAF tube
2.82"
71.62mm
(little larger than I thought)
SSA Maf
2.55"
64.77mm
Here's a pic of the 3" Spectre MAF tube and two 3" tubes on each side.
i like your intake setup, what is that red tube at the end of intake is that your filter are you using a low profile filter to fit in the fender?
WrXwaBBit is offline   Reply With Quote
Old 10-12-2006, 12:29 AM   #1172
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
Yeah, its my homemade CAI. Its a Spectre flex hose I got at Pep Boys for like $15. Its only 2.75 ID and the 90 degree Spectre fitting I have in the filter sucks since it narrows at the bend. Since then, I reinstalled the air filter back on the straight Spectre maf tube (no CAI) and the car feels much quicker. I run a 3" Red turbo so on a stock sized turbo, I doubt it would make any difference.
R0DENT is offline   Reply With Quote
Old 10-12-2006, 12:37 AM   #1173
WrXwaBBit
Member#: 33296
so do you have the air filter in the engine bay not in the fender now?
Old 10-12-2006, 12:43 AM   #1174
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
I put it back in the engine bay for now until I can find a better CAI solution. Hyperflow is another CAI but shipping is a killer since its coming from AU.
Filter is just cheap Spectre filter that I also got a Pep Boys ($25).
http://www.powerflowracing.com/spect...ail.asp?PD=671
Old 10-12-2006, 01:41 AM   #1175
benw
Member#: 103320
2005 wingless
aspen white
spectre for the win. Using a 3" cone filter in the engine bay no problems.
FMIC piping made from silicone only subypal Newbies & FAQs 14 12-11-2009 02:43 AM
Ford Mustang Made From 5000 Beer Cans AVANTI R5 Non-Subaru News & Rumors 16 08-04-2007 01:00 AM
I just made coffee with 6-month old Folgers from an open can beachbum Off-Topic 15 01-19-2006 12:46 PM
New e-bay FMIC...not made from Burmese Soda cans. Optimus Prime Factory 2.5L Turbo Powertrain 546 12-16-2005 10:36 AM
New bumper and new FMIC = new pics (56k do not try) GottaREX Member's Car Gallery 87 10-12-2005 06:01 PM
Message Board Statistics All times are GMT -4. The time now is 06:06 PM.
