Old 05-21-2006, 11:32 PM   #1
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Lightbulb Discussion/questions/updates about "Stock head unit information..." FAQ thread
This thread is for questions, suggestions, updates, etc. about the FAQ thread
Stock head unit information -- pin-outs, subwoofer, aux inputs, and more
Please post your questions here, not there!
If you have a question related to your own car, please be sure to post the model, year, and country where the car was originally sold.
Old 05-22-2006, 01:35 AM   #2
ironfinger
Member#: 64688
04 Forester
Java Black
sub signal out question. I have a US 04 forester.
I replaced the 6x9 stock sub in the trunk with an aftermarket 8". Will I get better bass quality if I connect my LOC to the signal from the sub out instead of the rear outs? If so, is it possible to bridge the LOC connection to the sub signal ? I ask because I plan to bridge the speaker wires at the amp?
thanks!
ironfinger is offline   Reply With Quote
Old 06-08-2006, 11:05 PM   #3
AKADriver
Member#: 37298
2000 Mazda Miata
Highlight Silver
I thought I'd add something to the Aux-in discussions, particularly concerning the rectangular CD changer connector on some newer HUs. I saw a Subaru 6disc head unit on eBay while I was looking for cheap Mazda stock HUs and noticed that it had the exact same CD changer connector form factor.
'9?-'01 Mazdas have a CD changer connector with a very, very, very similar pinout. In fact, almost all the pins are the same - except for a few which are labeled as Not Connected on the Subaru.
Miata.net has a pinout. I'd post a link but your forum software won't let me. At any rate, go to Miata.net -> Garage -> Audio -> NB Stereo Interface Descriptions.
For the Mazda, all we have to do is set pin 6 (AUX CONTROL IN) to +5v. The display on the radio says "LINE" and the aux input is the only audio source.
I saw that Subaru claims pin F (pin 6) is not connected, but someone ought to confirm that. Mazda uses that pin because they had a factory optional add-on cassette player for these stereos that needed a simple trigger. The Mazda radios are also built by Matsushiiita/Panasonic, BTW.
It sounds like the line-in is always on for your stereos, so you might just try using the System Mute pin (pin L).
AKADriver is offline   Reply With Quote
Old 07-08-2006, 02:59 AM   #4
vroom...psshh
Member#: 118351
2002 wrx wagon
I have some questions, I own a 02 wrx wagon and I'm in socal, my first question is there a double din dvd player with the screen already that fits my car with no mods? second, if I do install a double din dvd player will I be able to use the oem subwoofer still? and for my last question, can I add an amplifier and a sub in the trunk with the oem sub still working??? thanks in advance.
vroom...psshh is offline   Reply With Quote
Old 07-08-2006, 03:09 AM   #5
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
Yes, you can add an amp and sub with your stock sub still working. Yes, I've seen many people with double din dvd units right in dash. You will still be able to use the stock sub with that as well.
P.S. Better put on your flame suit with that user name
02BlueSuperRoo is offline   Reply With Quote
Old 07-08-2006, 03:12 AM   #6
vroom...psshh
Member#: 118351
2002 wrx wagon
thanks for the heads up
Old 07-25-2006, 12:20 PM   #7
WejR20X
Member#: 58101
will i be able to power aftermarket door speakers with the stock HU? if so how much wattage can the stock HU support? i don't have enough money for an amp but i want better door speakers.
WejR20X is offline   Reply With Quote
Old 09-21-2006, 08:32 AM   #8
07Waggin
Member#: 126600
Default Sub connections
On this new USA '07 2.5i MT5 Wagon, I intend to replace the head unit with an Alpine 9856 or Pioneer 4800/5800, both of which are available with dedicated subwoofer output and control. I'm hoping that this approach will provide a stereo sub signal condensed safely into a mono output for the single factory OEM sub my car came with. I know bass is generally not panned strongly to the right or left channel, but in rare cases it is.
Does someone have a moment to answer these few questions?
1. Will a speaker-level output be sufficient to run the OEM Subwoofer?
2. Some owners with aftermarket head units that have no dedicated sub outputs just tap off of one of the main speaker outs to run the sub, is that still a sensible alternative?
3. The factory radio seems to tap off a front speaker output. Is that true? Would that be just one, left or right, rather than some combination of both? I think some combination might cause an inappropriate right/left signal cross.
4. One owner tapped off the front left for his subwoofer output. Was that a good choice?
Thank you for your time and expertise. This forum is great and I've already learned a lot from everyone!
07Waggin is offline   Reply With Quote
Old 09-21-2006, 12:38 PM   #9
07Waggin
Member#: 126600
Follow-up:
As it turns out, the factory radio powers the OEM sub off of the front speakers - both of them. So there must be an internal signal combiner that permits both the right and left channels to send bass to the sub without it crossing the channels.
Old 09-21-2006, 12:49 PM   #10
kromHASaWRX
Member#: 125126
15 STi Ltd.
have a question where can i find the speed sensor wire ive been searchn all day and got nothing... HELP!
kromHASaWRX is offline   Reply With Quote
Old 09-21-2006, 01:14 PM   #11
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
Old 09-21-2006, 01:22 PM   #12
ekw
Member#: 92141
2004 STi-WRB on gold
Street prepped by TiC !
probably not on the back of a factory stereo!!
make & model of your car might help someone answer you.
w/o this info it migh be impossible to answer.
ekw is offline   Reply With Quote
Old 09-22-2006, 12:08 AM   #13
kromHASaWRX
Member#: 125126
15 STi Ltd.
sorry 2006 WRX TR ive found a ton about 05 and older but nothing on 06... ive been searching all day !
Old 09-22-2006, 02:52 AM   #14
rubrduk
Member#: 126587
06 wagback...now
with more child seat!
doesn't the factory hu have an active eq that decreases bass as volume is increased...this automatically is bad - get a Fosgate 3sixty or something if you keep the factory hu to clean the curve
rubrduk is offline   Reply With Quote
Old 09-22-2006, 09:44 AM   #15
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
^^ yes it does
Old 09-24-2006, 09:57 PM   #16
07Waggin
Member#: 126600
Default Possible power amp circumvent
Is it possible to power just the OEM sub driver with an aftermarket amp coming off an aftermarket head unit with sub pre-out and sub control by circumventing the OEM sub amp completely - basically, hand wiring directly to the OEM sub driver?
Old 09-24-2006, 10:31 PM   #17
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
How do you reset a stock HU in an '04 WRX? My battery was dead for a while and now the HU will not turn on at all no matter what I try.
blkscooby is offline   Reply With Quote
Old 09-25-2006, 03:51 PM   #18
necro-master
Member#: 127094
06 WRX TR
Blue Pearl
What dash kit can u use to add an aftermarket head unit? its a 06 WRX TR
necro-master is offline   Reply With Quote
Old 09-25-2006, 06:46 PM   #19
LastResort
Member#: 99289
Dash Kits are Not Applicable to imprezas.
LastResort is offline   Reply With Quote
Old 09-28-2006, 08:48 PM   #20
blkscooby
Member#: 44422
2009 G8 GT
Anyone?!?
Old 09-28-2006, 09:07 PM   #21
LastResort
Member#: 99289
I don't think there is a reset beyond removing power from them.
Old 11-06-2006, 12:19 AM   #22
trooper1556
Member#: 128474
2006 WRX sport wagon
black
Does anyone know if the 2006 factory harness will plug directly into a 2007 head unit?
trooper1556 is offline   Reply With Quote
Old 11-06-2006, 11:02 AM   #23
Captain Ned
Member#: 36144
2010 Legacy2.5GT Ltd
Graphite Gray Metallic
Is there any way to recalibrate the volume control in the 06/07 head unit? On my '02, a comfortable listening level for FM radio was a volume setting between 10 and 15. On my '07, it's closer to 30. Both units have the same 40-step volume scale.
Captain Ned is offline   Reply With Quote
Old 11-06-2006, 11:31 AM   #24
LastResort
Member#: 99289
It should
Old 11-08-2006, 11:50 PM   #25
TimmyZ
Member#: 126885
2006 Outback Sport
Green
I would like to know the answer to this as well, if someone has the information. Also, the volume maxes out at "40" what's that all about? A good listening level is close to 30 (26-32) typically, and it stops at 40. That doesn't seem right.
TimmyZ is offline   Reply With Quote
Stock head unit information -- pin-outs, aux inputs, and more SVXdc Car Audio, Video & Security 60 12-06-2015 02:11 PM
Question about factory head units nsnguyen Car Audio, Video & Security 7 04-30-2004 02:26 PM
Question about using head unit to power back speakers STI-o-MY Car Audio, Video & Security 0 12-01-2003 03:06 PM
question about my head unit creature546 Car Audio, Video & Security 1 10-03-2002 07:48 PM
