Old 11-11-2006, 01:42 PM   #1
Durmiente
Member#: 75771
2002 WRX Wagon
#87 STX
Default How to paint your Subaru badge, both the stars and the background!
I posted this over on scoobymods.com (I am known as dark_vandal on all the other subaru forums except this one) and wanted to post it here for you all to see.... a lot of people wanted to see this, so here it is.
Here are some materials you might like to get before doing this:
I'd recommend Q tips, tooth picks, and a heavy duty remover (i.e. Goof Off). nailpolish doesn't really work (I tried it). Just whatever you use, don't use something that is harmful to plastics. Goof Off is pushing it, but I didn't notice it eating away at the badge plastic.
The Steps:
1. First you need to pop your stock badge off from the car. This is relatively easy to do, but be careful to do it slowly. You'll want to take the grill off the car (4 clips) and then heat the badge with a blow dryer for several minutes... the hotter the better. Then use something thin (i.e., a butter knife) and pry the badge from the grill (I'd recommend using a cloth so as to not scratch it... you should also pry from the underside of the badge (bottom) so in case you do scratch it, it will not be noticeable when it is on the car.)
2. Here we have our badge off the car. I actually did this to an '03 WRX badge (my WRX is an '02). I like the 03 badge more, as the stars are bigger and just look nicer IMO.
Here is the reverse side of the badge. It is basically chrome inserts covered by blue paint.
3. First off, start off by using some of the goof-off to start removing the blue paint. It comes off pretty easy. Use a Q-tip saturated in the remover to rub off the paint. You might also pour some of the remover on the badge and let it soak so as to soften up the paint. As you do this, most of the chrome will start to come off the badge. However, little fleks of chrome will remain in the edges of the stars. I used a toothpick to scratch at these and remove them. This part was a PITA and took a very long time. Continually inspect the badge until you remove all the chrome.
4. Next, clean the badge very well with soap and water. let it dry well. Check again that no chrome specs are in the stars. Your badge should look like this from the reverse. You'll see some remaining paint on mine on the edges, but this doesn't matter as you can't see it from the front.
5. Now it is time to paint the stars and the loop. I did this with some red caliper paint i had left over. I just sprayed it into a cup and brushed it on. I had some paint thinner and paper towel handy to wipe off any mistakes i made (it is pretty easy to paint the wrong part of the badge, especially considering the nooks are so small.
6. Give your badge 3-4 coats, allowing enough time to dry between each coat, like any other paint job. Make sure you have enough coats so that when you hold it up to the light, no light can get through the paint. It should look like this:
and the front side:
Durmiente is offline   Reply With Quote
Old 11-11-2006, 01:42 PM   #2
Durmiente
Member#: 75771
2002 WRX Wagon
#87 STX
7. Mask off the sides and front of your badge like so.
This is to prevent any paint from seeping onto the face of the badge when you paint.
8. Spray paint the badge's back face with any color you'd like. Just like any paint job, start slow, and do multiple light coats.
The reverse side now:
9. Throw on a few coats of clear coat for protection.
10. Now you're done! The finished product:
11, Reinstall. I actually drilled some holes behind where the badge mounts to the grill. That way, I can just pop it off from the reverse side with a screwdriver if i ever have to remove it again. To attach, just use some strips of 3M automotive double sided tape. It works very well.
Here it is on my car... I did red/black to match my color scheme and wheels. I'm very happy with the way it turned out:
Enjoy!
Old 11-11-2006, 01:48 PM   #3
G3Red04WRX
Member#: 66611
2007 Trailblazer AWD
3LT Sandstone Metallic
Now thats nice. Almost makes me want to take mine of and redo it the way you did. Mine is currently chrome stars with san remo red background.
two thumbs up for you!
G3Red04WRX is offline   Reply With Quote
Old 11-11-2006, 02:03 PM   #4
Gorge
Member#: 97449
2007 WRX
Wow, looks hot! I like it
Gorge is offline   Reply With Quote
Old 11-11-2006, 02:06 PM   #5
Ryan314
Member#: 82989
Hybrid VF22
Wow I'm just imagining your wagon with JDM projectors... it would look amazing.
Ryan314 is offline   Reply With Quote
Old 11-11-2006, 02:31 PM   #6
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
very nice job
boundy3 is offline   Reply With Quote
Old 11-11-2006, 02:35 PM   #7
Nicholas Mouyos
Member#: 25306
2005 Evolution
2006 ts Wagon
nice
Nicholas Mouyos is offline   Reply With Quote
Old 11-11-2006, 02:42 PM   #8
Burncycle
Member#: 85156
2004 Outback Sport
What would you suggest if you wanted to keep the chrome?
Burncycle is offline   Reply With Quote
Old 11-11-2006, 02:57 PM   #9
carlosamilcar
Member#: 102107
2006 Impreza Wrx
Wow! that looks awesome. Thanks for taking the time to post it!!
carlosamilcar is offline   Reply With Quote
Old 11-11-2006, 03:48 PM   #10
denigrad
Member#: 68666
2000 Impreza 2.5RS
Silverthorn Metallic
I recommend adding this to the "threads of note" (sticky).
-Denigrad-
denigrad is offline   Reply With Quote
Old 11-11-2006, 04:26 PM   #11
Dragicon
Member#: 112323
great write up.
Dragicon is offline   Reply With Quote
Old 11-11-2006, 05:44 PM   #12
G3Red04WRX
Member#: 66611
Theres another thread on this. You would just remove the blue paint from the emblem and leave the chrome in place then repaint the badge in the color of your choice. This is what I did with mine. But after seeing the red on black, i may be a copycat and redo mine just like the OP...
Old 11-11-2006, 09:49 PM   #13
SurfPine
Member#: 39401
Thumbs up
looks cool
SurfPine is offline   Reply With Quote
Old 11-11-2006, 10:05 PM   #14
RS drifter
Member#: 7891
2005 wrx STI
Aspen MF white!
very nice
RS drifter is offline   Reply With Quote
Old 11-11-2006, 10:05 PM   #15
Senfinger
Member#: 110912
2015 STi
ISM
Awesome write up man!
Senfinger is offline   Reply With Quote
Old 11-11-2006, 10:15 PM   #16
brcewane
Member#: 63990
Flat Grey
No need to imagine any more... I tinted the fogs and lowered it too
brcewane is offline   Reply With Quote
Old 11-11-2006, 10:48 PM   #17
2$SPIFF
Member#: 78437
2002 WRXWag 16.5 PSI
Rally Blue
those rims are nicely done in addition to the badge, nice wagon bro
2$SPIFF is offline   Reply With Quote
Old 11-11-2006, 10:52 PM   #18
w.f.p.k.
Member#: 110001
STi
I have experimented with this before but I am wondering if I could do it to a 06 trunk badge? I have not even looked at that badge yet. I am too lazy to take it out. Has anyone done this?
w.f.p.k. is offline   Reply With Quote
Old 11-11-2006, 11:27 PM   #19
Durmiente
Member#: 75771
2002 WRX Wagon
#87 STX
thanks for the compliments guys.
man that photoshop is sweet! I wish i was a better photo-shopper.... that is done very well. I wish i could get those headlights (I love them) but as you can probably tell I am a poor college student and most of my mods are DIY things...
First up will be some 17x8s and the rest of my suspension work. then i might someday consider the JDM headlights... someday... how much do they cost?
Old 11-11-2006, 11:40 PM   #20
02wrbrex
Member#: 103061
98 Impreza EJ207
350 Zed
Hey what did you tint your corner markers with?
02wrbrex is offline   Reply With Quote
Old 11-11-2006, 11:46 PM   #21
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Very nicely done!!!
Hank3 is offline   Reply With Quote
Old 11-12-2006, 12:06 AM   #22
brcewane
Member#: 63990
Flat Grey
I didn't want to spend the money on the JDM projectors either, the EDM version are about $1200 and the JDM's are about $800 new... so I made my own
Old 11-12-2006, 03:47 AM   #23
Durmiente
Member#: 75771
2002 WRX Wagon
#87 STX
Nice! Definitely interested in this (and other homebrew mods). You should write up a tutorial or tell me how...
well nightshades is probably a good choice... but no local places have it. and getting it shipped is expensive as it is a "hazardous" material. so I actually used some transparent black paint that is typically used for RC car tint (I guess they spray the inside of the lexan bodies to give it a window tint). anyways, just used that stuff... it's kind of an odd paint... after lots of prep and very light coats and clear coating, it still fades. it lasts about a year in the NM sun... after that i usually just re-paint it. I am tempted to just take out the bulbs and spray it black with real paint, but that wouldn't reall be a safe thing to do.
but with the transparent black the light still shines through. it is a lot dimmer, but still noticeable.
Old 11-12-2006, 06:12 AM   #24
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
He already has
semaj is offline   Reply With Quote
Old 11-12-2006, 10:15 AM   #25
Ryan314
Member#: 82989
Hybrid VF22
Originally Posted by semaj View Post
He already has
Link!?
How to paint your stock wheels criscross79 Interior & Exterior Modification 545 04-10-2012 06:10 PM
Video Intruction of how to debadge your SUBARU minx1225 Interior & Exterior Modification 15 03-21-2006 06:30 PM
How To Keep Your Subaru Alive (V2 Manual) NewDriverOlderRide Private 'For Sale' Classifieds 0 01-21-2006 12:43 AM
How to paint your seats reconracer Interior & Exterior Modification 62 08-26-2005 02:23 PM
How to paint your aftermarket rims? o2sys Interior & Exterior Modification 2 06-29-2005 05:51 PM
