Old 11-07-2006, 02:57 PM   #1
hulkSTi
Member#: 96355
2005 STi
Default p2096
got the cel p2096 Post Catalyst Fuel Trim System Too Lean Bank 1
how do i fix this?
thanks for any help
hulkSTi is offline   Reply With Quote
Old 11-08-2006, 09:55 PM   #2
ase05scooby
Member#: 103710
05 impreza wrx
red
Any mods done to the car.Could be several things Your rear oxygen sensor,mass air flow sensor, air intake temp sensor or coolant temp sensor.Take it to a shop and have them checks the values of the sensors compared to their actual values.
ase05scooby is offline   Reply With Quote
Old 11-08-2006, 10:41 PM   #3
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
I'd check the code again- it doesn't come up at all that I can find.
Brian
North Ursalia is offline   Reply With Quote
Old 11-12-2006, 01:16 PM   #4
badtaste
Member#: 116636
2003 impreza
black
possibal bad converter
badtaste is offline   Reply With Quote
Old 11-13-2006, 08:22 AM   #5
hulkSTi
Member#: 96355
2005 STi
converter?
Old 11-13-2006, 10:45 AM   #6
According to my '05 FSM....there are 12 steps---3 full pages of diagnostics for that code.
How well equipped are you to perform mechanical/electrical diagnostics???
Old 11-13-2006, 10:58 AM   #7
Jon [in CT]
Member#: 2992
02 WRX Sedan
This code is frequently associated with trying to run a late model Subaru with the rear O2 sensor mounted in a spark plug anti-fouler.
Jon [in CT] is offline   Reply With Quote
Old 11-16-2006, 08:32 PM   #8
TMessick
Member#: 882
2004 WRX Wagon
very blue
First off (and in general for anyone looking for help) please post your mods! Quite difficult (and a lot of guessing) if we don't know the hardware you're dealing with.
Highly reccomend finding someone with a Tactrix cable (or getting one yourself) and getting some logs. Uncle Scotty's kind of got the method to the madness of diagnosis (follow the SM).
In a generic sense, DS fuel trim lean (P2096) means that the control system couldn't get the downstream sensor down to the voltage it wanted, so the system is out of control. As such, you get a fault. COuld be a problem with the DS sensor reading incorrectly high (sensor/wiring problem, sensor out of exh stream) or a tune/HW issue where you're running a bit richer than the cal is set up for and the DS control is trying to pull out fuel to get you back to "normal" but runs out of authority.
Possible causes in order of SM diagnostic procedure) are:
2) rear O2 sensor reading stuck hi or offset (failed sensor or wiring, should be able to see it on logs)
3) rear O2 sensor offset hi/biased (failed sensor or wiring, should be able to see it on logs)
4) rear O2 sensor wiring failed between ECU and sensor signal (fix wiring)
5) rear O2 sensor signal reference offset (failed sensor, replace)
6) air leak in the exhaust near the front O2 or rear O2 is isolated (repair exhaust)
7) ??? not sure how an air leak would cause this, but a borked MAF might
8) high fuel pressure causing rich event
9) failed pressure regulator (see above)
... (I'm too lazy to check these, they are unlikely)
I'd say an aftermarket exhaust by itself is unlikely to cause this, but any of the various "CEL" fixes applied to the DS O2 _could_ be causing it.....
-T
TMessick is offline   Reply With Quote
Old 11-16-2006, 08:50 PM   #9
hulkSTi
Member#: 96355
2005 STi
-T
well i did just get a new TXS exhaust and i had to extend my o2 sensor wiring by about 5" to reach the o2 bung in the new exhaust. im hoping i have a loose wiring connection in there. makes sense. i didnt get this code until after i did the o2. it was about 4 weeks ago. i got the 1st cel a week ago
sorry, my mods are FP Green 50 Trim Turbo, Perrin FMIC, SMC meth kit, Perrin BIG MAF intake, Perrin 816cc modded injectors, Perrin Radiator Reservior, Tial Bov, Walbro Fuel Pump, Turbo XS 4" downpipe, Turbo XS racepipe, Turbo XS exhaust, Thermotec turbo wrap, Thermo-tec Cool Tube on I/C Pipe, Custom turbo heatshield, Heatwrapped downpipe, GFB Red pulley kit, Carbon Fiber radiator shroud, NGK Iridium colder plugs, Motul Race Oil, STi high pressure radiator cap, Apex-I AVC-R, Apex-I TT, HKS TT harness, Ecutek ecu custom street tune by Scott Siegel, monitored by Ecutuk Delta Dash Software.
Old 11-16-2006, 09:53 PM   #10
hulkSTi
Member#: 96355
2005 STi
not running a plug anti-fouler
Old 11-16-2006, 11:06 PM   #11
...it is possible that an exhaust leak would do this, too...
Old 11-17-2006, 08:19 AM   #12
hulkSTi
Member#: 96355
2005 STi
im going to check that this weekend. brand new gaskets for the entire exhaust system
P2096 code; anyone else get this??? riceburner22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 71 10-22-2009 11:09 PM
p2096, Any News? EXzacLEE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 02-09-2006 03:26 PM
it safe to drive the car with this code P2096 Post Catalyst Fuel Trim System Too L TampaSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-21-2005 11:54 PM
P2096 Post Catalyst Fuel Trim System Too Lean Bank ? TampaSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-18-2005 05:46 AM
P2096, and a freaking out fiance' attitude Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 28 06-03-2005 11:02 AM
