Old 11-15-2006, 01:52 PM   #26
WildBlueWRX
Member#: 111164
2008 Legacy 2.5GT
Obsidian Black Pearl
i just baught my 04 wrx a couple months ago, and i just now realized that theres an oem subwoofer under the passenger seat. however, it doesnt work. ive checked all the fuses (even the inline fuse) and nothing seems to be blown. i dont want to accept the fact that the unit itself might be blown. ne ideas on what could be the problem?
WildBlueWRX is offline   Reply With Quote
Old 11-15-2006, 03:06 PM   #27
dan1587wrx
Member#: 132107
2006 WRX Stage 3
340WHP 340WTQ WRB
Default 06 TR HU swap with 06 WRX HU
I have an 06 TR and am about to buy an 06 WRX HU with indash 6cd changer. I was wondering if i can just swap out the headunits and take out the din tray under the old radio. Is there any how to's dealing with this change.
dan1587wrx is offline   Reply With Quote
Old 11-15-2006, 03:08 PM   #28
LastResort
Member#: 99289
There is a thread on pulling 06 stereos. and the unit will be plug and play.
NOTE: on the right side HU bracket there is a ground, you PUSH on the top of the plastic tab to remove the ground.
LastResort is offline   Reply With Quote
Old 11-20-2006, 11:00 PM   #29
subieworx
Member#: 47769
A while ago there was a thread talking about how to wire an "aux in" to the factory tape player leads. Anyone know that thread?
subieworx is offline   Reply With Quote
Old 11-21-2006, 02:46 PM   #30
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Here is the thread I think you are referring to (SVXdc's great stock HU thread, primarily section 8)...
http://forums.nasioc.com/forums/showthread.php?t=749402
I am not sure what you are wanting to wire in exactly, but here is another thread that might give you one more idea on what can be done as far as a clean install...
http://forums.nasioc.com/forums/show....php?t=1134603
Let me know if you need any more help,
offset
offset is offline   Reply With Quote
Old 11-21-2006, 03:33 PM   #31
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I am trying to find a way to wire up my Sirius S50 in my rsx type s. The type s does not have a way of adding an input through normal means. I was thinkging of wiring to the leads of the tape player as I will never use the tape player. Right now the FM modulator is not cuttin it.
Tony
Old 11-30-2006, 11:26 AM   #32
pca7ggr
Member#: 115554
2014 Forester XT-Trg
Blue Metallic Pearl
I would like to use a Subie sub with a Sony CDX-M630 deck. Can someone he me with info on how to adapt the sub's wiring harness so that it wil be compatible with this deck? I'm not an electronics guru, so a "ducks-n-bunnies" explanation with diagram would be most appreciated.
I have read the verious threads withthe wiring diagrams but I would like to somehow adapt the sub harness to plug into the RCA connections and the "on" lead on the Sony deck.Yeah-yeah-yeah - the Subie sub, according to my 26 year old son, sucks but I like it anyway and want to use it on my old 911.
pca7ggr is offline   Reply With Quote
Old 12-02-2006, 08:40 PM   #33
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
There are a couple of other threads out there that talk about hacking (inside) the factory radio to piggyback an Aux input onto the CD audio. There's a link to one in post #14 of my HU FAQ thread.
I think I've seen another thread that describes a similar hack to give you an Aux input in place of the cassette, but after a brief search I haven't found it yet.
Old 12-02-2006, 09:12 PM   #34
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by pca7ggr View Post
I would like to use a Subie sub with a Sony CDX-M630 deck. Can someone he me with info on how to adapt the sub's wiring harness so that it wil be compatible with this deck? ...
Since the Subaru sub only has speaker-level inputs, the easiest way to install it would be to connect to the speaker outputs on your Sony deck.
The sub automatically activates when it senses sound on the left channel, so there's no need to use the Sony's "remote on" line.
Assuming you used a wiring adaptor ("forward" harness) to connect the Sony into your 911, you can buy a reverse subwoofer plug from me and wire that in between the Porsche forward harness and the Sony harness.
Or if your sub came with the factory T-harness, you can cut off the long leg and wire it in between the forward and Sony harnesses. If you're careful not to cut any of the wires running between the two 14-pin connectors, you can sell that portion to a Subaru owner who wants to wire an external speaker amp to their factory radio.
One of the guys on the ScoobyMods thread (see link from my HU FAQ thread) talked about the possibility of hacking the sub to use line-level inputs, but unless you do that kind of electronics tinkering a lot, you'd be better off just buying an after-market sub that can take line-level inputs, like the Clarion SRV303.
Old 12-06-2006, 09:43 PM   #35
billmoon73
Member#: 79440
Angry '04 Baja Stereo Question
I have an '04 Baja Turbo with the 'upgraded' factory stereo (in dash 6 disc changer plus the tweeters). When I fade to the rear speakers there is a clear and noticable DECREASE in low end response, greater than would be expected from just a 'weaker' speaker unable to produce lower end bass.
I am wondering if the head unit is designed with a low-pass filter eliminating low frequencies to the rear speakers, or is there a capacitor in-line somewhere? Both of these ideas seem very unusual to me in a factory stereo setup, but the fact remains, my rear speakers play essentially no low frequencies.
Thanks in advance for your help and thoughts!!
billmoon73 is offline   Reply With Quote
Old 12-07-2006, 01:37 AM   #36
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Do you have the factory subwoofer underneath one of the front seats? If so, put your ear close to that and see if its volume goes down when you fade from front to rear speakers. You can also unplug the sub and see if this phenomenon stops.
All of the factory subwoofer harnesses that I've seen have tied the sub to the rear speaker outputs, so more rear = more subwoofer. But one person claimed his sub was running off the fronts. Perhaps that's the case in certain models? It's tough to know because the powered subwoofer harness does not appear on Subaru's schematics for the various vehicles.
Old 12-07-2006, 11:06 PM   #37
midnight2.5rs-t
Member#: 126217
04 Jetta GLI
i want to add an after market sub and amp to the stock hu how would i do that? ne help would be nice
thanks
scott
p.s. not the subaru sub it is all power acoustic amp and sub
midnight2.5rs-t is offline   Reply With Quote
Old 12-07-2006, 11:59 PM   #38
LastResort
Member#: 99289
http://forums.nasioc.com/forums/showthread.php?t=824983
How do I hook an amp/sub up to my stock radio? Can I run a sub off the rear channels of my head unit?
Yes, there are two common ways to do this. Some amplifiers come with “speaker level inputs” where you run the wiring that was going from your stock radio to your speakers into the amplifier. Another method, in case your amplifier doesn’t have speaker level inputs, is to buy a Line-Out Converter (or LOC for short). An LOC is a whole lot like an extra speaker level input module; you run the existing speaker wires from your stock radio to it, and then you connect the LOC to the amp using RCA cables. Both methods get the signal to the amplifier, and then you just need to run new wires from the amplifier to the speakers/subwoofer.
Old 12-16-2006, 05:47 PM   #39
TimmyZ
Member#: 126885
2006 Outback Sport
Green
In my 2006 Impreza Outback Sport, the factory subwoofer which is under the driver's seat, is definately hooked up to the front speakers. Like the person with the Baja stated, there is a noticable volume drop and bass response drop when you adjust the fader toward the rear.
I would like to increase that volume level, and possibly the overall volume level. Is the best way to do that simply to replace the stock head unit?
If so, what do you all recommend for a double-DIN head unit? I don't like the idea of adding "spacers" or cubbies or trays under or below. I would like it to look as stock as possible.
Thanks.
TimmyZ is offline   Reply With Quote
Old 12-17-2006, 03:21 PM   #40
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Thanks. Sounds like at least a few different models/years connect to the fronts. I've updated my FAQ.
Have you tried the "gain" adjustment on the subwoofer? See the close-up picture in post #4 of the "Stock Head Unit" thread.
I don't really have any recommendations on after-market double-DIN head units. There just aren't nearly as many out there in that size.
You'll find more choices (and probably pay less) if you stick with single-DIN. You can splurge on a Subaru pocket (perhaps from another model) and it will still look stock. Some pockets even have a flip down door.
Old 12-31-2006, 02:54 PM   #41
Burton
Member#: 136265
Default Legacy and new ACC unit!
I've bot this to change my music system in my Subaru legacy spec B:
http://www.subaruparts.ru/i/cat/item/283_2.jpg
and 2 din board
i thought that it would be like on your photos, but when i opened the box i found that it is black (ACC unit)
The problem is that it shows the temperature, mode etc but it doesn't respond to my actions. I push buttons but nothing happens.
Do i have to change anything to install it, or it should be connected to the original plug in the car without any changes?
I'll make photos an maybe videos today.
LHD Legacy spec. B, single zone based acc unit, my2005 bought in Moscow, Russia.
Burton is offline   Reply With Quote
Old 12-31-2006, 05:10 PM   #42
aksti
Member#: 134303
2006 STI
Default 07 sti aux question
I recently put a 07 hu in my 06 sti and I was wondering if anyone knows if there is any way to build a harness for the aux input on it? I know subaru doesn't sell the wiring harness but if someone sells the connecters to hook up to the stereo it would be easy to build my own harness. Thank you.
aksti is offline   Reply With Quote
Old 01-01-2007, 11:47 AM   #43
TooLeg
Member#: 124456
Default Need Help/Legacy GT ltd 2000 Sedan
Hi
i change my radio for a ClearView Model (http://www.clearviewaudio.com/)
i plug all wire with the pinout of my Legacy ( with your information )
every thing go find but..... when i turn back my key at the off position into the ignition switch ,i hear a noise comming from all the speakers .!
PS: if i turn the volume off before, no noise from the speakers
Need Help
Best Regards
TooLeg
TooLeg is offline   Reply With Quote
Old 01-08-2007, 12:31 AM   #44
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Default Aux-in on 2007 stock HUs
I've started looking into this. See this thread: OEM CD changer from 2007
I'd be surprised if Subaru doesn't sell the interconnect cable as a replacement part. That would get you the connector that plugs into the rear of the factory HU. Subaru might only sell it packaged with the "ashtray box" but you could probably cannibalize that for the 3.5mm jack.
I'll update my FAQ thread when I find out more.
Old 01-08-2007, 12:42 AM   #45
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by TooLeg View Post
Hi
Which model ClearView radio?
Do the lights and display on the ClearView deck also stay on after you turn the key off? Or is there only sound from the speakers but no lights and no display?
What kind of noise? Does it ever stop?
Did you install anything besides the new HU (new amp, subwoofer, etc.)?
It's difficult to tell what might be wrong, but it sounds like something is still powering the deck even after the key is off. That might mean you have not wired everything correctly.
Old 01-16-2007, 05:37 PM   #46
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
May be the same answer as above, but just checking. I have a Clarion DXZ865MP HU and would like to put it into my 07 Legacy, and keep the stock sub operational. All I have to do is hook up the wires from the sub straight to the new harness, and it will be operational? correct? what about the ground, and power on? Thanks.
runninstrong is offline   Reply With Quote
Old 01-17-2007, 02:16 AM   #47
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
If you use a wiring adapter ("forward" harness) to install the Clarion, then you can simply plug the sub T-harness between the car's harness and the forward harness, similar to how it's connected with your stock HU now.
You'll need to make one mod to the sub T-harness. See this thread:
stock sub w/ aftermarket hu
post #18 for pictures, and posts 20 & 21 for instructions.
[UPDATE: No mode required. 2007 factory sub T-harness went back to the "old" style -- dropped the square 8-pin connector. T-harness will be plug-n-play.]
The factory sub harness has no power-on wire. See the info in the Stock HU thread.
Old 02-03-2007, 01:38 PM   #48
Bourque77
Member#: 101084
2002 wrx
blue cf hood blue wheels
Will the new 07 head unit fit in an 02 wrx. Plug and play wiring, or is some modification needed?
Bourque77 is offline   Reply With Quote
Old 02-03-2007, 05:20 PM   #49
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
The main speaker/power connector is plug-n-play. From what I've heard, the HU will fit -- the size is still double-ISO DIN.
If your 2002 has the factory under-seat powered subwoofer, it will also be plug-n-play with the 2007 HU.
Old 02-04-2007, 01:49 PM   #50
Bourque77
Member#: 101084
2002 wrx
Thanks for the shor simple answer and no "SEARCH NOOB" comments.
Stock head unit information -- pin-outs, aux inputs, and more SVXdc Car Audio, Video & Security 60 12-06-2015 02:11 PM
Question about factory head units nsnguyen Car Audio, Video & Security 7 04-30-2004 02:26 PM
Question about using head unit to power back speakers STI-o-MY Car Audio, Video & Security 0 12-01-2003 03:06 PM
question about my head unit creature546 Car Audio, Video & Security 1 10-03-2002 07:48 PM
