#1 |
Member#: 132574
SWIC
Vehicle:04 Aspen White Sti GT35r, axis motor,280cams |
I am wanting to install my new 255 fuel pump....how the hell do you get to the gas tank......i looked under the car and the tank is in the middle so you cant really get it high enough to drop it, even if you could you would have to remove the difrential.....help please! pm with something....im wanting to do this tonight, thanks guys
#2 |
Member#: 85736
Vehicle:05 STi Black |
Pull the rear seat. It's under the right (passenger) side access cover.
Good luck! Myles |
#3 |
Member#: 62362
RMIC
Vehicle:2005 wrx CGM |
![]() What a concept! ![]() |
#4 |
Member#: 86788
MAIC
Vehicle:04 STi PSM |
#5 |
Member#: 62362
RMIC
#6 |
Member#: 17332
NESIC
Vehicle:2004 Black STI Not stock anymore |
you know it is true that the forum has gotten so large that successful searches are becoming MORE difficult rather than easier due to overwhelming numbers of results jamming the search function, especially on common keywords.
Go easy. |
#7 |
Member#: 62362
RMIC
#8 |
Member#: 17332
NESIC
tasq - I hadn't thought of that, but I guess you are right that it's snowballing.
Just try searching for "clutch install" - when I did it, it never gives a result because it goes on essentially forever. |
#9 |
Member#: 36528
Vehicle:2002 Impreza Wrx Silver |
#10 |
Member#: 100673
MAIC
Vehicle:04 STi Aspen |
Dont forget to check scoobymods.com
#11 |
Member#: 17332
NESIC
maybe it's my connection...
#12 |
Member#: 36528
Two easy ways to narrow down search results-
1) The word "and" is required if you want to search for more then one word. Ie- "clutch install" will only search for clutch while "clutch and install" will search for both words. If you want to search for the words clutch and install, you must put the "and" between them. If you get too many results for your liking, adding another "and", like "clutch and install and how" might narrow down the results, since it would look for those three words. 2) Searching just thread titles is a search option, and it can also help reduce the amount of search results. Ie- There are probably less threads with clutch install in the title then in the thread, and the search lets ya just search through titles if ya want.... peace Last edited by hippy; 11-30-2006 at 10:02 AM. |
#13 | |
Member#: 95554
Vehicle:2007 The Surly Squad |
#14 |
Member#: 36528
This thread is the first one that comes up if ya type "install and fuel and pump" in the search. There are two links that I posted above which have pictures and directions on how to install a fuel pump. Is it a bad thing if people find this thread when trying to find out how to install a fuel pump? Now if I type the word walbro
, this thread will come up when people add that to their search making this thread that much easier to find for people who want to install a walbro fuel pump. I bet if someone did a search on how to search, this thread would come up too. That's the whole point. The key is knowing how to look for what you want.peace Last edited by hippy; 11-30-2006 at 10:41 AM. |
#15 |
Member#: 14141
Vehicle:2002 Impreza WRX e85forum.net |
And if all else fails use Google's search function and limit the search to only this forum. With their advanced search features you can search for an exact phrase with ease.
Also if you limit your search to threads with a large number of responses you are more likely to get threads with detailed discussion in them --- I usually start a 10 or 20 reponses. Searching is an aquired skill --- the more you use it the better you get at it. Think about words or phrases that are very likely to be related to the issue involved like in the case of fuel pumps, "inspection plate" "filter sock" etc. Larry |
#16 | |
Member#: 67669
MWSOC
Vehicle:2005 2.5 Hybrid WRX evoIII 16G |
just to clarify... |
#17 |
Member#: 103320
Vehicle:2005 wingless aspen white |
well, since he said remove the rear seat, he means ALL of it.
![]() My advice is this. if during the course of the install, you can't remove the rear seat, you should stop immediately and have a professional install the pump. ![]() |
#18 |
Member#: 94070
South East
Vehicle:73 DL Race Car WRB/ Yellow SUby Logo |
If you have a wagon you have to remove all the black foam, then its by behind the pax side rear seat.
#19 |
Member#: 126686
South East
Vehicle:2002 Impreza, WRX World Rally Blue |
I love this board, I hardly ever have to post because 9 out of 10 times I find my answer in the archives. Seriously.
For something that is a quick answer, like "remove the back seat to install the fuel pump" then it is silly not to at least give that much information, and then bitch at them for not searching. |
| Thread Tools | |
| Display Modes | |
| how do you test a fuel pump relay | fyr3 | Newbies & FAQs | 2 | 04-04-2013 05:38 PM |
| How do I log for fuel pumps? | Tommi300 | Open Source Reflashes | 5 | 04-27-2010 11:39 AM |
| How do you tell if Oil pump is Primed? Turbo Oil Line? | Hayaboosted | Factory 2.5L Turbo Powertrain | 3 | 06-25-2008 01:55 AM |
| why with ecutek do you need a fuel pump? | mpower22 | Factory 2.5L Turbo Powertrain | 23 | 06-03-2005 04:16 PM |
| how do install a walbro fuel pump | Jimmy | Normally Aspirated with bolt-on Forced Induction Powertrain | 2 | 07-04-2001 04:06 PM |
