Old 11-30-2006, 12:49 PM   #1
jmc9809
Member#: 33344
2015 WRX
Default Log analyzer - check it out
Hey guys -
I spent a few hours over the weekend and cranked out a simple web based log analyzer. Feel free to check it out and give me feedback. I've only tried this with ECU Explorer logs, but I think it should work fine with any (comma seperated value) logs. If anyone has any other logs (deltadash, etc), fire them my way.
The only analysis it currently does is check for negative KC at positive boost pressure, calculation of max acceleration and maximum vehicle speed. But, it also allows you to plot any data you've captured.
If anyone has any ideas for other analysis that could be done on this data, or ways to make this better, post them up here.
Also, if anyone has any ideas on how to better calculate acceleration (I had issues with that since ECU read vehicle speed seems to lag behind real time), let me know.
http://www.waygate.net/plotter
Please send me any feedback you have. Enjoy!
-Justin
jmc9809 is offline   Reply With Quote
Old 11-30-2006, 01:21 PM   #2
R4ND0M_AX3
Member#: 67483
2005 WRX STi
it didn't work with a streettuner log.
R4ND0M_AX3 is offline   Reply With Quote
Old 11-30-2006, 01:33 PM   #3
jmc9809
Member#: 33344
2015 WRX
what format are streettuner logs? Can you email one to jmc+surtr@waygate.net?
Old 11-30-2006, 01:57 PM   #4
teiva-boy
Member#: 22825
An error has occured. Uploaded data not found on session. Please start over.
This when uploading an ECUExplorer log.
teiva-boy is offline   Reply With Quote
Old 11-30-2006, 02:32 PM   #5
jmc9809
Member#: 33344
2015 WRX
Teiva - send me your logfile so I can take a look. Also, make sure you have cookies enabled (without cookies, the server can't track your session, on which your datafile is stored).
Old 11-30-2006, 02:34 PM   #6
jmc9809
Member#: 33344
2015 WRX
Ewps, looks like the plots don't show up in Internet Explorer. Apparently, IE doesn't like dynamically adding images to an already loaded page. I'll fix it tonight.
Old 11-30-2006, 03:01 PM   #7
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Wow that's sweet. Can you make the bottom row RPM instead of time? Or give that option atleast.
akira02rex is offline   Reply With Quote
Old 11-30-2006, 03:14 PM   #8
jmc9809
Member#: 33344
2015 WRX
I thought about that some, but am not sure it would be valuable since engine speed isn't natively a domain in these logs -- what I mean is that for a single RPM value, there will be multiple values for all other data. It's also not a linear scale, so the plot might come out pretty odd.
I suppose I could do a bar graph or something like that; I'll screw around with it over the weekend if I can find a bit of time and see if I can come up with something useful.
And for you IE guys, try it using firefox for the time being; I'll see about getting it working on IE tonight if I get a chance.
-Justin
Old 12-01-2006, 08:55 PM   #9
jmc9809
Member#: 33344
2015 WRX
Hey guys -
I made a few updates this evening:
- Plots now work in Internet Explorer
- Timestamps in raw milliseconds and HH:mm:ss.xxx (xxx = milliseconds) are now supported
- Empty data values no longer cause plot to fail.
Also, if anyone can send me a streettuner log, I'll add support for that as well.
-Justin
Old 12-01-2006, 10:17 PM   #10
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
Awesome man
Poweredbysnail is offline   Reply With Quote
Old 12-01-2006, 10:22 PM   #11
LastResort
Member#: 99289
Hey, any chance you could post up an "example" button for those of us without a log file handy?
LastResort is offline   Reply With Quote
Old 12-01-2006, 11:09 PM   #12
STISTL
Member#: 69659
07 BMW 335
12.6 @ 111.1
Nice work. Thanks
STISTL is offline   Reply With Quote
Old 12-02-2006, 01:00 AM   #13
jmc9809
Member#: 33344
2015 WRX
Sure thing. Here's an example file: http://www.waygate.net/13-10-2006_20h14m50s.csv
And a screenshot:
Old 12-02-2006, 02:06 AM   #14
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
-8.0?
Looks cool though. I'll try to find a UTEC log and see what it does with it.
RP31 is offline   Reply With Quote
Old 12-02-2006, 02:10 AM   #15
jmc9809
Member#: 33344
2015 WRX
Originally Posted by RP31 View Post
-8.0?
Heh, yeah I actually changed one of the entries in that log to make sure that the KC analysis works, the real value was positive.
Would you mind emailing me a UTEC log so I can check it out? jmc+surtr@waygate.net.
Old 12-02-2006, 02:47 AM   #16
LastResort
Member#: 99289
Very cool! you going to be keeping that around for a while?
Old 12-02-2006, 12:30 PM   #17
jmc9809
Member#: 33344
2015 WRX
Yep, planning on leaving it up indefinitely. I'll probably make changes to it from time to time.
Old 12-03-2006, 01:05 PM   #18
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I started the very very basics of something like this, but not web-based. HTTP does me no good when I am in a parking lot somewhere after datalogging I guess I will have to go through with my plans... or just buy DataLogLab.
Cool though.
I will send you a Hydra Nemsis 'Export to CSV' log file for testing.
jblaine is offline   Reply With Quote
Old 12-03-2006, 05:28 PM   #19
Airboy
Member#: 72829
2006 WRX
2015 WRX
In this case, my spreadsheet may be of use, if you have MS Excel of course.
It is over at Enginuity.org in this thread:
http://www.enginuity.org/viewtopic.php?t=957
Airboy is offline   Reply With Quote
Old 12-03-2006, 08:51 PM   #20
jmc9809
Member#: 33344
2015 WRX
Cool, thanks airboy. I may do a non web based version of this at some point too.
I just added support for scatter plots -- you can now put whatever you want on the x-axis of the plot.
Old 12-03-2006, 10:24 PM   #21
varmint007
Member#: 13626
0298 M5M3
E39E36
Wow, nice work!
varmint007 is offline   Reply With Quote
Old 12-03-2006, 10:33 PM   #22
R4ND0M_AX3
Member#: 67483
2005 WRX STi
They're on my work laptop. I'll try to send it tomorrow.
It might be getting hung up on the header row. Also I don' have that many logs that are small enough. might consider bumping the file size limit.
Old 12-04-2006, 01:59 AM   #23
jmc9809
Member#: 33344
2015 WRX
Yeah, originally there was no limit; problem is with large file sizes the CPU on the server gets hammered pretty hard calculating the plots. You can pretty easily break a large file into multiples since these are just plain text. I will go ahead and bump the size limit to 500k though.
-Justin
Old 12-04-2006, 03:55 AM   #24
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
I am just subscribing for now. I will throw a ST log or 2 in there tomorrow. Also will this show where the fastest acceleration point was?
I am really interested to see where this project heads.
Good luck and happy tuning
scoobdude is offline   Reply With Quote
Old 12-04-2006, 01:33 PM   #25
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Excellent. I will definitely check this out.
Bought a Honda.....and love it check it out, you'll like it JonP North West Impreza Club Forum -- NWIC 12 07-18-2007 01:03 AM
Parting out 03 WRX. Check it out. wishbone318 Private 'For Sale' Classifieds 38 03-04-2004 05:19 PM
Parting out 03 WRX. Check it out. wishbone318 Mid Atlantic Impreza Club -- MAIC 33 02-14-2004 07:53 PM
It is Done, Check it Out Flat Black and Blue 02 WRX mrtrex Member's Car Gallery 24 07-11-2003 09:55 AM
check it out...check it out...my pics from detroit :D shukes24 Mid West Subaru Owners Club Forum -- MWSOC 7 01-24-2001 11:01 PM
