Old 12-06-2006, 07:32 AM   #1
psychochild
Member#: 59353
2003 2.5 TS-Turbo
Pearl Ridge Blue
Default How to do the "cars" Photoshop
Per Request: Here is a step by step method for how I do the "CARS" chops:
Step 1: Get a photo of your car,something medium resolution is good, if the photo is two low then the cars parts will look odd, if its a crazy detailed RAW file, the final product will look more fake. so heres the photo Im using, Its from the old thread compliments of 04ts:
Step 2: Go to the cars wallpaper site http://www.filmtotaal.nl/module.php?...ew&wid=0317219 and find a car mouth and eyes that suit your picture, It dosent mater if the car is facing left or right, or the perspective angle, we can change all that later, for this chop im using Flo, Open this wallpaper at the highest resolution:
Step 3: with your CARS wallpaper and using the freehand laso (newbies) or pen tool select a large area around the mouth. Make sure you include all the mouth corner lines. this selection dosent have to be perfect.
Step 4: Drag the mouth to your car photograph and set the opacity to around 75%
Step 5: If your mouth is backwards (as in this case) go to the edit menu>transform>flip horizontal. Now comes the hard part: using the transform functions (rotate, scale, and a lot of perspective) drag the mouth around so it covers the area of your front bumper. I find it very easy to use the foglight holes as a refferance, putting the edes of the mouth just a little bit over the inside crease (blue) just make sure you pay attention to the bottom and sides of the mouth (red) and that the perspective of the mouth fits the perspective of the car
step 6: go back to your wallpaper and using the plygonal laso select a general area around the eyes/windshield. again this selection dosent have to be perfect just make sure you're outside the windshield:
Step 8: Drag the eyes over to your photo and set the opacity to 75%. Ok, as with the mouth you have to use the transform tools (rotate, scale, A lot of Perspective) to fit the windshield around your own windshield (pat attention to the perspectives! (blue lines) this will make the differance between something that looks realistic and something that looks stupid) Pay attention to the eyebrows, make sure the color goes all the way to the top corners (red) make sure your eyes
Step 9: hide the visibility of the eyes layer (the little eyeball in the Layers Pallet) and very carefully using the magnetic laso or Pen tool select around the edge of your windshield. you want to select under your windshield wipers. Then go up to the menu Select>Feather and set that to 2 or 3 pixles (a little more if your using a big file)
Step 10: Select the inverse (ctrl+shift+I) and without deselecting anything, click on your CARS eyes, make it visible again (the little eyeball) and press delete. this should trim around the edge and make the eyeballs fit your windshield, Now you can play with the opacity, to preserve the reflections in the windshield I think about 85% is good.
psychochild is offline   Reply With Quote
Old 12-06-2006, 07:32 AM   #2
psychochild
Member#: 59353
2003 2.5 TS-Turbo
Pearl Ridge Blue
Step 11: Going back to the mouth, make sure you have the brush pallet open (Press F5) and select the ereaser tool. pick a fuzzy brush (see below) thats about 10% the size of the mouth, start ereasing around your mouth to remove all hard edges, make sure you dont erease any of the actual mouth.
Step 12: Set the opacity of the mouth back up to 100% and using progresively smaller fuzzy brushes erease the rest of the color that covers the fog lights, grill, under the bumper, headlights. basicly everywhere that isnt solid paint (Red)
Step 13: Go to Image>Adjustments>hue and saturation and change the color of the mouth to the color of your car, If you have a black white or silver car dont just change the saturation to zero! there are about a million reflected colors in your paint, look at whats most domminant (usualy a light blue) and keep a little of this color in your mouth.
Step 14: youll notice that you can still see some of the grill under the mouth, the best way I've found for getting rid of this is tedious. going back to your car photo and using the healing and clone stamp tools. If you arent comfortable with these then using another fuzzy brush and painting in some of the color of your car over the hole will also work this takes a pretty long time, I usualy try to clone the piece of the bumber between the fog lights and grill and use vertical strokes to cover the middle. heres an in process shot:
Step 15: Go back up to the eyes and make a general selection around the eyeballs, then feather it out (like before) about 5 pixles, Then select the inverese again (ctrl+shift+I)
Step 16: Do the same color adjustments as on the mouth and then you should be done!
There is plenty more to add, you can use the wheels or just about any aspect off the cars wallpapers, Play with it! then post what you make!
Old 12-06-2006, 07:36 AM   #3
Burnall4
Member#: 35518
2011 Forester XT
damn thats a hell of a write up... +100000000 for you
Burnall4 is offline   Reply With Quote
Old 12-06-2006, 07:44 AM   #4
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
yea for really!!!
99subi is offline   Reply With Quote
Old 12-06-2006, 07:47 AM   #5
psychochild
Member#: 59353
2003 2.5 TS-Turbo
Pearl Ridge Blue
Im sick and i cant sleep anyway, finished my homework, what else is an art student to do? (but photoshop ofcorse!)
Old 12-06-2006, 08:03 AM   #6
psychochild
Member#: 59353
2003 2.5 TS-Turbo
Pearl Ridge Blue
Old 12-06-2006, 08:17 AM   #7
04ts
Member#: 57517
2010 Impreza WRX Ltd
Satin white Pearl
thanks for sharing psychochild
04ts is online now   Reply With Quote
Old 12-06-2006, 08:26 AM   #8
Boosted 03 REX
Member#: 102747
1992 5.0 Mustang LX
Subscribing!!
Boosted 03 REX is offline   Reply With Quote
Old 12-06-2006, 10:21 AM   #9
darroj
Member#: 113645
2004 PSM WRX
Stage 1ish
thanks for making me not have to do anymore chops haha! good write up!
darroj is offline   Reply With Quote
Old 12-06-2006, 10:30 AM   #10
S.G.D
Member#: 36448
that aztec is awesome.
hahahahahah
S.G.D is offline   Reply With Quote
Old 12-06-2006, 10:41 AM   #11
clbd39
Member#: 104078
2013 WRX
subscribed... thanks
clbd39 is offline   Reply With Quote
Old 12-06-2006, 10:51 AM   #12
Handsdown
Member#: 29355
if you're worried you'll delete or erase something important, i'd suggest using a layer mask on the mouth and eye layers, that way you can get them 'trimmed' without actually losing it forever if you trim too much. search the web for how to do that if you don't already
Handsdown is offline   Reply With Quote
Old 12-06-2006, 12:28 PM   #13
Sylon
Member#: 109000
2006 Impreza 2.5i
Obsidian Black Pearl
Thanks for the info and the work!!!
Sylon is offline   Reply With Quote
Old 12-06-2006, 01:05 PM   #14
CatfaceType-R
Member#: 81102
Old 12-06-2006, 01:26 PM   #15
SUBYDOODIE
Member#: 71490
05 cgm wrx
rubbing axles haha
hahahaha see... he asks for his to be done like 7x in the other thread... now he does it himself... someone do it for him..
SUBYDOODIE is offline   Reply With Quote
Old 12-06-2006, 01:30 PM   #16
Handsdown
Member#: 29355
some cars are easier to do than others... the color in the picture has a lot to do with it. the less reflections in the paint, the better it will look.
my best:
http://img56.imageshack.us/img56/2222/typercars1zv1.jpg
my worst:
http://img243.imageshack.us/img243/671/pastecw3.jpg
it all depends on the original picture you go off of.
soontobe- i think this thread would be better if there are no requests. please make requests in the request Cars thread, leave this thread for finished products, tutorials, and tips.
Old 12-06-2006, 01:36 PM   #17
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Nice write up. Thanks!
chimchimm5 is offline   Reply With Quote
Old 12-06-2006, 01:44 PM   #18
4hero
Member#: 125638
2006 Impreza STi
Obsidian Black
good tutorial mate, now I just need to add to yours to do this
4hero is offline   Reply With Quote
Old 12-06-2006, 01:58 PM   #19
STi-JDM
Top Scoob 023
Member#: 90373
05' STi. 89' GT-R
00' GT-R ; LCM x WFC
can I get the hi res?
STi-JDM is offline   Reply With Quote
Old 12-06-2006, 02:21 PM   #20
4hero
Member#: 125638
2006 Impreza STi
Obsidian Black
you can Check out my deviantart for a 1280x1024 version. (select the download option on the left for the biggie)
Old 12-06-2006, 02:22 PM   #21
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
I blew water all over my monitor when I saw this
Capt Crunch is offline   Reply With Quote
Old 12-06-2006, 02:33 PM   #22
wrxsnowstyle
Member#: 122973
02 WRX wagon
eyes are dialated mang....that rex is on crack...
wrxsnowstyle is offline   Reply With Quote
Old 12-06-2006, 03:25 PM   #23
Distinctive
Member#: 68122
2004 dbl u ar ex
VF34 w/white paint
thanx for the help.....my 1st time using photoshop...hereya go...
Distinctive is offline   Reply With Quote
Old 12-06-2006, 03:51 PM   #24
Handsdown
Member#: 29355
not bad but needs more blue in the mouth.
really take your time getting to know the Hue/Saturation tool (ctrl-u) and curves tool (ctrl-m)
Old 12-06-2006, 04:36 PM   #25
rally_on
Member#: 86849
2005 GMC Savana
white
pics from far away work the best IMO good chops in here
rally_on is offline   Reply With Quote
Goddamn, the Brits know how to do the blues Fach Off-Topic 28 01-21-2008 03:24 PM
instructions on how to do the painted headlight mod? juztin180 Interior & Exterior Modification 2 01-02-2003 12:59 PM
more specific driving advice HOW TO do the "flick" Davenow General Community 1 01-02-2003 02:02 AM
Custom cat back exhaust, how to do the bends? WhiteWRXBoy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-06-2002 02:42 AM
Hey anyone know how to do the fog light mod ? s-one Mid Atlantic Impreza Club -- MAIC 4 06-22-2001 04:12 PM
