![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 | ||||
Street's closed, pizza boy
Member#: 17301
MAIC
Vehicle:is the "dark side" 06 Evo #7 STU, 05 Saabaru |
The OFFICIAL Brake Upgrade / Big Brake Kit FAQ
The goal is to explain the basics of brake upgrades. This used to be part of the “best coilover” thread but I felt it was worth splitting off so it could be discussed independently. My brakes suck! How do I fix them? They don't suck, I swear. They may not feel great, but that does not mean they are not working. Read the rest of the FAQ, but try to remember that pedal feel and stopping distance are not the same thing. You can do some mods that *may* help pedal feel (stainless lines, master cylinder brace) but those will not stop you any faster. Ultimately you are limited by the amount of traction your tires can provide. That is why the tires are one of the most important (and probably overlooked) part of your braking system. If you are spending money upgrading your brakes and driving around on cheezy all season tires you will not stop as fast as the guy with stock brakes and good summer tires. Anyway, read on ![]() How do my brakes work? If you’re curious and want to see diagrams and such, HowStuffWorks has descriptions for both disc brakes: http://auto.howstuffworks.com/disc-brake.htm ![]() And drum brakes: http://auto.howstuffworks.com/drum-brake.htm What are some common brake upgrades? The most common brake upgrades are: * brake pads * brake lines * brake rotors * brake fluid * brake calipers / big brake kits, including swapping to bigger rotors * drum to disc conversion for the older cars Some other modifications that people do: * Master cylinder brace * (suggestions?) Why would I put on new brakepads? For the non-STi owners, you would typically switch pads for a few reasons: -You want better bite out of your brakes -You want better modulation out of your brakes -You want to increase your pads’ temperature range so they will not fade on you in hard driving. (Fade is discussed later) For STi owners, the pads are pretty aggressive from the get-go. You still might want to upgrade them for the same reasons as above, but you might also want to “downgrade” them to pads that will dust less. A lot of people think that not having to clean off their wheels is more important than having aggressive pads. What kinds of brake pads are out there? http://www.se-r.net/car_info/brake_p...l#Brake%20Fade Quote:
Cliff notes: http://forums.nasioc.com/forums/show...39&postcount=4 Quote:
http://forums.nasioc.com/forums/show...9&postcount=54 Quote:
The lines that come on your car are typically made of rubber, which allows for some flex. By installing stainless steel brake lines, you can eliminate some of that flex and have a firmer pedal. When shopping for aftermarket brake lines, you should make sure that they are DOT approved. Ideally they will also be coated, just in case your brake lines ever come in contact with something, although that is not a cure-all. Manufacturers of stainless lines include StopTech, Goodridge and STi. I’ve done lots of brake upgrades, but my pedal still feels soft. First, make sure you have a good bleed. Even some shops screw it up sometimes. If you have a good bleed and you still feel that your pedal is soft, Mike Shields explains this phenomenon here, the dual stage brake booster: http://www.spdusa.com/soft.htm You can switch to a single stage booster, but most people don’t bother. I’ve never driven a car configured that way so I can’t speak to how much better it is. But basically, as Myles says here, you’ll never have that “the car is off” feel as long as you’re running a brake booster: http://forums.nasioc.com/forums/show...highlight=feel Quote:
Basically, for most people, rotors are rotors. I wouldn’t go nuts buying bling bling rotors unless they go with your big brake kit. They are chunks of metal that are going to slowly go away over time and that’s about it ![]() There are some distinguishing features among rotors: * two piece versus one piece: Two piece rotors have a lightweight hat in the middle that has the holes that mount to the hub, attached to an outer ring that contains the part of the rotor that the pad will grip. Here’s an example: ![]() * Vented versus non vented: For the 02-05 WRX at least, the front rotors are vented but the rears are not. The 06 starts out better, with the 4-pot/2pot setup with vented rotors front and rear. The rears typically do less work, so this is OK. But if you are driving hard enough you may want to upgrade to vented rotors in the rear. (I think the new and old Legacy Turbo have vented rear rotors) *Slotted versus drilled versus plain: Really there’s not much of a reason to use anything but solid. Slotted and drilled have tradeoffs: * Might get a little bit better bite off of the slots/holes, but might wear pads faster as a result * More prone to cracking around the slots/holes * Slots might help a little bit in wet weather. * Slotted/drilled are usually more expensive. Basically, most of the problems that slotted/drilled rotors were built to solve are no longer problems. If you really want all the tech explaining why the drilled/slotted stuff is useless, check out this thread: http://corner-carvers.com/altimathread.php.html MaddMatt and Cobra make a compelling case for why drilled rotors are not a good idea In addition there is tons of valuable information about brakes in there. You may be thinking "but I have had drilled rotors and they haven't cracked". That's possible, but why risk it? Just for bling? If your brakes fail, you might end up somewhere you don't want to be. I think my rotors are warped. They're probably fine and just need a re-bedding: http://www.stoptech.com/whitepapers/...otors_myth.htm It's possible to warp rotors, for instance if you overtorque or unevenly torque the lugnuts. But most cases where people have warped rotor feel, are not warped rotors. Here's an excellent thread on the subject: http://forums.nasioc.com/forums/show....php?t=1151329 What kind of brake fluid should I use? If you’re not tracking your car, you can stick with whatever the car has already. It’s really only during track events that you’ll see the temperatures that will cause your stock fluid to go out of its range. Both the ATE Super Blue and Valvoline SynPower have gotten good reviews: http://forums.nasioc.com/forums/show....php?t=1051150 One nice thing about the Super Blue is that ATE also makes a Typ200 fluid that is the same as Super Blue, but in a gold color instead of blue. This makes it easy to tell when you’ve fully flushed the system from one to the other. If you see fade with those, there are some more expensive options like Motul. You should not use DOT5 brake fluid as it is silicon based and will not work right with your Subaru’s brakes. DOT 4 and DOT 5.1 are OK. I just got new pads. What should I do to "brake" them in? You need to brake... er... break in your new pads to build a layer of pad material onto the rotor. There are more details here: http://www.stoptech.com/tech_info/wp_bedintheory.shtml http://www.stoptech.com/tech_info/wp_bedinstock.shtml The basic jist is: You find a place with very straight roads and no traffic. You do a series of stops from a high speed to a low speed - maybe 60 mph to 10 mph nine or ten times. Then, let the pads cool - i.e. drive on the highway for a while without touching them (if possible) or at least without leaving your foot planted on them (i.e. don't stop on a hill). StopTech recommends doing this cycle twice for street performance pads. I have never done it more than once and it's always worked out OK. Your mileage may vary. It's pretty hard to find a safe spot to do this, and as always, NASIOC does not condone anything illegal or dangerous. Your best bet is to pop a Red Bull at 2 AM and do it while no one else is on the road or something along those lines.
#2 | ||||
Member#: 17301
MAIC
Part 2: Big brake kits and other meta-issues.
Do I need to upgrade my brakes? In general - your stock brakes are probably pretty good (depending on which car you start with). I quote Gary Sheehan a lot in this FAQ. He RACED, yes RACED, a WRX on the stock calipers in NASA's US Touring Car Challenge - basically NASA's equivalent of SCCA's World Challenge. Serious touring car racing. He ran on the stock calipers for an entire season. And did well. Consider this when you are thinking about whether or not you need to upgrade your brakes. (More info: http://forums.nasioc.com/forums/showthread.php?t=197590) Ultimately he and his team went with Stoptechs - not because they were seeing fade on that setup, but because the heat generated from it was causing unnecessary wear elsewhere. (And again... they were RACING... not doing track days, not autocrossing, and not doing "spirited driving".) If you are doing anything other than tracking the car, or driving like an asshat on public roads, you likely do not need a big brake kit or anything close to it. If you are fading your brakes driving on the street, slow the **** down. What are some reasons people upgrade their brakes? 1. They want to decrease stopping distance. 2. They want their brakes to handle heat well and not fade (i.e. track use) 3. They want their car to brake "flatter" 4. They want their brakes to look cool 5. They want to reduce unsprung weight. Let's look at those reasons. 1. Decreasing stopping distance How can I shorten stopping distance? What's the best bang for buck way? This one is easy - TIRES! As Stoptech so elegantly says: http://www.stoptech.com/tech_info/wp...lections.shtml Quote:
"I don't believe you... I installed cross drilled rotors and my car stops on a DIME now!" Your butt dyno may be tricking you. http://forums.nasioc.com/forums/show...6&postcount=39 Quote:
![]() I don't believe you... I have a BBK not just pads... I swear I stop like 50 feet sooner! http://forums.nasioc.com/forums/show...7&postcount=26 Quote:
Here is a pretty good thread: http://forums.nasioc.com/forums/show...hreadid=351743 2. Reducing brake fade What is brake fade? Brake fade occurs when your brake system is put into a temperature range that it was not designed for. This can happen if you take your car to a track event without upgrading the brake pads and brake fluid. The result is that you will push the brake pedal, but the car won’t slow down, which is quite unpleasant ![]() There are three types of brake fade: http://www.se-r.net/car_info/brake_p...l#Brake%20Fade Pad fade: your pads are designed to work inside of a certain temperature range. If you get them too hot you can get them outside of that range, especially if they are near the end of their life. You resolve this in two ways: 1) driving within the limits of your pads (duh) or 2) installing pads with a higher temperature range. Green fade: If you do not bed your pads in, they will not grip like you expect them to. This is easily fixed. Bed in your pads! Fluid fade: Like pads, brake fluid has a temperature range it is comfortable operating in. If your fluid is not up to the task, it can boil, which introduces air bubbles into the brake system. This results in a soft pedal and can also be quite scary. Fortunately, better fluid is cheap. "I'm not an asshat, I track my car, but I see fade. What should I do?" Make sure you have pads that are track-worthy. There are basically three categories of brake pads: -street-only pads: won't hold up to a track day. Either don't try, or drive like a chicken on the straights -street/track pads: you can track these, but you will have to deal with the tradeoffs - likely noise and dust. -track-only pads: you don't want to daily drive these, as the noise and dust will likely annoy you. They may also eat your rotors prematurely. Make sure you also have a brake fluid that won't boil easily. Finally, if you still see fade, congratulations! You're probably working the car pretty hard. It's time to start looking into vented rotors and big brake kits. You can also try brake ducts. Some vendors (i.e. RaceComp Engineering) make some, and some people have made their own. What else should I know about picking pads for track use? A thread full of good advice, especially Todd TCE's post, is here: http://forums.nasioc.com/forums/show....php?t=1269968 3. Braking "flatter" When I hit the brakes, the nose of the car dives down pretty significantly. Can I fix this? Most Imprezas come with a fairly significant front brake bias from the factory. For a discussion of brake bias, check out this article on StopTech's website: http://www.stoptech.com/whitepapers/...erformance.htm There are a few ways to make the car more "flat" while braking: -Suspension mods. Making your suspension stiffer (i.e. the springs) (and lower - right?) will make the car dive less. -Reduce front brake torque -Increase rear brake torque OK, I've got a stiffer suspension. I'm decreasing weight transfer under braking now, right? No ![]() http://www.turnfast.com/tech_handlin...eightxfr.shtml Quote:
![]() How can I change brake torque? Legacy777 has done a bunch of work on this subject. http://forums.nasioc.com/forums/show...t=brake+torque His Excel spreadsheet for calculating brake torque is here: http://www.main.experiencetherave.co.../brakemath.xls Some of the variables that you can easily control are: * Pad coefficient. If you want more rear bias, put a more aggressive pad in the rear than the front, and vice versa. * Rotor size. This changes the effective diameter of the rotor. Bigger rotors = grab the rotor further out from the center = more effective torque. * The "H6" upgrade is very popular among Impreza owners because it's so damn cheap and has a noticeable impact on the car's bias. For the 2.5RS's and the 02-05 WRX's, the stock rear calipers can be used with a larger rotor from the H6 Legacy, and a different caliper bracket to move the stock rear caliper further out to accomodate the bigger rotor. You definitely need the OEM caliper bracket, but you can choose from several 290x10 rotors if you want slots or something. * Unabomber's guide to the H6 upgrade is here: http://forums.nasioc.com/forums/showthread.php?t=522006 * A list of non-Subaru H6 sized rotors is here: http://forums.nasioc.com/forums/showthread.php?t=562057 * Piston area. The visual size of the calipers has NOTHING to do with how much torque they generate. The crappy looking two pots from the 02-05 WRX have more piston area than the 4-pots on the 06 WRX or the StopTech kit for the 02-05 WRX. If the 4-pots are placed on an 02-05 WRX they will reduce the front piston area and thus decrease front brake torque. 4. Making the brakes look cool I saw this sweet BBK from some cool sounding Japanese company. I want to put it on my car to impress my friends. Should I? What you should never do is compromise your car's safety for looks. I didn't realize how bad some of the BBK's on the market were until I saw this: http://www.stoptech.com/company_info...hallenge.shtml Now - admittedly this is StopTech's website. But StopTech doesn't make any outrageous claims. The stock RSX in that comparison was on Michelin Pilot MXM4's - an all season tire. It did 60-0 in 132 feet. Of the two StopTech shod cars, one was on Hoosiers (very sticky) and one was on Advan A032R's (also very sticky). So you'd expect them to stop noticeably shorter than the stock car on all seasons. But the terrifying thing about that comparison is how bad some of those high dollar kits are. A Ford Expedition stops 60-0 in 140 feet, 8 feet slower than our stock RSX (see http://autos.yahoo.com/ford_expediti...4-performance/) -The Brembo kit, on sticky Advan 048's, was a foot slower to stop than the stock RSX. -The Wilwood kit, on Nitto NT01's (race tires), was 11 feet slower to stop than the stock RSX, and equivalent to the Ford Expedition. -The Project Mu kit, on the same Hoosiers that the StopTechs stopped in 110 feet with, stopped at 171 feet. To put that into clearer terms, if they were 30 feet behind the Expedition at 60 mph, and both the Expedition and the Project Mu RSX hit their brakes at the same time, the RSX would still rear end the Expedition. That's freaking ridiculous! And how many of you leave 30 feet between you and the car in front of you at 60 mph? There are other variables - wheel alignment for instance, maybe some of the cars were broken - but it's a pretty scary looking test. Cliff notes: make sure your bling is well-engineered bling. 5. Reducing unsprung weight Will my BBK be lighter or heavier than stock? Here's a list: http://forums.nasioc.com/forums/showthread.php?t=596404 "what else should I read about brakes" There are some great articles on stoptech.com: http://www.stoptech.com/technical/ I hope this is helpful! Last edited by ButtDyno; 12-21-2008 at 01:02 AM. |
#3 | |||||
Member#: 17301
MAIC
I just bought new pads. Do I need to buy new rotors or have my rotors turned?
I just bought new rotors. Do I need to buy new pads? This comes up somewhat frequently. Some folks have asserted that you need to buy them in pairs. So I sent this question to some of the NASIOC brake experts: Quote:
![]() 1. Eric @ StopTech: Quote:
#4 | |||||||
Member#: 17301
MAIC
How do I swap from drums to discs?
Upgrading Rear Brankes '03 TS - Drum to Disc http://forums.nasioc.com/forums/show....php?t=1153675 I have a late 2002/early 2003 WRX. What pads do I need? StopTech has a handy guide here: http://www.stoptech.com/tech_info/faq_wrxcalipers.shtml Drilled rotors *must* be good for track use! Porsche/BMW/Lamborghini use them on their cars! Here's some things I've found from the major brake manufacturers: Stoptech: http://www.stoptech.com/tech_info/glossary.shtml Quote:
http://www.baer.com/technical/faq/index.php Quote:
http://www.wilwood.com/Centers/Infor...pages/faqs.asp Quote:
http://www.apracing.com/car/fstudentsae/index.htm Quote:
![]() But if you cast the holes in place, it should be better than drilling them, right? No From Brembo:http://www.brembo.com/ENG/HighPerfor...List/faq22.htm Quote:
#5 |
Member#: 59199
South East
Vehicle:2008 STI DGM |
wow~ Lots of Infos here. These are exactly what I was looking! Big thumps up for you, buttdyno. so which BBk is the best?? lol jp~
And how come this is not a sticky?? |
#6 |
Member#: 17301
MAIC
It's in the "faqs and threads of note" but I'll sticky this and the swaybar one for a couple weeks to get people's feedback.
#7 |
Member#: 7958
Vehicle:09 GH B+ |
nice
One minor correction-"the WRX has vented front brakes and solid rears"- true w/ the USDM until 06 ![]() As one who has tracked his car a fair amount on oe size rotors- our cars are heavy and I can't emphasize what a difference ducting can make in keeping things "relatively" cooler (they still get smoking hot!) |
#8 |
Member#: 17301
MAIC
#9 |
Member#: 69232
MAIC
Vehicle:2004 WRX STI WRB |
Awesome info and it should definitely be a sticky. My STI's pads and rotors are shot right now. Looking at the cost of replacing them I was like why dont I upgrade while I am at it. Now I am asking my self why dont I put that money some where else in the car! I still have a lot more to research and reading to do but this was beyound helpful. Thanks BD!
#10 |
Member#: 3496
NESIC
Vehicle:1995 Roadmaster Beige |
trying to find info on the 4 pot 2006+ swap.
I hear they just bolt on... is this true or do I need some sort of caliper bracket? |
#11 |
Member#: 120386
South East
Vehicle:2000 BRP 2.5RS Coupe Wow the 89 Civic is fast |
I really love getting quality information like this!!!
I just did my "big brake upgrade" on my 2000 RS new hawk hps pads stainless lines turned existing rotors ATE super blue $300.00 total ohh forgot the main component, Tires Falken ziex 512 vr 16 $500.00 installed my butt dyno is VERY pleased where can i get the master cylinder brace |
#12 |
RIP 3/18/1965 to 1/10/2008
Scooby Specialist Member#: 91500
MWSOC
Vehicle:hmmm sr-30+640cc=? I has teh Endless BBK. |
Man, only got to the 2nd post while reading & I just had to say 'thanks'. So, thanks!!
#13 |
Member#: 16739
South East
Vehicle:2002 WRX, 2005 STI silver |
Buttdyno wrote that stock brakes were used in racing applications:
"Ultimately he [Sheehan]and his team went with Stoptechs - not because they were seeing fade on that setup, but because the heat generated from it was causing unnecessary wear elsewhere. (And again... they were RACING... not doing track days, not autocrossing, and not doing "spirited driving".)" I agree that stock brakes can be set up to work without fade, and eventually the excess heat will damage something else. The first sign of damage to other components that I have seen from track events in my own 2002 WRX, and friends', has been piston dust boots melting and ripping. No feeling of fade while all this was happening, but the design of the stock brakes do not sweat off the heat very well. ***I have heard that a 2 piece with aluminum hats will not carry as much heat toward the hub. Is that true?*** Also my 2 cents on cross-drilled rotors for the 02 WRX is DONT BUT THEM. They sound like a good idea, degassing and all that stuff. I paid big bucks on some Brembo cross-drilled for my stock 02 WRX, and went to the track with nice Carbotch Panther pads and Toyo RA-1s. The Brembos did fine on the track, but cracked in the paddocks while cooling. The Cracks were so big you could hear it slapping the pad when the car rolled. I couldnt even drive the car until I replaced the rotors (luckily i brought some). My solid rotors have always been dependable (all 4 sets), and only had to be replaced for minimum thickness reasons after many track days. Thankfully they are cheap. And it is easier to replace them at $70 for 8-10 track days versus $1500 for a big brake kit ( plus another $1500 for new 17"s to go over big brakes) Last edited by X-VWGLX; 01-21-2007 at 01:07 PM. Reason: spelling |
#14 |
Member#: 82595
MAIC
Vehicle:let me see ur feetz |
wow so i should deffinately keep my wrx 2pots?? opposed to a oem 4pot upgrade and stoptech for the 02-04wrx.
#15 | |
Member#: 16739
South East
I think the Stoptechs would be naturally more reliable at the track than our 2pots, probably no reason to buy them unless you frequent the track. Here is what I do know: A good set of agressive (track) pads are all you need to make the stock brakes feel like a big brake kit. I loved my Carbotech Bobcats on the street (not for track use). longevity of this setup at the track...not so good, but cheap and easy to keep going. |
#16 |
Member#: 50167
MWSOC
Vehicle:1996 Subaru STI RA White |
It would be nice if there was some information on bedding pads in here. Add that to the FAQ!
#17 | |
Member#: 82595
MAIC
I had EBC yellow's now i am wondering if I should go back to them, carbotechs, or hawks. I understand all are greatand i did love the EBC's. |
#18 | |
Member#: 16739
South East
the best thing to do is brake rapidly form 60 down to almost 0. Repeat 3-4 times until they really stink. Now park the car. Allow them to cool for at lest 30 min. U R done. |
#19 |
Member#: 141438
Thank you guys! Informative thread.
#20 |
Member#: 124663
South East
Vehicle:2003 AW WRX 2008 GG Evo X MR |
Wow. I read all those white pages at StopTech.com. Great info! It's probably going to save me a ton of cash.
#21 |
Member#: 17301
MAIC
Bump for folks who haven't seen it yet. Feedback is always welcome.
#22 |
Member#: 124348
NESIC
Vehicle:1996 OBS- Proj. Car I do vinyl graphics |
Very informative for those who know little (raises hand) about braking and what is affected and when.
I came here looking for a DIY on BBK, and am now more informed. However, I still have a question in my mind... Can I put 2005 WRX brakes/rotors/calipers/mounting brackets fit on my 1996 OBS with rear discs? |
#23 | |
Member#: 25119
BAIC
Vehicle:2005 Impreza WRX STi Silver |
They suggest you do 10 times a 60 MPH to 10 MPH hard braking to lock up your tires/abs "(about 80 to 90% of the deceleration required to lock up the brakes and/or to engage the ABS)," from the stoptech website. After this you want to let the car cool by driving at a good speed without braking to a stop but applying the brakes? This part is a little confusing.. After cooling, you want to do another 10 times 60-10 hard braking and let it cool after that. http://www.stoptech.com/tech_info/wp_bedinstock.shtml (the link is also on top of the page) My question is, what do they mean by "The system should then be allowed to cool, by driving the vehicle at the highest safe speed for the circumstances, without bringing it to a complete stop with the brakes still applied." Are we cruising on the freeway while left foot braking or are we just driving normally while braking from time to time? |
#24 |
Member#: 17301
MAIC
I think you just need to break up the sentence differently.
I think you're looking at it like this: (The system should then be allowed to cool, by driving the vehicle at the highest safe speed for the circumstances), (without bringing it to a complete stop) (with the brakes still applied). But I think the intent is: (The system should then be allowed to cool, by driving the vehicle at the highest safe speed for the circumstances), (without bringing it to a complete stop with the brakes still applied). As in - you can hit the brakes if you have to but don't sit at a stop light with your foot holding the pads against the rotors. I'm sure ESmooth will check in tho, now that the StopTech bat-signal has been fired into the sky. john |
#25 | |
Member#: 126003
International
Vehicle:2003 ... grey |
| Thread Tools | |
| Display Modes | |
| The problem with changeing Big Brake Kit in the front and leaving the stock | ChAi | Brakes, Steering & Suspension | 5 | 03-19-2006 10:34 PM |
| Anyone installed the AEB Front O.E. Caliper Big Rotor Brake Upgrade Kit? | WhiteWRoX | Brakes, Steering & Suspension | 2 | 06-02-2002 11:05 PM |
| Big Brake Upgrade Kit in the Works | bsquare | Brakes, Steering & Suspension | 50 | 05-20-2001 04:13 PM |
