Old 11-30-2006, 02:04 PM   #26
fastwrx25
Member#: 126441
03 bugeye
^^me too.
"If you build it they will come"
Old 11-30-2006, 04:48 PM   #27
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
Originally Posted by nate.the.great View Post
haha, gotcha.
well, i just wanted to share my thoughts. i hope they are put into production, and you make lots of money.
well - if it's good enough to make money someone will copy it and undercut me...but at least people will think I'm cool
I'm still trying to figure out how to get Toyota 4 pots on a WRX - cheap BBK with reliable components for the masses
Old 11-30-2006, 05:05 PM   #28
sonic rex 03
Member#: 62313
2003 FP Green
sonic yellow
i think once you guy have make the kits than set up a group buy for limited time only. see how's the sale go.
sonic rex 03 is offline   Reply With Quote
Old 12-02-2006, 04:06 AM   #29
MiNES
Member#: 106169
Originally Posted by [email protected] View Post
the adapters we make are close but they do not fit. i might be able to change them a little bit to do both. not positive.
the main reason why we didnt pursue it any further was the rotor issue. personaly i think the sleeve inside the OE rotors is very dangerous. sure it might work for a parking brake. so will leaving the car in gear.... what happens if you actually need to use the E brake?
maybe we can work something out with WRXbrakes and put together a package? who knows.
if you want to email me please do.
[email protected]
This sounds fantastic
MiNES is offline   Reply With Quote
Old 12-04-2006, 07:51 PM   #30
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
Will this rotor work with the Legacy? Is the parking brake shoe the same diameter?
mickeyd2005 is offline   Reply With Quote
Old 12-05-2006, 01:24 AM   #31
MiNES
Member#: 106169
yes they are
Old 12-08-2006, 03:35 AM   #32
turbokonejo
Member#: 68669
2000 Dodge Durango
So when can I send payment? I've had my rear brembos laying around for a long time now and I am not buyin a r180 to put them on.
BIG BUMP
turbokonejo is offline   Reply With Quote
Old 12-08-2006, 10:47 AM   #33
sonic rex 03
Member#: 62313
2003 FP Green
sonic yellow
any update on rear brembo?
Old 12-08-2006, 11:14 AM   #34
KNS Brakes
Member#: 125739
2015 WRB WRX
It will take some time - rotor tooling is not quick. A few months at a minimum.
I will edit first post to reflect that and check in anytime I have news.
Old 12-08-2006, 11:20 AM   #35
Rallyroo
Member#: 67994
I'm interested.
Subscribing to stay updated.
Rallyroo is offline   Reply With Quote
Old 12-08-2006, 11:47 AM   #36
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
Interested,
but doesn't that mean we are limited to buy replacement rotor from you only and only 1 type of rotor?
No one else in the market would have a replacement rotor of the same size?
I would think it's better to some how adapt the brembo using a bracket to the h6 rotor or subuar 2 pot rotor. (something more common)
Kenji815 is offline   Reply With Quote
Old 12-13-2006, 02:15 AM   #37
WRXDriftR
Member#: 65065
04 WRX/ STi Hybrid
6MT, VF43
this why you asked if I had a milling machine for rotors?
WRXDriftR is offline   Reply With Quote
Old 12-13-2006, 10:23 AM   #38
KNS Brakes
Member#: 125739
2015 WRB WRX
Originally Posted by Kenji815 View Post
Interested,
If/when DBA elects to make it it will be available from any DBA dealer I would assume.
Old 12-13-2006, 10:25 AM   #39
KNS Brakes
Member#: 125739
2015 WRB WRX
no - I want to design 2 piece rotors. But it's doubtful I can do it any better than the big boys.
Old 12-13-2006, 09:37 PM   #40
emoracing
Member#: 65131
sounds good, lets see what happens
emoracing is offline   Reply With Quote
Old 12-14-2006, 01:52 AM   #41
Ian Godney
Member#: 41573
1999 Subaru RB5
Grey
Just to let you know we in the uk overcame this problem with the E brake by just having thicker handbrake shoes made , had them made 10mm thicker than standard that makes up the difference in size , works perfect and does away with the need for special discs or inserts fitted into them , you can just use stock discs , calipers and pads
Cheers Ian
Edited as I have just had a warning by email not to add any details up , so I guess someone doesn't want you to know the easy / cheap way of overcoming this problem.
Ian Godney is offline   Reply With Quote
Old 12-28-2006, 09:53 PM   #42
sonic rex 03
Member#: 62313
2003 FP Green
sonic yellow
that mean we can use stock rotors and pads? how can that be possible?
Old 12-29-2006, 12:03 PM   #43
BurschiK
Member#: 109250
The pads are thicker:
@Ian: do they fit on the newage Imprezas too?
BurschiK is offline   Reply With Quote
Old 12-29-2006, 01:05 PM   #44
sonic rex 03
Member#: 62313
2003 FP Green
sonic yellow
that is whole alot meat in that shoes.probably last life time of the car
Old 12-29-2006, 03:49 PM   #45
Daishi00
Member#: 78952
2005 WRX
Good stuff Ian. that's a nifty solution to the problem and I may try that route out.
WRXBrakes...you would kill if you came out with something similar to that.
Daishi00 is offline   Reply With Quote
Old 01-23-2007, 11:53 AM   #46
BiggSean
Member#: 97352
2005 6MT 35R Wagon
Full STI drivetrain
Bumping this thread. I need my rear brembos on yesterday!
BiggSean is offline   Reply With Quote
Old 01-23-2007, 12:18 PM   #47
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
i picked up some rotora because i got sick of waiting and if they come out, ill be pist : O
Thran is offline   Reply With Quote
Old 01-23-2007, 04:58 PM   #48
KNS Brakes
Member#: 125739
2015 WRB WRX
I was just informed that DBA does intend to make this part - they have released a part number and begun tooling. That means it is still some time before they are available but assuming no unforseen issues they would be here by late spring or so. Pricing is still up in the air - but it appears that we will be able to offer the brackets and rotors for about $650 ish. The rotors are about $450 and the brackets are about $200.
Old 01-23-2007, 05:08 PM   #49
keaniegenie
Member#: 94494
2005 Element 92x
This is only or people who also want the sti brembo fronts too, right? I'm assuming so since the bias has to be correct. I'd think STI rears is too much rear bias for most setups.
keaniegenie is offline   Reply With Quote
Old 01-23-2007, 05:25 PM   #50
KNS Brakes
Member#: 125739
2015 WRB WRX
This is for installing STi rear Brembo calipers on a R160 rear hub that has a backing plate that accepts Subaru 1 pot sliding calipers.
Most commonly it would be for 02-05 USDM WRX's that have STi takeoffs in front and have too much front brake bias.
It would also fit many Forresters, Legacies, Baja's and older GC cars.
BRAKE ADAPTER to fit 06 STI Rear Brembos on 02 WRX ed10 Private 'Wanted' Classifieds 0 06-01-2009 02:40 PM
Gold Brembos on WRX --- rotor and bracket question ted dibiase Brakes, Steering & Suspension 13 01-21-2009 04:40 PM
Wanted: OEM WRX rear rotors and caliper brackets JWB65 MWSOC Private Classifieds 4 09-26-2006 11:01 PM
2003 WRX Rear rotors and caliper brackets REX8 Suspension/Brakes/Handling 7 09-08-2006 11:14 PM
98 rs calipers w/ wrx rotors and brackets christianvwcars Brakes, Steering & Suspension 3 02-14-2004 11:18 AM
