Notices
Old 12-18-2006, 11:39 PM   #1
Emmettjg
Member#: 135259
1995 Legend
Gn
Legacy Legacy AWD Gas tank leaks! How to change ???
I am intersted in knowing if anyone out there has changed a fuel tank in the 1995 Legacy AWD?
I have a serious leak in mine (read Rust - I live inthe RUST BELT) and it needs to come out.
I have the new tank, but it looks like a bear to change.
It appears the car was built around the gas tank.
The tank hangs over both sides of the rear end and drive shaft.
The cradle for the rear suspension forms a cage behind the tank, and the cross member and sway bar make it a pretty impermeable cage to get the dang thing out.
I am seriously considering cutting the floor out, as it looks easier than taking the whole rear suspension out. (not to mention disturbing the all the fuel and brake lines, emerg. brake cables, hardware, etc. in the process.)
I just don't know if the tank can come out through the top. (width of the Unit body etc. )
Anyone out there replaced one?? Any suggestions?
I would appreciate any suggestions for shortcuts or helpful hints on what to / not do to make this easier, cuz it doesn't seem like it will be fun..
Thanks,
Emmettjg is offline   Reply With Quote
Old 12-22-2006, 10:52 PM   #2
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
The FSM has the complete procedure, but basically it comes down to removing the rear section of your exhaust, the rear diff, axles and crossmember, and disconnecting all the hoses.
I would definitely not recommend cutting anywhere around there, as you'd destroy the structural integrity of the car, not to mention cutting + gasoline = bad times.
Dan Cech is offline   Reply With Quote
Old 12-24-2006, 12:09 AM   #3
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
The only way that sucker is going to come off is down. Like Dan said, most of the rearend has to be removed, which will be a lot less of a hassle than cutting the floor.
It's just one of the bitch things that you have to do properly.
i_c_the_light is offline   Reply With Quote
Old 12-27-2006, 06:57 AM   #4
turbo2ner
Member#: 89385
many most all
WRB/blk/blk/blk/slvr/wht
It's been a while, but I thought it was easy.
I did not have to take the axles off the diff.
I lowered the diff with the axles still attached, and rocked the tank out.
Four boltz for the axle, few more for the shield, maybe six or eight (I forgot) for the diff...hoses and wire connections..remove exhaust.
For a first timer....I'd say four hours at the most.
turbo2ner is offline   Reply With Quote
Old 12-27-2006, 01:54 PM   #5
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Another suggestion would be to perform this procedure when you have little or no gasoline in left the gas tank. If you figure (guessing) that gasonline (in liquid form) weighs roughly 50 to 60 pounds for each gallon, then a half tank of gas might mean, like, 400 pounds.
Jonathan is offline   Reply With Quote
Old 12-27-2006, 02:10 PM   #6
skiwagon
Member#: 43728
2007 328iT
Graphite
Thankfully gasoline isn't anywhere near that weight. It weighs roughly 6 pounds per gallon for a half tank weight of ~42 pounds.
skiwagon is offline   Reply With Quote
Old 12-27-2006, 09:18 PM   #7
linsavy
Member#: 11620
1997 GF4-STiV3 clone
It's a 4 hour job with a hoist and air tools. If you don't have those then it's going to be LONGER...
You will likely need new straps and hardware to hold the tank because the old ones will not come off in one piece.
linsavy is offline   Reply With Quote
How to change transmission fluid and filter in 1996 Legacy LSi AWD 2.5L auto Lat0 Transmission (AT/MT) & Driveline 0 01-22-2010 04:48 PM
Legacy AWD gas tank trevitino Subaru Conversions 2 04-19-2009 01:35 AM
96 AWD Legacy Wagon Gas Tank Quandry Bullwinkle Legacy Forum 11 11-27-2007 04:07 PM
AWD gas tank question scoobyimprza Subaru Conversions 3 05-04-2004 11:19 PM
difference between FWD and AWD gas tanks scobaru Subaru Conversions 2 08-11-2003 03:44 PM
