Old 12-28-2006, 12:17 AM   #51
amukaoen
Member#: 62595
04 WRX Cobb S2
Does anyone know if you do a 2005-2006 STi steering wheel swap with the airbag working if you carry over the 04 WRX cruise control as in the tutorial? anyone done this before? thanks.
(once again)
amukaoen is offline   Reply With Quote
Old 12-29-2006, 02:00 AM   #52
scooby9
Member#: 76026
2007 BMW 335xi
Titanium Silver
Is there any way to re-use the STi cruise control switch? Can the additional wires be passed through the steering column to replace the momentary switch on the WRX dash?
Thanks.
scooby9 is offline   Reply With Quote
Old 08-23-2007, 08:46 PM   #53
poleboy90
Member#: 101028
2000 Impreza RS
STM
A little update since I put a '05 STi steering wheel on my '00 RS, hopefully the '04 STi cruise control wires are the same. The '03 WRX steering wheel (replaced by STi) has the same cruise control wires as my '00 cruise control switch so this should work for both. Heres how to keep the STi cruise control switch, youll need to cut the plug off of your old cruise control switch so it'd plug up. There are 5 wires on the STi one since it has the "enable cruise mode button" on the switch. Heres the what wires you need to connect.
STi cruise control switch -> Old plug ---- Function
Yellow -> White ---- Set/Coast
White -> Yellow ---- Res/Acc
Green -> Green ---- Ground
These wires might have a stripe on them but I listed their main colors. Hope this helps.
poleboy90 is offline   Reply With Quote
Old 08-24-2007, 05:08 PM   #54
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Good job. I am assuming it will be similar in a 06
medamullet is offline   Reply With Quote
Old 08-24-2007, 09:41 PM   #55
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Good write up, but crimp connectors for the airbag...
I work in an airbag inflator design group (read airbag engineer) and I wouldn't mess with them (airbags). I would not generally switch airbags from year to year because generally the inflator and the airbag control module are tuned to work together and should not be used with anything but the exact part number that they were originally paired with.
However, my suspicion is that since this is a single stage inflator, you will likely be just fine. Subaru carries over a lot of technology from year to year. Newer driver's side and passenger side airbags are dual stage and are much much more application specific.
Get rid of those crappy crimps and solder the connection. MAKE SURE TO REMOVE THE CONNECTOR FROM THE AIRBAG PRIOR TO SOLDERING OR YOU MAY KILL YOURSELF.
Once again good write up, pictures are worth a thousand words.
Old 09-06-2007, 09:27 PM   #56
Vahnatai
Member#: 25027
Where did the pictures go?
Vahnatai is offline   Reply With Quote
Old 09-06-2007, 09:30 PM   #57
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
This thread is three years old.
wrxfactor is offline   Reply With Quote
Old 09-06-2007, 09:34 PM   #58
Rizzo314
Member#: 42215
2002 WRX being built
and going for 10s :evil:
I'm having issues with my server. Once I get it fixed I'll be sure to get the pictures fixed.
Rizzo314 is offline   Reply With Quote
Old 09-07-2007, 02:24 PM   #59
Drew888
Member#: 6459
2008 LGT Spec-B stg4
Delicious Tuned 336/336
Thanks riz...
Drew888 is offline   Reply With Quote
Old 09-07-2007, 08:56 PM   #60
Vahnatai
Member#: 25027
Um, I know, but as he said there are server issues. The pics were working a few days ago. I came to print it last night and they weren't loading.
Old 09-09-2007, 07:12 AM   #61
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
anyone know measurements between the wrx wheels on 02-03, 04, 04 STI, and 05+ STi? that would be great to know. thanks. measurements in mm would be awesome and greatly appreciated. thanks
arco is offline   Reply With Quote
Old 09-10-2007, 03:10 AM   #62
arco
Member#: 57156
2007 V.8 207 STi
also do you know if its possible to use an 04 STi wheel with an 04 WRX clock spring without any modification, basically plug and play? i heard that on the 02, the clockspring is different but have heard that it might be the same now. can someone verify this? thanks
Old 09-23-2007, 05:55 AM   #63
Driver X
Member#: 121707
2001 Wrx Wagon
Premium Silver
Too bad the pictures are gone, but real good write up.
Driver X is offline   Reply With Quote
Old 10-08-2007, 03:46 PM   #64
Vahnatai
Member#: 25027
Bump for pics
Old 12-15-2007, 07:50 PM   #65
BuggeyEYED
Member#: 101691
97 Supra TT
SOLD - 35r bug/hawkeye
bump for pix!!
BuggeyEYED is offline   Reply With Quote
Old 12-16-2007, 01:43 PM   #66
ChristianGT
Member#: 166856
1994 Impreza GT
Wow!!!
ChristianGT is offline   Reply With Quote
Old 02-07-2008, 11:59 AM   #67
DomozitoLK
Member#: 58668
2015 WRX Limited
Lightning Red
Default 06 STI wheel on 04 WRX w-working cruise control
I just installed an 06 STI steering wheel in my 04 WRX sedan. It came with the 06 STI clock spring / roll connector as well (which I used). I never swapped or hack any cruise control arms or wires. I am using the 06 STI CC control arm.
I followed many of the posts on here and other forums. Essentially, this is what I did:
  1. Unhooked the negative terminal on the battery
  2. Removed airbag from 04 WRX wheel
  3. Unclipped wires and unbolted 04 WRX wheel
  4. Left bolt partially on and used the yank-method to remove wheel
  5. Removed 04 WRX clock spring (what a pain!)
  6. Installed 06 STI clock spring (even bigger pain)
  7. Installed 06 STI wheel and reconnected wires
  8. Retorqued wheel and attached airbag
  9. Reconnect negative terminal to battery
Everything went pretty smooth. The main issue I had was that only two bolt holes on the 06 STI clock spring / roll connector would line up to the 04 WRX turn signal / wiper stalks. Seems to be holding and working fine even though. I get an occasional buzz or rattle from it once in awhile over bumpy roads. Once I figure out how to secure it it should be fine (either that or get 05+ stalks.) And getting the clock spring wires fished through was a challenge.
I am very happy that the cruise control and airbag connectors are the same and are plug-n-play. The difference is that the 06 STI connector has two extra pins to turn the cruise control ON/OFF from the arm. The 04 WRX is missing those since there is a button on the dash to control that function. I tested everything out and it functions the same as the stock WRX cruise control arm does.
Hopefully this is helpful to other looking for this same info...
Good luck!
Rob
DomozitoLK is offline   Reply With Quote
Old 02-07-2008, 12:04 PM   #68
wrxworx
Member#: 171203
07 2.5i
looks like you got that ish to work !
wrxworx is offline   Reply With Quote
Old 03-08-2008, 09:24 AM   #69
Jon200
Member#: 49003
bump for the re-hosting of pics
thanks
Jon200 is offline   Reply With Quote
Old 03-09-2008, 11:56 AM   #70
Driver X
Member#: 121707
2001 Wrx Wagon
Premium Silver
Bump for update on pics.
What do you do if you dont have the clockspring?
Old 03-20-2008, 01:43 AM   #71
nycsubaruwrx
Member#: 157456
2003 JDM GD and GC
Aspen White and STM
bump for need for the original pictures for swap!!! thanksssssssss
nycsubaruwrx is offline   Reply With Quote
Old 11-20-2008, 10:32 AM   #72
02WRX"monster"
Member#: 173100
also bump for original pics. I am looking into swapping a wheel with audio controls on it. not worried about the audio wiring just the airbag and cruise anybody have any ideas? i am looking at either the 06 legacy spec b wheel or 08 legacy spec b wheel but if you know of others that may work better let me know
02WRX"monster" is offline   Reply With Quote
Old 12-07-2008, 10:21 PM   #73
Pee_Sack
Member#: 98266
2003 WRX Cobb Stg 2
Same as the sky
any chance you can get the pics back up?
Pee_Sack is offline   Reply With Quote
Old 12-08-2008, 12:32 AM   #74
mannyOlicious
Member#: 173829
04 dom3 +meth pyah
09 triumph daytona 675
its REALLY straight forward...
1. look behind the steering wheelat 3 and 9 o'clock, unscrew the torx screws...
2. take out the air bag
3. (with the steering wheel locked) grab a breaker bar and break the bolt loose (its the ONLY bolt you see.)
4. if you have the clock spring, simply undo the screws and screw the new ones in... if not, just align the new steering wheel as best as possible and slide it back in, then bolt it back up, place the airbag in place, and tighten up the torx screws
mannyOlicious is offline   Reply With Quote
Old 12-19-2008, 07:12 PM   #75
ThinktecWRX
Member#: 197237
2002 Subaru WRX
The pictures on this write up don't work anymore =[
ThinktecWRX is offline   Reply With Quote
DIY: How to swap an 08 STi steering wheel into an 05 STi xxscaxx Interior & Exterior Modification 113 06-18-2016 02:02 PM
putting an 08+ STI steering wheel into an 07 WRX? NMZ_WRX Interior & Exterior Modification 1 05-19-2010 07:57 AM
installing a 2004 sti steering wheel in a 2002 wrx mhwrx02 Interior & Exterior Modification 0 06-28-2009 10:47 AM
FS in MD: 2004 silver sti bbs wheels w/ tires; 2002 wrx wheels w/ snow tires ALaDDiN MAIC Private Classifieds 26 03-09-2008 03:02 AM
How to put a 2007 usdm sti 6 speed into my 2003 WRX InfamousDX Transmission (AT/MT) & Driveline 11 10-27-2007 12:54 AM
