Old 11-02-2006, 11:03 AM   #51
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Finally got around to measuring the '97 ports. 59mm x 48mm with "D" shaped ports...
Old 11-02-2006, 05:37 PM   #52
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
good to know
are they HLA? i would assume not?
Hurley 2.5 WRS is offline   Reply With Quote
Old 11-02-2006, 05:45 PM   #53
Matt Monson
Member#: 832
99 2.5RS, '85 911
Nope. They are shim over bucket. The '96 is HLA...
Old 11-03-2006, 02:29 AM   #54
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Which heads are those? Any pics?
EDIT: scratch that.....EJ20K heads you measured....
Also...I was talking with one of the guys who had a STi Ver7 head. He noted that they where the small ports. The intake ports where IDENTICAL to the USDM WRX heads as well as the USDM STi heads.
So this means that the small ports are the ones we got; USDM WRX/STi heads. 2 different castings for the NEW PHASE heads; MY00+ GD.
FuJi K is online now   Reply With Quote
Old 11-03-2006, 02:36 AM   #55
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
so can we get a comprehensive list of measurments of all heads? I could get my hands on some legacy outback heads but don't know if its wroth it...
scobaru is offline   Reply With Quote
Old 11-08-2006, 09:04 PM   #56
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Originally Posted by Scoobie Steve View Post
There are 2 different Ver 7 heads. Large port and small port "JDM and import". The Import heads are junk and cant be compared to a JDM head. I would be interested in port CC numbers but you need to find a real Ver 7 JDM head.
yes, the STi head and then the STi spec C head...I would be very interested in the seeing a cc comparison of pretty much all the heads (minus the ej18 and ej22 sohc).
Old 11-22-2006, 01:40 PM   #57
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
a follow to my post, post #54
okies.....confirmed....the SMALL PORT STi V7 heads are the same casting as the USDM WRX heads. The BIG PORT casting seems to have started out with the Ver5 STi/RA. They are all the NEWER head casting, which is why they run a different cam than the Ver 1-4. You can see this clearly when you take out the cam and the end caps to where the cam seal is.
Seems all the old school heads are of a large size because it was still OBD1 for the most part and less emmissions then. The NEWER castings, which we got for our USDM '02 WRX and other countries UK? AUS? got the economy heads; small port casting. The S201-S204 heads and SPEC C heads all may just be the same size in port aside from factory porting at the entry, which I've seen in some pictures. Because NEWER cars are coming out, many speculate them to have LARGER ports EVER! But a lot has to do with the AVCS and cam profile which is why it does flow better than the older ones, IMO.
Old 11-22-2006, 09:22 PM   #58
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
OKIES, something NEW.... I got to take a look at the FIRST DOHC NA 2.5L that we got here in the US. This head is the hydraic style valvetrain. A '96 2.5L. I NOTICED that the port is the SAME SHAPE as the gasket. The 4mm LOST is not apparent on this head. The valve covers are stamped with "4 CAM 16 VALVE" on the sides. The valve guides look just like mine so this port is actually a bit different from the SVX port, which I've seen is the same port casting on the OLD STi EJ20G heads, not sure of the Legacy EJ20G but the Imprezas seem to be. NOTE: The engine is from a friend of mines (wagonL) and is out of a '96 Legacy 2.5GT. He somewhat touched the splitters so I'm not sure if it was skinny like the '98 or what.
Here is a pic. NOW we have a '96 DOHC 2.5L head in the bunch. Not sure of the Combustion chamber yet. No doubt these '96 EJ25NA heads are KING here as a US-Spec Subaru head for intake port.
Here its layered on top of my '98 EJ25NA head to compare with the BIG PORT STi head on top.
'96 head LAYERED over the botten head which is a '98.
Here you can see the Valve guide how it protudes into the port MORE than the DOHC EJ25NA head.
EJ20G
'96 EJ25 NA DOHC
Old 11-29-2006, 06:02 PM   #59
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
where are the pics of these IMFAMOUS heads?
Quit keeping them away from me!
Old 12-03-2006, 09:46 PM   #60
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
I know this is mostly a comparison of the DOHC heads, but what about the 99 SOHC heads compared to the DOHC heads port size.
civic2scooby is offline   Reply With Quote
Old 12-06-2006, 07:44 PM   #61
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
the '99-01 SOHC
The port runner on the 97-99 DOHC are D-style thus allowing some flow. The '96 DOHC have a BIG port entry of the old skool heads and flows more than the SOHC. The SOHC isn't as wide, but is taller than the '97-'99 DOHC.
The difference in the SOHC and the DOHC is that the power curve is different but peak power is the same. The SOHC has more torque in the lower revs to midrange. The DOHC has similer midrange but doesn't drop off as much as the SOHC as the rpms past 5000rpms.
Old 12-18-2006, 05:22 AM   #62
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
I measured the ports of three heads over the weekend:
EUDM MY97 EJ25D: 58 x 44 mm (58 x 30 without injector boss)
JDM MY99 EJ254 (with AVCS): 59 x 49 mm (59 x 35 without injector boss)
USDM MY92 EJ22T: 49 x 44 mm (49 x 31 without injector boss)
I also calculated the cross sectional area of intake and port runner. I will put the Excel-file onto my homepage after Christmas.
Marnix is offline   Reply With Quote
Old 12-28-2006, 01:26 AM   #63
liberty2000rs
Member#: 33348
2014 Eco, 08 Duramax
Great Info guys!! Does anyone have any cam lift charts for the JUN 272's that fit the EJ25D heads??
liberty2000rs is offline   Reply With Quote
Old 12-28-2006, 05:19 PM   #64
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
now if there was a way to convert hydr. heads to mechanical....
thanks for the info and time you put into this FuJi K
snowman4us is offline   Reply With Quote
Old 01-02-2007, 05:12 AM   #65
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
There is. You can use lifters and shim of the EJ20K/EJ25D on EJ20G heads. You can use the hydraulic cams on solid lifters, but not the other way around (due to cam wear, hydraulic cams are hardened allround, the mechanical cams only the lobes not the base circle I've been told).
Old 01-03-2007, 03:15 PM   #66
Matt Monson
Member#: 832
99 2.5RS, '85 911
I should have some more numbers to post in fairly short order. I purchased an Ej20G auto tranny '95 WRX engine and an Ej20H TT engine yesterday as well. I will add my info as I find time. I have been in the midst of buying a house and a business and haven't had much time to dink in the garage. That should change in a few weeks and I will be sure to do my part for this thread and the knowledge database...
Old 01-03-2007, 03:34 PM   #67
kheff46
Member#: 66739
2002 WRX wagon
c'mon matt. thats ALL you have to do? get a movin'
kheff46 is offline   Reply With Quote
Old 01-03-2007, 04:22 PM   #68
Matt Monson
Member#: 832
99 2.5RS, '85 911
Actually,
I got engaged on Sunday, so that's one more thing to add to the mix...
Old 01-03-2007, 04:27 PM   #69
kheff46
Member#: 66739
2002 WRX wagon
congrats! at least she isn't in the dark about your suby fetish!
most wedding stuff is her planning anyway. just a bunch of "yes dears and ok honey's" and hand holding during planning. meanwhile your thinking about subaru's!
love is blind!
--keith
Old 01-03-2007, 04:49 PM   #70
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Love should also drive a Subaru.
But I'm not sure if my wife will appreciate lifting the intake manifold to measure the MY90 EJ20D ports!
Old 01-03-2007, 05:07 PM   #71
Matt Monson
Member#: 832
99 2.5RS, '85 911
My fiance drives a '99 RS. When I told her I was selling my MY00 RS, I asked her if she wanted my built motor or if she wanted me to continue with my plans to install the Rimmer SC on her car. Her response?
Can't I have both?!?
Old 01-03-2007, 05:40 PM   #72
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
more turbo motors ...
geebus the new ghetto garage must be huge
Old 01-03-2007, 06:07 PM   #73
kheff46
Member#: 66739
2002 WRX wagon
matt- you fiance is smart. and that'll cost ya!
good luck with everything!
--keith
Old 01-03-2007, 06:55 PM   #74
Matt Monson
Member#: 832
99 2.5RS, '85 911
It's smaller. It's just better organized and it going to stay that way...
Old 01-04-2007, 10:29 PM   #75
Ozzy
Member#: 8774
1998 Impreza RS
Heres a few of my 98 heads
Match ported to my gaskets, dimensions are almost exactly what Matt Listed above 59x48 after hogging out a bunch of material.
Ozzy is offline   Reply With Quote
head porting and arp head studs..... ejsportcom Built Motor Discussion 6 03-24-2006 12:05 PM
IL: Gruppe-s header, TXS TBE, APS UP, Axis Stg 4, Ported heads, Ported TB, Manifold BLUETURBOWRX Private 'For Sale' Classifieds 20 03-06-2005 06:19 PM
IL:Gruppe-s Header,TXS TB,APS UP,Axis Stg 4, Ported heads,Ported TB,Manifolds & more. BLUETURBOWRX Mid West Subaru Owners Club Forum -- MWSOC 14 02-23-2005 09:47 PM
throttle body & head porting? JST Normally Aspirated with bolt-on Forced Induction Powertrain 5 07-23-2002 08:24 AM
